40" Samsung lnt4061f Vertical lines no backlight
    Re: 40" Samsung lnt4061f Vertical lines no backlight
    I expect BOTH transistors will show about 10 Ohms on two pins reading, if you look at the diagram you will see 10 Ohms resistor between Source pin and Gate pin. How about the fuse?
    • tieny
      • Feb 2012
      • 478
      FS801? The one also next to the AC input? Checked it, seems to be good
      EDIT: oh F1801 just found it, i checked its continuity and it seems good.
      • tieny
        • Feb 2012
        • 478
        I measured the voltage across the Fuse F1801 and got a reading of 0.42V and tracing to this component here, that outputed 0.42V but the input had a reading that was oscillating between 0 - 10V dc.
        I noticed that the board seemed very dirty, I'm guessing it must of sustained water damage and least this board anyway. Because also some of metal components seem to have rust on them as least thats what it looks like to me.
          That 0.42v across the fuse is OK since fuse is not 0 Ohm, the fuse is fed with about 390Vdc, you have to use the Negative leg of the large DC filter cap in theprimary side as a reference ground point when you work in the primary side of the circuits. The voltage on either ends of the fuse should be around 390Vdc with ref to primary ground.
          The board looks rusted out you may have to clean it out real good with alcohal, some of the component leads may be eaten away, need good inspection on all the traces and leads. How much is the new board? Did you check around yet?
          • tieny
            • Feb 2012
            • 478
            You're right i measured across the fuse again and got 392Vdc on both ends.
            I checked around and lowest Ive found was on ebay on 60$. Kinda pricey for me and I already spent a good amount on the tv =(
            • tieny
              • Feb 2012
              • 478
              Well I'm completely lost. I've been checking the components near the transformer and those mosfets and I can't seem to find anything odd or wrong.
              • tieny
                • Feb 2012
                • 478
                Is there a way to check if a transformer is good or bad?
                  You need Ringer tester to find shorted turn, just Google it. Otherwise you can use Ohm meter to see if the windings are open or not. Which transformer did you pull out. Did you down load the diagram of the board and look at it yet. On page 3, top left, do you have that 12V feeding that transformer driving circuits
                  • tieny
                    • Feb 2012
                    • 478
                    I pulled out T1802 (the one you were just talking about), I think I just created a new problem... When I pulled out the transformer, I forgot to put it back in the board and I plugged everything back on together and tried to power on the TV, but I noticed it wouldn't power on. So then I soldered the transformer back on and now everytime I plug in the power cable all I get is the standby LED light slowly blinking on and off and pressing the button has no response. Did something fry when I turned on the TV without the transformer?
                      Well, do your tests methodically: Do you still have standby power?
                      It's inadvisable to remove components from a power supply and then run it, though I doubt you did damage.
                      • tieny
                        • Feb 2012
                        • 478
                        Checking the power on/off connector pin I still have 5.26V showing, actually it would drop back down to 0.04V for a second and rise by up to 5.26V continuously. (As oppose to 0.04V on standby and 2.79V when turned on from post #8, I received prior the new problem ). And the standby pin measures constant 5.26V. I measured the large cap and still a reading of 162.2V
                        • tieny
                          • Feb 2012
                          • 478
                          Nevermind, I found the problem the power on/off had a broken trace, must of been when it scraped against the panel when I took it off and on the panel.
                          I'm getting a measurement of 11.83V on the two pins of the transformer.
                          • tieny
                            • Feb 2012
                            • 478
                            Alright so the backlight problem has been solved. Now with the backlight on I see a new problem...
                            When the TV turns on to the cable input, it starts flickering a bit until it lights up steady however on the left side of the TV has some werid distortion. When I put it into hdmi input there are some lines that appear in that area.. I thought it was a bad panel issue.
                            Videos of what I'm talking about:
                            http://www.youtube.com/watch?v=Bn2UDBnE6o8&feature=plcp
                            The left side of the screen also seems darker and has a bit of color distortion. Its quite noticable that one side is darker when on the cable input where the white noise is pictured.
