Philips LCD 47 black screen
  • AndyD
    • Sep 2012
    • 15
    I have a Philips LCD model#47PFL3603D/27. The problem I am having is that I will be watching the TV and the the screen will go black. I still have sound. Sometimes the screen goes black slowly, other times instantly. Sometimes it will work good for over an hour or two, other times five minutes or less. It also occasionally makes noise as it goes to black. I can shine a flashlight at the right angle and see whats on the screen. I have taken the back off the TV and cant see anything obvious, but I have little to no knowledge in this department. I have read some people having this problem but a few different fixes. wondering if anyone has had this exact problem or any experience with this TV and an exact fix. I took some pictures, dont know if they will help or not. Can take more pics if needed. Thanks in advance, Andy
  • drpj23
    • May 2012
    • 528
    Re: Philips LCD 47 black screen
    On the smaller used connector, there should be a pin called INV_on, what is the voltage on that pin when it does go to black? If you catch going to black slowly I would monitor that pin and the DIM pin.
      Look at the screen in the darkened room when the picture goes black, see if you can see the slight glow from the backlights or not, we need to find out if the backlights go out or the T-CON board quit working.
      • AndyD
        • Sep 2012
        • 15
        Thanks guys for your responses. drpj23, I cant seem to find INV_on. Sorry to be difficult, but is there any way you could point me in the right direction? which board is it on? I have a multi meter ready to test if I can locate it. budm, I will check tonight after it gets dark. Thanks again
        • RON_CET
          • 217
          Check the solder connections @ the backlight inverter transformer @ bottom right of your photo#5 image,the noise you maybe hearing is the arching of the connections from that
          inverter transformer pins to the pad connection.
          Ron Driver,BSEE,CET,ISCET,NESDA
          • AndyD
            • Sep 2012
            • 15
            Looks like RON CET nailed it on the head. Took the TV further apart to look at the back of ther boards, and that looks like a problem to me. Im guessing I will need a new board then? or can that be fixed? or is it not worth it?
            • RON_CET
              • 217
              that can be fixed,take soldering scrap tool or knife blade scrap the pin and the pad,to just where you see the copper run,then you can reapply solder to the pin and exposed copper run to re-flow connection
              • AndyD
                • Sep 2012
                • 15
                Ok Thanks again. I will try that. probably wont be until I get back in town this weekend. Thanks again for your help on this. I will let you know the results.
                • Got sol
                  • Oct 2012
                  • Usa
                  Andy it seems like I'm having the same issue. Let me know if this worked for you.
                  • AndyD
                    • Sep 2012
                    • 15
                    I will keep ya posted. I plan on trying to fix it Friday night or Saturday morning at the latest. If that doesn't work I will order the board. I found it for $75.00 so hopefully that a worst case scenario. Did you take your TV apart yet?
                    • AndyD
                      • Sep 2012
                      • 15
                      Well I re-soldered the connection and so far so good. I watched an hour or so so far and it is working the way it should. Thanks again for all the input. Saved me a bunch of money!
                      • AndyD
                        • Sep 2012
                        • 15
                        Haha. Spoke too soon. Back to the black screen. Tried re-soldering connection again. We will see but I am expecting to have to order a new board.
                        • vildasha
                          • 5
                          I have the same problem. Is anyone help me? I have all equipment.
                          • HTR-Informatique
                            by HTR-Informatique
                            02-09-2025, 06:51 AM
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
                          • VcemPzd
                            Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                            by VcemPzd
                            Hello everyone !
                            My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                            04-28-2025, 10:14 AM
                          • bohaboha
                            PHILIPS 75PUS7805/12 BLACK SCREEN
                            by bohaboha
                            Hi all this set power on and the ambient lamps lite but the screen is black and no sound i tried Samsung way to test backlight but it did not work i did also try to power of and hold power for some times nothing happened
                            on power supply big capacitor :394v on tcon the 12v and 3,3v even on Mainboard...
                            08-10-2025, 09:04 PM
                          • DaniK
                            Acer Aspire E5-574-52RH - black screen
                            by DaniK
                            I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                            Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                            Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                            Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                            The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                            Symptoms are:
                            - random black screen after displaying Acer logo...
                            02-21-2024, 06:27 AM
