40" Samsung lnt4061f Vertical lines no backlight
  • tieny
    • Feb 2012
    • 478
    Hey guys I have a lnt4061f samsung LCD TV. So here are the initial problems I'm seeing so far. I am able to turn the TV and it will turn on just fine however there is no backlight that goes on at all. I used a flash light on it and I can see color vertical lines all across the entire screen.
    Also when I lay the TV face down with the screen facing down or place it upside down I hear the relay continuously clicking as soon as I plug in the power cable.
    Is this TV even able to be fixed? Would the vertical lines point to a bad panel, though it covers the entire screen? I will put up some photos tomorrow.
  • Mr Bill
    • Nov 2011
    • 648
    Re: 40" Samsung lnt4061f Vertical lines no backlight
    The power supply in this model is full of capxon caps. When you open this tv up i'm sure there will be several bloated. The tcon could be failing causing the lines but a faulty power supply could do it too. I do have this exact model in my basement with a broken screen so if it needs a board atleast you'll know where to look
    • tieny
      • Feb 2012
      • 478
      Oh I forgot to mention, I already checked the capacitors on the power supply with my esr meter and they all seem to be good. Except that some of the traces seem to look damaged. I read that bad capacitors on this power supply actually caused the vertical lines on this tv. But what would cause the no backlight? I think I should fix the backlight problem first so I can get a better look at the vertical lines.
      • Mr Bill
        • Nov 2011
        • 648
        Did you check the fuses on the inverter. 24v coming from the power supply?
        • tieny
          • Feb 2012
          • 478
          Can't seem to find any fuses on the inverter board. I feel this might be a power supply issue. Theres 12.1V from the output of the PSU going into the inverter board (Pin labeled VCC_12V). Also on standby I'm also not getting any reading on the pin labeled STB5.2V.
            This TV has power supply/Backlights inverter combo board (high voltage transfromer on rhe botom left of the board), it will be a harder to troubleshoot. That long board on the left is the high voltage balancer board to ditribute the high voltage from the Power supply/inverter combo board.
            There are connectors on the combo board, can you please show good closed up pictures so we can see the labels on them? The board is BN44-00167, need to look up the diagram for it. One palce to test right now is the DC voltage on that large cap in the primary side, check it when the TV is plugged in (it should be around 165VDC) and then when TV is turn on (it should be around 390~400VDC), this board has PFC Voltage booster circuits.
            Diagram for BN44-00167A: http://www.tgohome.com/ServiceManual...g_BN44-00167A_[SCH].pdf
            Check CN801 Pin 1 Power ON-OFF Voltage.
            CN1803 Pin 1 Inverter ON-OFF Voltage
            • tieny
              • Feb 2012
              • 478
              The large capacitor measures 163.3V when on standby and oscillated between 380 and 387V. On CN801 pin 1 (power on/off measures 0V both standby and when on. CN1803 where it says VCC12V measures 12.22V. I cant seem to open the link to the schematic.
              • tieny
                • Feb 2012
                • 478
                Oops i meant to stay the large capacitor oscillates between 380-387V when the TV is on. On CN801 pin 1 (power on/off) it measures 0.04V on standby and 2.79V when turned on. On pin 1 of CN1803 (Inverter on/off) I measured 0V when on standby and 5.2V when the TV is turned on. (Ignore what I said last post that was the wrong measurements) And I got the schematic to open =)
                • tieny
                  • Feb 2012
                  • 478
                  Ok so i decided to disassemble it futher to check if it really has a bad panel or not before I waste my time trying to repair it.
                  I removed the LCD screen and shined my own light underneath it and this is what I see.
                  There are vertical lines across the entire screen however there are spots where it is just is black. The pattern doesn't seem to be even, since though some colored line strips are larger than others. Also whenever I turn off and turn it back on sometimes the pattern would change. (See the photos)
                  Also touching and pressing on the tab bonds doesn't seem to affect the picture in any way. I also tried pressing the menu and volume buttons on the side of the TV but also there was no change in the patterns
                  Also During the beginning as the TV turned on I also notice some horizontal lines within the vertical but it fades away after a couple of seconds (see the video link)
                  http://www.youtube.com/watch?v=TfsdY...ature=youtu.be
                  Would this be a bad panel? It doesn't look like the same problem Ive seen where the vertical lines just go across the entire screen.
                    You are getting correct control voltages and the PFC is working. As far as the panel concern, you need to see if the T-CON board is getting the voltage to it, check that on the surface mounted fues (both ends of the fuse) on the T-CON board.
                    • tieny
                      • Feb 2012
                      • 478
                      I'm getting a reading of 13.1V on both ends of the fuse F1
                        I had a vaguely similar problem with a Samsung - random vertical lines. However, I DID have a backlight. A voltage regulator on the t-con had failed.
                          It sounds like you have TWO problems, one in the inverter circuits, tow is either the T-CON or the main board (more likely to be the T-CON).
                          • tieny
                            • Feb 2012
                            • 478
                            Hmm I'm guessing I should solve the tcon problem first to make sure the picture is ok. So I should start by testing all the voltage regulators on the tcon board first?
                              That would be a good start...
                              • tieny
                                • Feb 2012
                                • 478
                                Alright! so good news, I found a capacitor that was broken off the tcon, I was able to solder the pins back on in a werid way but it works. Turned on the TV and now I can see OSD menu and the white static when on the ANT input =) (except with no backlight).
                                Okay so next step is to figure out what is wrong with the inverter circuits.
                                When you say inverter circuits you mean the problem would be in the board of power supply/inverter combination? Would the problem be that high voltage transformer on the bottom left isn't outputing the voltages to the balancer board? I'll check diodes, but not sure how to check the mosfets
                                  You need to check the MOSFET'S that drive the high voltage transformer first. Did you down load the diagram of the board?
                                  • tieny
                                    • Feb 2012
                                    • 478
                                    Yeah I was able to download it. How would you test a mosfet.
                                      Check the fuse F1801 which is for the inverter output drive circuits.
                                      It has 3 pins, so just mark the pins as 1, 2, 3.
                                      Since we are looking for short (low resistance reading), just set the meter 200-Ohm scale and just measure:
                                      1 & 2
                                      1 & 3
                                      2 & 3
                                      • tieny
                                        • Feb 2012
                                        • 478
                                        I'm guessing its the two mosfets right next to the transformer Q1801 and Q1802. Putting my probes on the suggested pins all read above the range of 200 ohms EXCEPT on Q1801 probe on pin 1 and 3 gives a measurement of 8.8 ohms. Suspect a short? (these measurements were taken in circuit) Both mosfets are labeled K3568 8:2
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
                                        • pni
                                          LG 49uf695v vertical coloured lines
                                          by pni
                                          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                                          11-14-2025, 03:15 AM
                                        • x_orange90_x
                                          Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                          by x_orange90_x
                                          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                          09-04-2023, 12:09 PM
