Sharp LC-52D64U-Negative picture
  • buuhaahaa
    • Aug 2012
    • 22
    • US
    Re: Sharp LC-52D64U-Negative picture
    Just about to put this TV out for parts but before I do I took some voltage readings and maybe someone will notice what's wrong with my TV. (Hope my Volt meter is working right LOL)
    DC Voltage readings
    Main Board
    (12) 14.5
    (11) 14.5
    (10) 0.0
    (9) 0.0
    (8) 4.96
    (7) 0.0
    (6) 0.0
    (5) 2.98
    (4) 2.64
    (3) empty
    (2) empty
    (1) empty
    T-Con
    (4) 0.0
    (3) 0.0
    (2) 0.33
    (1) 0.32
    Inverter(left)
    (#7-#12) 11.06
    (#1-#6) 0.0
    Inverter(right)
    (#1-#6) 0.0
    (#7-#12) 11.06
    Terminal Board
    (1) 0.0
    (2) 14.5
    (3) 0.0
    (4) 0.0
    (5) 14.53
    (6) 14.53
    • drpj23
      • May 2012
      • 528
      Is there a legend by the connectors? The T-CON one doesn't look right.
      • buuhaahaa
        • Aug 2012
        • 22
        • US
        What do you mean by "legend"? I'm no "Tech" I generally work on cars and stuff. Here's the pic of the T-Con and the connector I tested.
        • tibimakai
          • Jan 2012
          • 3680
          Voltages printed on the board(if they are there), they match up with the measured ones?
          • buuhaahaa
            • Aug 2012
            • 22
            • US
            no voltage "legend" on the boards
            • kevinm34232
              • May 2012
              • 1884
              Interesting that the picture would be there but negative, it would seem main board may be sending wrong signals to T-Con board, especially if T-Con board didn't fix it...
              What would it take to cause a negative image down to the pixel in the LCD panel compared to a normal image? Is it as simple as the on/off pixels being reversed?
              • drpj23
                • May 2012
                • 528
                Oh I meant to ask if the monochrome setting made it seem the black was where the white was supposed to be and vice versa? Or in other words, backwards? (Just curious lol)
                Here is something you may want to glance at (as well as other ppl)
                http://www.eserviceinfo.com/repair_tips.php?pagetogo=1 (type in negative under problem) (it won' let me have a link directly to it for some reason)
                • drpj23
                  • May 2012
                  • 528
                  Maybe you have a power supply prob. The flashing lights mentioned earlier was an error code. Sounds like a 3.3v detection error
                  Pg 62 is error codes
                  http://www.mediafire.com/view/?ire75cd8jtpr6g2
                  Ok your pic of the back of the tv is very hard to decipher what connector is to what but note which connector the T-CON ones go to and either let me know or you can look at the back of the SM and go through the schematics and find the outputs
                  It should look like P2601
                  And the power supply does have a legend by the connector but are more or less ambiguous from what I can see.
                  • buuhaahaa
                    • Aug 2012
                    • 22
                    • US
                    #29
                    @drpj23
                    "Here is something you may want to glance at (as well as other ppl)
                    http://www.eserviceinfo.com/repair_tips.php?pagetogo=1"
                    Search results.....
                    Found: 0
                    Mono chrome didn't do much but remove the color.
                    There's a TV that I was messing with(an older Sony Bravia LCD) and it actually has a setting where it would change the picture to a "negative" looking image which looks like what my TV is stuck with. It's a setting that says something like "Invert" which is set either off or on. Next time I'm around it I'll take some photos.
                    • drpj23
                      • May 2012
                      • 528
                      whoops haha I guess I should check my links. Ok well click on it and type in negative under problems. A couple said eeprom but since you changed the main, I would figure something with p/s or voltage distribution thereof or by some odd chance the lvds cable.
                      • kevinm34232
                        • May 2012
                        • 1884
                        Has there been a resolution to this yet? I have someone with a Toshiba with the same negative image, which on a PC you can create by inverting the colors, it would seem to be a main board problem but trying to understand why that could happen??
                        • MikeRWK
                          Sharp LC-32D40U Negative picture unless the contrast is almost 0
                          by MikeRWK
                          This only affects the picture but not the tv menus. Selecting any of the default picture settings gives a negative picture but turning the contrast down to 5 'fixes' it but then the tv is too dim which is hard to tell in the pictures.
                          This tv has a main board, scaler board, and a tcon.
                          I tore it down so I could probe the tcon which is nicely labelled. I've also included a pic of it.Here are the voltages I got:
                          VGH 32V
                          VGL -6V
                          GAM1 14.6V
                          GAM18 185mV
                          VLS 14.67V
                          3V 3.01V
                          RESET 2.95V
                          TCLK 0V
                          SCC_VDD...
                          01-30-2021, 05:21 PM
                        • JJAAMM
                          by JJAAMM
                          Problem
                          07-06-2023, 06:01 AM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • BeeShadow
                          Sharp lc-70le755u flickering picture/backlight
                          by BeeShadow
                          Hey everyone! I inherited a "free" Sharp lc-70le755u with a strange picture issue. To try to explain, the picture flickers before what I think is a power saving mode kicks in and reduces the back light. I took a short video and uploaded it here:
                          https://imgur.com/NAou7aP
                          I'm thinking it could be the TCon board, but possibly the panel. Thought it might be worth it to post here and see if anyone has a better idea before I try throwing parts at it. If its the panel (which I hope its not), then I won't bother trying to fix it.
                          07-01-2021, 08:32 PM
                        • Mgiffune
                          by Mgiffune
                          06-09-2024, 10:28 AM
