Vizio 42" LCD VW42LHDTV10A Will Not Turn On
  • Mulp
    VIZIO M65-C1 Does Not Turn On
    by Mulp
    Hi All,
    I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
    When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
    I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
    01-13-2024, 09:57 PM
  • EazyBone
    Vizio V705-H3 Won't power up
    by EazyBone
    This TV has the white light on the front. When you click the power button or hit the remote nothing happens the lights stays solid. I checked the main board for the voltage for that signal and everything is fine.
    The power supply is giving 13 volts and 2.7 on AC detection. Zero on PSOn and nothing changes when hitting power. The led lines show zero and those caps won't turn on
    ​​​​​​ it seems the PSU won't turn on to supply voltage to LEDs. The main caps sit at 170v.
    It's odd to me the led lines go from PSU to main board and THEN to LEDs.. as a note....
    03-01-2025, 01:34 PM
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • mrtek
    Vizio M65-C1
    by mrtek
    Hi.
    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
    Today, 07:28 PM
