Sony KDL-37m400 Relay Click...... Nothing
  • avaktech
    • Jan 2012
    • 68
    • US
    I have a Sony 37m400 that was apparently getting wet. Person that asked me to look at it said it just died. It is obvious by looking at the main board and water stains running down the front that it had gotten wet several times over a long period of time.
    Only signs of life are a clicking relay when attempting to power on and a standy light. I found a diode that's questionable, and I also would like to know what is at location Z1 just north of the main fuse on the power board, it tests open whatever it is.
    The questionable diode is at D950
  • selldoor
    Slow Learner
    • 7870
    Re: Sony KDL-37m400 Relay Click...... Nothing
    Best not to use a tv in the shower!
    Are we supposed to be able to see a Z1 on the picture If you mean the black rectangular box with white writing? it looks like a relay - try googling the part number.
    Why is the diode questionable? Use diode test on your meter and post result.
    What happened to this:Re: 42" Spectrincq no power.
    It would be good to update the thread.
    • avaktech
      • Jan 2012
      • 68
      • US
      Diode test is 1070 one way and 230 the other,
      Z1 is just above and left of the relay it looks like a ceramic disc capacitor but I don't think it is, guessing it has to do with surge protection.
      I'll update the other thread, sorry about that. Just gave up, in over my head I guess.
      • retiredcaps
        • Apr 2010
        • 9271
        http://en.wikipedia.org/wiki/Electro...e_designations
        Z = Zener diode
        --- begin sig file ---
        --- end sig file ---
        • vinceroger69
          • Mar 2012
          • 6714
          could it be a thermistor?
          • retiredcaps
            • Apr 2010
            • 9271
            That is a good diode.
            I still don't know where it is or what it looks like, but see my other post. A clear focused picture would help where I can read and see the pcb designation.
            • selldoor
              Slow Learner
              • 7870
              Yes I thought a Z designation would be a Zener but both the green disk and the orange disk with a sleeve on look like Thermistors.
              If you are talking about the orange disk with the sleeve on take the sleeve off and see if there are any part numbers on it.
              • avaktech
                • Jan 2012
                • 68
                • US
                tvr 14621 i guess its a varistor. I'm guessing its normally open, is this correct?
                Where do I go from here?
                • selldoor
                  Slow Learner
                  • 7870
                  Can you get some decent pics as retiredcaps asked. - he wont ask again.
                  Is the orange blob near the connector on the right hand side a fuse?
                  There are also fuses on the main board - I cant see them but can see the labeling
                  • avaktech
                    • Jan 2012
                    • 68
                    • US
                    Ok, put it in broad daylight to get some pics. I tested some voltages, the standy was right on at 3.3v the unreg13v was very low .6v and reg12 was similar at .9v. don't know what that means but I thought I'd provide that info.
                    • selldoor
                      Slow Learner
                      • 7870
                      Thats much better as long as we dont need to see the part of the main board in the shadow. We aso need the backs of the boards.
                      Still cant see the fuses - can you- The label says F400 or 4000 5A24V at the bottom left under the wires.
                      Another is on the left halfway up F7000? 3.15A 24V
                      • avaktech
                        • Jan 2012
                        • 68
                        • US
                        Ok, I unplugged the tcon and got a little life out of the inverter board, the backlight would at least flash little. I heard a little whining, tried a few more times and it stayed on a little longer each time, but only briefly.
                        • avaktech
                          • Jan 2012
                          • 68
                          • US
                          You can see plenty oh crud in several spots. Do SMD fuses leave something behind when they blow? I can't really find them.
                          • avaktech
                            • Jan 2012
                            • 68
                            • US
                            Selldoor, I cant really figure out where the heck the fuses are on the front the arrow points right for the connector.
                              There's a lot of corrosion on some of those leads on the board. It must have got really wet. How did that happen, did owner notice water?? If the damage is too severe, you will likely need a new main board, just hope the others are okay.
                              • selldoor
                                Slow Learner
                                • 7870
                                Ok - maybe they use different fuses depending on what application the board is for but I think it likely that the item I have marked is a fuse
                                does it have a letter or number on it.
                                • avaktech
                                  • Jan 2012
                                  • 68
                                  • US
                                  The TV was in the basment and he claims the water traveled in through the cable and dripped down on the tv. Must have been that way a while cause it is pretty corroded. I am not ready to give up on it so any troubleshooting help I can get is very appreciated. There is a transistor that has a kind of ooze look to it. How would I go about testing it.
                                    I would say clean up all the pins with a scourer then resolder anything which looks corroded. The LCD may also have been damaged by the water, someone else on this forum had a problem with water damage.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      Man - its a miracle it switches on!! I missed these pics when I went for the fuse.Did think about water in via the cable as tuner box it goes into looked rusty.
                                      We are going to need more members to look at this as I am not sure how to proceed.
                                      First thing is to get clear close pics as possible of each corroded area.
                                      Then try and clean the corrosion off - my first instincts would be WD40 and a fine
                                      toothbrush but I dont know about the wd40 - perhaps IPA would be better?
                                      Once it is clean then retake the photos - you need the first ones in case any bits drop off!! We can try but suspect a replacement board will be the answer.
                                      What are the other boards like underneath.
                                      EDIT
                                      Tom beat me to it
                                      • avaktech
                                        • Jan 2012
                                        • 68
                                        • US
                                        Ok, cleaned up everything I could find that looked affected and it not will turn on with tcon plugged in and even gives me a BRAVIA logo but turns off in about 3 seconds every time.
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • InsertCoin
                                          Relay Satronic MMI 810.1 bad diode & Transistor
                                          by InsertCoin
                                          Hello and happy new year ,
                                          my Analog Combustion Machine Honeywell gone bad and I don't know what type of diode is utilized.
                                          There is no mark around the body of the diode. The Schematics are general referred only, without any electronics components and values.
                                          The two contacts (2),(5) of the Relay Coil need 48 Volts DC to begin operating. Between these two contacts in series is the bad diode and near of contact (5) is the bad pnp (bc856b) Transistor that can be easily replaced.
                                          I have made a diagram of the PCB and some measurements along some...
                                          01-16-2024, 05:47 AM
                                        • Tnmg
                                          Sony XBR-65X850E power supply board diode replacement
                                          by Tnmg
                                          I have a Sony XBR-65X850E that when plugged in buzzes for a few seconds about 5-7 times but the screen never comes on. It looks like one of the four diodes on the main power supply board are bad. I'd like to replace all four at the same time. The diodes that are bad are the D750, D751, D752 and D753. The S750 looks discolored and fails the diode test on the board. It hasn't been removed from the board yet for testing.
                                          Are all four of these the same diode? I saw a video that called the discolored one a Schottky 5150 diode. How can I make sure to get the right diodes for these?...
                                          07-01-2022, 04:54 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
