Testing Capacitors?
  • allsmith
    • Aug 2012
    • 179
    Testing Capacitors?
    I have a question about testing capacitors.
    Is there any way to test caps out of circuit just for trouble shooting purposes.
    Is there a way to just test if they are good enough to do there job and make the tv work,then i will replace them with high quality new ones once i know the tv works good with a good lcd picture.
    Now is a ESR meter the only way to make a test like that on a cap,or is there a shade tree machanic way to do it?
    I have seen a youtube video of a guy that tested them by running a audio signal from a stereo through them hooked to a speaker.
    I have tried this on obvious bad caps that are completely vented and yeah the audio signal wont go through.(where the audio signal will pass through good caps)
    I have also tried charging them with two AA batteries to see if they will take the 3 volt charge.
    Problem with the audio test is i have had some that will pass a audio signal but they wont take a charge from the two AA batteries,so the audio test is not very acurate.
    Is charging them with a battery the only back yard way to test or is there any other way to test them without a ESR meter?
    The only other way i have heard of is to use a analog meter on ohm test and the needle will jump and increase as the meter is charging the cap.
    If a ESR meter is the only way to accurately test if the cap will work and there not too expensive i would like to get one.
    Any info would be appreciated!
    Thanks, Lonny
  • EvilGhozt
    • Aug 2012
    • 6
    • Sweden
    Re: Testing Capacitors?
    Connect 555 timer running in 100khz and some few mV, then use a oscilioscope to look at the signal. You should then see if the capacistor is bad or not. the good thing is that you dont need to desolder the cap for testing, since the low voltage...
    • shorteddiode
      • 221
      How about the old octopus test rig, will that work in circuit?
        DIY ESR, just Google. For examples.
        • allsmith
          • Aug 2012
          • 179
          Thanks bud,i did a quick google on diy esr.
          Looks a bit too copmlicated for me,but i'll research some more and see if i can understand it.
          Do you have a recomendation of a decent,but affordable store bought ESR meter?
          It wouldnt have to test in circuit ,but that would be nice.
          Thank you.
          • quickname
            Cyberpower 1500AVR UPS repair
            by quickname
            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
            I decided to verify that the batteries were...
            11-12-2023, 09:57 AM
            Modification done to a EBC-A40L 5volts Battery Capacity Tester 40A for less noise when charging / discharging cycles
            When I first turned this battery testing machine the fan for the switching power supply was a little bit noisy but once I recapped the switching power supply board it quiet down considerably then I put a temperature controlled fan that does the mosfets control board was really noisy but now that it is cooled with temperature controlled fan that sensor was moved from the fan to the heat sink so now that the fan is controlled this way the fan runs according to the temperature of the heat sink
            This switching power supply was really fun to recap the quality of the board was very good...
            02-25-2024, 08:55 PM
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
          • ten-d
            Nippon Chemi-con 100uf 100v BP electrolytic cap
            by ten-d
            Hi all!
            I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
            01-30-2024, 05:18 PM
          • chth96
            by chth96
            03-09-2024, 10:03 PM
