Insignia NS-LCD32 powers on but blank screen & no sound, need help troubleshooting
    Re: Insignia NS-LCD32 powers on but blank screen & no sound, need help troubleshootin
    We will still need to know if you get the power to the T-CON or not.
    • omegastrm
      • Sep 2012
      • 19
      • Amerka
      I checked each end of the F1 green fuse on the T-Con board and its getting 5 volts on each end.
        I wonder now if the main board is sending any signals to the T-CON, or the new T-CON is not good. You will have to use the Oscilloscope at this point to look at the LVD signals feeding the T-CON to see if there are any activities at all.
        • omegastrm
          • Sep 2012
          • 19
          • Amerka
          can I just check the voltage on the cable wires going out from the mainboard into the tcon board?
            The LVD signals are high frequency in the Mega Hertz range that you AC meter does not have the bandwidth to be able to measure. You can try to locate the LCD panel model number to look for the spec sheet to show us what the pins are on the T-CON board, then you can try using the meter to see if it may or may not show any action on the meter.
            • omegastrm
              • Sep 2012
              • 19
              • Amerka
              #26
              I will try to find out the panel model number tomorrow. I think I have to unscrew a couple of bolts to take off the boards and reveal it.
              On a side note, I measured voltage going in from the power supply to the main board and there were two wires that were getting a lower amount of voltage (11.55v) rather than the 12v that it stated on the board, versus others wires that were getting a little more than the recommended voltage i.e. a 24v wire was getting 24.3v, which seems ok.
              is that .5v deficit a possible problem or no?
              • diodo49
                • Dec 2012
                • 17
                I want to know...
                  No, the 12 will be fed to a bunch of voltage regulators and regulated switching power supplies on the T-CON board, the 12v power supply is also used for Audio amplifiers which can tolerate voltage variation.
                  • omegastrm
                    • Sep 2012
                    • 19
                    • Amerka
                    #29
                    alright so I got me another main board and currently returning the first one i purchased. It turns out the first mainboard that i got had two end digits off even though it was advertised as the board that I needed with the correct pn.
                    Thats my fault so my lesson is learned: NEVER RELY on others to be accurate. Even if it looks identical and most of the numbers match up. Make sure that that it is the EXACT one that you need!
                    Once installed I got a picture, however I encountered a new problem with this next main board: the screen is grainy and has a weird color distortion to it as shown in the pictures. Now i can return it or if anyone has a solution as to any possible component failure inside the main board thats causing this, i'd love to hear it.
                    • beamus
                      • usa
                      #30
                      so bottom line is after all purchasing the "t-con board" was the best bet. I have the same problem with this type of TV. The power goes on, but nothing shows on the screen. It was given to me that way.
                      I am thinking on taking it to be fixed, but it not too sure.
                      Don't have all the equipment for testing...
                      • ChaosLegionnaire
                        by ChaosLegionnaire
                        09-13-2022, 09:02 AM
                      • mecha1166
                        KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                        by mecha1166
                        KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                        11-25-2024, 05:22 PM
                      • LEECH666
                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                        by LEECH666
                        Good day ladies and gentleman!
                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                        01-19-2024, 05:46 PM
                      • mrtek
                        Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                        by mrtek
                        Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                        11-26-2024, 09:58 AM
                      • jose6326
                        Insignia Ns-l22x-10a no picture only sound
                        by jose6326
                        When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
                        When i was removing the back cover i heard a rattle.
                        Removed the metal plate and the heat sink was off (see pic)
                        would this cause a no picture/image issue?
                        What is used to put back the heat sink
                        07-30-2024, 11:03 PM
