LG 26LG3000 white screen problem
  • manoftheyear
    • Nov 2010
    • 39
    • Europe
    Re: LG 26LG3000 white screen problem
    Thanks. Will try and find one from some junk boards.
    There's still the low voltage on t-con main rail problem, probably gonna need the AO4449 mosfet replaced.
    • mlwray
      • Oct 2016
      • England
      Hi
      Im having a similar problem, white screen of death.
      I have measured the voltages to the T Con and they seem correct.
      I have taken resistance measurements with respect to ground:
      VDD = 34.7
      VDA = 2.39K
      VGHP = 1.4M falling
      VGH = 600K rising
      DP1 = measured ok using multimeter diode test function
      DP3 = 39.4 one side and 0 ohms the other
      CP42= 34.9
      CP35 = 34.9
      CP36 = 34.9
      I am suspecting it may be DP3 but do not want to jump to conclusions without consulting the experts first.
      Any help on this matter would be much appreciated.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Plug power and signal to your monitor and measure some voltages on the tcon, at the points where you measured resistance.
        A working TV? How boring!
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • ahmarzo
          Asus la-7322p white screen problem
          by ahmarzo
          My asus laptop motherboard la-7322p has white screen. Have tried new screen but same problem.lcd vdd is 1.8v when i removed the mosfet an short 3vs with lcdvdd white screen is solved but no data on screen...
          07-15-2022, 07:52 AM
        • domu
          Viewsonic VS16217 strange problem - white flickering screen on power up
          by domu
          As per subject, on power up display shows no image, but white
          flickering screen. Strangely, it only happen after power was lost
          when it was on. After power returns - white screen only, but if
          disconnect power for 12-24 hrs, and connect then again monitor
          works normally.
          Any clues how to go about it would be greatly appreciated.
          07-18-2023, 04:57 AM
        • mmccomputer
          problem with replacing lcd screen
          by mmccomputer
          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
          If anyone has any information on the subject...
          12-15-2024, 03:44 PM
        • maxim2511
          LG 55EC930V OLED - swich on swich of no screen
          by maxim2511
          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
          Then I get an idea to take it apart and clean boards from dust.
          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
          05-14-2021, 02:21 AM