                            http://www.youtube.com/watch?v=7QoXoONUjp8
                            The OSD input doesn't seem to be affected at least I don't think. The OSD menu is hard to tell cuz it was a bit transparent already. I tried messing with the tab bonds to see any effects but there was no change. Around that area on the left is the only area where the picture seems to "ghost"
                            Video of the input label:
                            http://www.youtube.com/watch?v=uqkZ5...ature=youtu.be
                            I simulated the problem I had in the beginning of this thread where it only showed vertical lines all over the screen by removing the component on the tcon below again (photo below, an inductor?) I had to strip away the bottom to reveal the leads so i could solder it back on the tcon board.
                            If it did have a bad panel wouldn't the vertical lines be more distorted in some way along the left side of the tv? So I'm thinking it might just be tcon at fault? (photos below, pattern changes when i turn the tv off and back on) The Tcon had been damaged already when I got the TV so its possible that there is futher damages.
                            QUESTION AT HAND:
                            Is the panel bad itself or is it just the tcon board that is at fault?
                            • tieny
                              • Feb 2012
                              • 478
                              If I unhook only the left ribbon cable from the tcon board the entire left half of the screen turns white. If I unhook only the right ribbon cable from the tcon board while the left is still on, The entire right side of the screen turns white but the left side also turns white with a few random lines overtop it. It seems like its struggling to maintain the left side of the screen by itself.
                              If both ribbon cables are unhooked, I get a perfect white screen. Is it the tcon or panel? I don't know at all...
                              • tieny
                                • Feb 2012
                                • 478
                                Any opinions?
                                  If I were you, I would try new T-CON board, if it does not fix the problem then you know it has worst problem, the panel, sometime it is worth spending $20~40 to find out.
                                  Or you can post good pictures of the T-CON board then we can try testing some voltages on the regulator IC's and switching power supply output and look for shorted out MLCC (Multi-Layer-Ceramic-Capacitor).
                                  Check the DC voltage of the T-CON fuse also, it should be either 5 or 12V, depends on the panel..
                                  • tieny
                                    • Feb 2012
                                    • 478
                                    Well, heres a photo of the tcon board, where should I start?
                                    Tcon fuse I get around 12.81V
                                      If look at the board real close, you will see a lot of test points with Voltage labeling on them, see what I have circle, check those voltage and write down each reading with name of the test points also.
                                      • tieny
                                        • Feb 2012
                                        • 478
                                        VDD: 3.28V
                                        VCOMG3: 5.55V
                                        VCOMG2R: 6.07V
                                        VST2: 5.76V
                                        VON_P: 22.9V
                                        VCC_3.3: 3.26V
                                        VREF_M: 1.3V
                                        VREF_T: 1.42V
                                        VDDQ: 2.58V
                                        LVDS_33: 3.26V
                                        VCC_1.8: 1.86V
                                        VCC_2.5: 2.6V
                                        Fuse F1: 12.79V
                                          The regulated DC reading are within the range for the 1.8, 2.5 (may be a little high, 2.6 is above 2 %), 3.3V voltages. I am not sure other reading though. I am not sure what else I can suggest. One test point I cannot see is the VLOW on the board, it is usually -10V or more. May be more T-CON expert can chime in.
                                          • Falki
                                            Colorful LCD Vertical Lines on Samsung ue55es8090
                                            by Falki
                                            Hello there, ive recently found an older 55inch Samsung SmartTV.
                                            A similar issue has been posted as well but also with no actual response ...
                                            08-12-2025, 04:19 AM
                                          • Stanley1843
                                            by Stanley1843
                                            06-29-2024, 11:54 AM
                                          • arctor
                                            samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                            by arctor
                                            hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                            04-26-2025, 05:22 AM
                                          • x_orange90_x
                                            Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                            by x_orange90_x
                                            I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                            The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                            09-04-2023, 12:09 PM
                                          • polaro
                                            Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                                            by polaro
                                            Greetings,
                                            I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                                            08-27-2022, 08:46 AM
