Vizio E470VLE eeprom?
+ More Options
Posts
  • charliestv
    • Mar 2010
    Re: Vizio E470VLE eeprom?
    Hi electronicsurplus,
    Can you contact me regarding Vizio EEPROM bin files. We need some of those.
    Thank you,
    Mike
    • spansion
      • Jun 2014
      • US
      Originally posted by electronicsurplus
      We have most of the Vizio EEprom bin files if anyone needs them and, we have found that the Same exact Bin file will work for a lot of models. They can be re-flashed right in circuit using a SOIC8 adapter and, EEprom writer. which are relatively cheap.
      Hi, i was wondering if you have an eeprom bin for a vizio M550NV tv, the tv only shows the logo on the screen.
      thank you
      • Daveyk01
        • Apr 2015
        Originally posted by budm
        The 'E' or economy series seem to be bad TV's, see so many people here and on the web are having problem with EEPROM, may be Vizio should have recalled them.
        I have one that I just ordered a Main PCB repair kit from ShopJimmy (although I think only the EEPROM is bad).
        My question is, what is causing the EEPROM to fail? Is it really failing or just getting its programmed scrambled? That's scarier yet.
        Dave
        • jason123
          • Oct 2015
          • 1056
          can you share the E470VL Bin file?
          • elpelado
            • Mar 2014
            • 8
            • united states
            I hooked up a EEPROM and it smoked got real hot
            • edgarmg15
              Damaged EEPROM on TV Vizio E320-A0
              by edgarmg15
              Hi everyone
              Iยดm trying to repair a TV Vizio E320-A0 that I found in the street
              The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
              The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
              So, Iยดm going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
              11-19-2022, 03:46 PM
            • NSkyLab
              Toshiba 55SL417U looking for EEPROM and Firmware
              by NSkyLab
              Hello everyone, I described the symptoms and measurements here
              It seems I tried everything, my last idea is that the eeprom or firmware (or both) may be corrupt.
              I'm not able to find eeprom and firmware dumps in open sources.
              Hoping someone here has access to closed forums or manufacturer's service center resources and can help get those dumps?
              01-20-2023, 12:29 PM
            • jason123
              Vizio D50-F1 - Can't update Software / Firmware
              by jason123
              Wondering if any of you have seen this before. I got this TV with lower half of the screen dim. Fixed the LED backlight issue - smooth
              I noticed that the System update lists current firmware is V1.0.6 and is able to find on the Vizio server 2.60.23-1... it downloads fully.. but instead of restarting, it just goes back to the previous screen "NO SIGNAL - HDMI1"
              I got the code and followed the update via flash drive - and it does exactly the same thing. Firmware is copied by the TV 100%, and then nothing - instead of restarting, it just goes back to the previous...
              08-15-2021, 06:48 AM
            • Lee M.
              Vizio E55-DO firmware corrupted?
              by Lee M.
              I was given this set and do not have the original remote. It will turn on with the power button and display "oobe V1.1.12 firmware V0" but that's all it will do. It does not respond to the input select button or volume button. I have a remote from the cable company and programmed it for Vizio and it will turn the set on and off but that's it, no response from any other buttons. The white standby led comes on bright at first and then dims but stays on while the set is on. I pulled the back off and looked for anything obvious like loose connectors, bad solder, bad caps and didn't find...
              04-02-2023, 03:12 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
