I have this small lcd tv that I am working on. when I push the power button on I can see faint image but the tv won't turn on. when it is in charging mode, the power button continuously flashing. where should i start? any idea?
HAIER HLT10 No video no power won't turn on
Re: HAIER HLT10 No video no power won't turn on
Haier=Expect inconsistent quality.
I had a bad experience with one of their window air conditioner units, seems that a moron over in the PRC made the evaporator too cold! Mine froze up like a bastard.
Bet that it can also freeze up at 70 F+!Last edited by RJARRRPCGP; 09-27-2012, 04:50 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 -
It is a just a PC monitor with tuner and Video inputs.
So post good clear pictures of the board and use the attachment function in the GO ADVANCED to post the pictures then we can tell you the test points to check.
Since this unit uses wallwart adapter, have you verify that it is OK? Also remove the batteries and see if it will power up by the wallwart.Never stop learning
budm, input power required for the tv is 9v-12v DC, 2A.
I do not have the original power supply but I found one with 9v DC and 2A.
I the power button continuously blinks like , it is trying to charge the battery. I heard that the power button usually turns green when functional. But it is red now.
I have taken apart the tv , I will take some pics and post it here. Thanks for the reply.Comment
Did you try removing the batteries?Never stop learning
if I remove the battery, the unit is totally dead. There is not even red light blinking. But I see faint image with or without the battery.
The main board has lot of small 100uF 16v and 220uF capacitors on it. None of them are bulged or look bad.Comment
If you disconnect the walwart and the batteries, do you see faint image with the flash light?
If you do, then we will need to look at the backlights inverter circuits when you post the pictures.Never stop learning
ok with battery connected, The power LED power red and blinks on the side. Without the battery and wall charger connected, the LED power in the front stays solid and I can see faint image with flash light.
Also seems like inverter section is built in on the main board. There is only two boards in it. Main board and control/switch board.Last edited by arman960; 09-28-2012, 09:49 PM.Comment
Well, I am waiting to see the pictures of the board.Never stop learning
On picture #1 I can see a white plug with red and white wires which looks like it is for the backlight. Where does this plug go to on the board? I do not see typical High voltage transformer any where on the board. Can you leave that connector connected to the board and take pictures of that area. This unit may use LED backlight.Last edited by budm; 09-28-2012, 10:33 PM.Never stop learning
you are right. I do not see any transformer on it. I think led on this unit. But LED not working as back-light. LCD panel works though as I can see image with flash light. I will take more pictures and post it.Comment
The must be a regulating power supply close to that connector, just need take a close look in that area.
Can you measure any voltage on those two pins of the connector? They will more likely to put the White LED in series, so if one goes out, it will kill the rest.Never stop learning
I do not see any voltage regulator on the main board or lcd panel. All I see some IC , capacitors, resistors. Please check the board.
The LED near the power supply port lights up only when I connect the battery. Without the battery there is no light , acts like totally dead.Last edited by arman960; 09-30-2012, 06:59 PM.Comment
looks like i might have missed one where 2 caps are laying on top of it. just helping along not an expert.Comment
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by masoksianHi everyone,
I am dealing with the problem of turning on and off my Dell e7470 notebook.
The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
The system does not turn on, there is no post.
I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
The problem continues in the same way.
I tried to turn on the Fn key, nothing came to the screen.... -
Assuming...7 Photos -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
by Journey11Hi All,
First time posting here ... my name is Kevin but my friends call me Journey.
I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again.... - Loading...
