Sony KDL-46XBR4 13 blinks
  • tieny
    • Feb 2012
    • 478
    There is a KDL-46XBR4 sony lcd tv for sale for 100$ and I was wondering if it is worth the fix. The problem is that the tv does not turn on and the standby LED flashes 13 times. From the service manual it says the problem is caused by the "BALANCER" What does that mean exactly?
    Would the problem be within the CCFL lamps? and I would need to replace them? (The guy also said he would also give me another free cracked screen sony 46" TV (different model but same size screen) for me to use the CCFL from. Would this solution work?)
    Or is the problem with the inverter board and I should replace the inverter board. (looking online the inverter board is pretty cheap (10-20$ range)
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Sony KDL-46XBR4 13 blinks
    this auction has finished this is supposed to be a balncer board?
    http://www.ebay.com/itm/SONY-KDL46XB...-/250889322874
    • Mt.Man
      • 53
      Balancer board is the inverter boards on the LCD panel, not the DF2 or DF3 power boards the drive the panel.
      • tieny
        • Feb 2012
        • 478
        Is the post on ebay an inverter board? It doesnt look one to me.
        • vinceroger69
          • Mar 2012
          • 6714
          i was not sure mt.man says this is a power board? that drives the panel. i was just searching for balancer issues as i have never heard of it and came up with this ebay link? so not sure probably a incorrectly worded ebay item?
            It generates the HV (3kV or so) and distributes it to the ballast/balancer board - which ensures each bulb gets the same current.
            It is usually built into the PSU. I guess the reason they may have separated it is so that they can make one using an LED screen which requires around 90 to 300V for series LED strings. Odd design choice though as it increases the cost.
            • vinceroger69
              • Mar 2012
              • 6714
              tom66 get you know its easy to understand when you explaine it like that
              also these tvs was recalled?
              http://hsindependance.hubpages.com/h...l46w135-recall
                That's probably due to the tab bonding problem affecting lots of 46" Sony TVs.
                • tieny
                  • Feb 2012
                  • 478
                  So would replacinh that board from that ebay link solve the problem?
                    I would not bet on it.
                    • tieny
                      • Feb 2012
                      • 478
                      My question hasnt been answered yet. Would the problem be with the ccfl lamps or a bad invertet board?
                        Probably CCFL or balancer. Bad inverter board is rare for Sony. But what do you expect us to guess without tests, measurements, analysis? We are not magic, part of the knack about TV repair is taking a chance on repairing a set. If you always do what you know you will not learn any new stuff!
                        • tieny
                          • Feb 2012
                          • 478
                          Well just bought the set itself, it actually can turn on with the menu and everything however itll turn back off to standby and with the blinking light. I'll open it up tomorrow and see what I have to work with =)
                          I was reading online and found this:
                          http://www.justanswer.com/tv-repair/...ely-gives.html
                          Saying its always the backlight lamp needing replacing. Any opinions on their knowledge?
                          • tieny
                            • Feb 2012
                            • 478
                            So just opened it up, and heres whats in it. I don't even know where to start! There are boards that I don't recognize. Which would be the balancer board? I'm about to disassemble everything down to the CCFL lamps and check those. I just learned that the "balancer" board is just the typical inverter board. Sony just calls it a balancer.
                            Been reading about the 13 light blink error online a bit and they all would say to replace the LCD panel itself if replacing the inverter (balancer) board does not work. However reading other articles, they say it is most likely a damaged CCFL lamp and the entire LCD panel should be replaced. No where mentions replacing the CCFL inside the LCD panel. Unless its not possible because there is actually no way to get into the CCFL lamps but I have not confirmed this. My guess is there is a damaged CCFL lamp.
                            My question is, Is it possible to replace a CCFL lamp within the LCD panel? If its possible I don't find much information about it online, is it very difficult to replace a CCFL lamp?
                              Left and right blue boards.
                              • tieny
                                • Feb 2012
                                • 478
                                Oh I just edited my last post if you hadn't noticed. is replacing a CCFL lamp possible?
                                  Yes, you can disassemble the panel, but have to be very careful not to break it.
                                  Maybe this is applicable? Similar design with Samsung TV.
                                  http://www.youtube.com/watch?v=oE6K4xBVweA&feature=plcp
                                  • tieny
                                    • Feb 2012
                                    • 478
                                    Hmm nice find, I just recently sold that same Samsung after a a simple capacitor fix. Saw the same tv that would power on but shut off, the guy said it was a backlight problem, it's still been on Craigslist for a week for 100$ i might just pick it up now seeing that fix
                                    Anyway the test points seem to be different where would I put the probes to check for ac?
                                    • tieny
                                      • Feb 2012
                                      • 478
                                      I was measuring all the resistances of each transformer. All measured around 2400 ohms but the one i circled measured 0.04 ohms, however its a different transformer than all the others. The one I circled is labeled: 886-Y7E3, and all the other transformers are labeled 910-Y7E5. Would the circled transformer be short circuited? I measured out of circuit and got the same readings as well.
                                        That is a current transformer, different to the rest. It measures the power consumption of the backlight tubes as a whole. Not sure why, maybe some kind of lifetime balancing to increase the current as the bulbs get dimmer over time. Either way, it is unlikely to be the fault. I would expect 0 ohms.
                                        • caseyjay_48
                                          Sony KDL-46BX450 Inverter Troubleshoot Logic
                                          by caseyjay_48
                                          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                          09-23-2022, 08:08 PM
                                        • AK_777
                                          Sony KD-65A1 Repair – 4 Red Blinks Error
                                          by AK_777
                                          Hi everyone!
                                          I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                          Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                          02-20-2025, 04:15 PM
                                        • jchon
                                          Sony A1e 5-blinks help
                                          by jchon
                                          Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                          I found the service manual, which was critical to know where to probe.
                                          https://www.manualslib.com/manual/20...1e-Series.html
                                          With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                          Unfortunately the 5-blinks...
                                          06-28-2023, 11:52 AM
                                        • Nicktronic
                                          Sony XBR-65X850D 2 Red Blinks
                                          by Nicktronic
                                          I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
                                          Any Sony experts out there that can help??...
                                          11-19-2023, 06:51 AM
                                        • dumbdd
                                          Sony 75X9400E TV.. 5 Red blinks
                                          by dumbdd
                                          I was using this TV for 5 years before it stopped working. I like this TV and would love to fix it myself.*
                                          When I press the power button, the white led comes on (sony calls the module smart core) and then it switches over to 5 red blinks. No screen, no backlight, no relay click, nothing. I have disassembled the tv and found the service manual for 75x940e online. The manual suggests a faulty power board, TCON or the panel.**
                                          The standby pin is at 3.3V. Fuses on the mainboard and TCON are fine. Caps on TCON also seem to be fine. When I turn on the tv the white led...
                                          07-01-2023, 08:54 PM
