How to test a voltage regulator
  • retiredcaps
    • Apr 2010
    • 9271
    Regulars will hopefully appreciate this new guide I just wrote so you don't have to explain it over and over again.
    https://www.badcaps.net/forum/showthread.php?p=261329
    PS. Same thread also posted on Troubleshooting Computer Displays as some regulars read one, but not the other.
    --- begin sig file ---
    --- end sig file ---
    Re: How to test a voltage regulator
    Fantastic guide - will be very useful for newbies.
    Only one comment I'd make. The IC at the top is an LM2576T - a switching regulator, not LDO. Testing its output should be done at one end of the inductor - the "680 JYE" component.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      And Me! - Thanks retiredcaps - got it bookmarked next to "2StoB"
      • mariushm
        • May 2011
        • 3799
        Uhm... you have there an example of a bad voltage regulator which should output 1.8v but it outputs 3.3v.
        Yes, theoretically it's bad but generally even the fixed output regulators can be adjusted to other voltages by adding feedback resistors to the ground pin.
        It should almost never happen in real world as these 1117 regulators cost pennies at volume purchases but especially when their output is a popular voltage like 2.5v or 3.3v, one should consider the manufacturer may have used the same part with adjusting resistors on it.
        Maybe change the example to say instead of 3.3v something else, let's say 1.2v
        ...I'll second tom66 to say some regulators are switching regulators, which need an inductor and a diode to work: people should check the diode and the inductor.
        Also, some switching regulators need to have the capacitor on the output with a somewhat higher ESR... somewhere around 0.4-1 ohm.
        Some people get trained to think anything over 0.3 or so is bad capacitors but that's not always the case and it can affect the regulator's stability if such low ESR capacitors are used. Don't rush into replacing capacitors unless you tested everything and you think they might cause problems.
        • woaimi
          • Sep 2005
          • 94
          • US
          thank you, that helps newbie like me to gain some real life experiences.
            Retiredcaps, glad you make the write up for the LDO. You may want to add about the two resistors used for setting up the output voltage of the adjustable LDO (that is one way to tell if it is fixed or adjustable LDO), there is formula for it.
              ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
              3+1 Voltage Regulator for IMVP-7/VR12 CPUs
              Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
              core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
              configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
              serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
              Based on Intersil's Robust Ripple Regulator...
              11-05-2024, 03:24 PM
            • playit
              diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
              by playit
              hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
              and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
              for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
              02-26-2025, 05:39 AM
            • chth96
              How Can I test PWM DM0365R?
              by chth96
              Hello
              I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
              So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
              I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
              I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
              06-18-2025, 04:14 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • artvandalai
              Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
              by artvandalai
              This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
              The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
              11-05-2024, 07:38 AM
