Sharp lc-70le755u flickering picture/backlight
  • BeeShadow
    • Jul 2021
    Hey everyone! I inherited a "free" Sharp lc-70le755u with a strange picture issue. To try to explain, the picture flickers before what I think is a power saving mode kicks in and reduces the back light. I took a short video and uploaded it here:
    https://imgur.com/NAou7aP
    I'm thinking it could be the TCon board, but possibly the panel. Thought it might be worth it to post here and see if anyone has a better idea before I try throwing parts at it. If its the panel (which I hope its not), then I won't bother trying to fix it.
  • neilc6
    • Nov 2015
    • 1550
    Re: Sharp lc-70le755u flickering picture/backlight
    Flickering image is a bad panel. Doesn't look like the backlight is flickering though it will be easier to tell with a proper video image. You can try blocking pins on the bad side or as a last resort, rip off the side tabs or side boards on the bad side once you identify which side is good.
    https://techhometravel.com/repair-of...lines-on-a-tv/
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • TheForgottenKing
      Sharp LC70LE755U - Intermittent backlight flickering and loss of sound.
      by TheForgottenKing
      Hello everyone, first time posting here so I hope I'm doing everything right.
      I just came into possession of a Sharp Aquos LC70LE755U. It was free for me, so with the stand and power cable I only have $30 in this. As such, I'm trying to repair it for cheap.
      It works most of the time perfectly, except for an issue with what I think is the power supply. After anywhere from 10-30 minutes of usage, the screen backlight will flicker briefly, and the sound will completely stop working. The sound doesn't start working until I unplug the TV, wait a few seconds, and plug it...
      04-18-2021, 10:40 AM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
