Element ELCHS261 Doesn't Power on
+ More Options
Posts
  • Gadjet
    • Aug 2012
    • 248
    I Have a Element ELCHS261 that has a red power light when plugged in, but nothing when you press the power button. I've tried using a remote as well, from what I can tell there aren't any bulging caps or leaks.
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Element ELCHS261 Doesn't Power on
    Take detailed pictures of the inside boards and post them here first.
    • Gadjet
      • Aug 2012
      • 248
      Ok I've taken pictures of both the boards the Tuner and the PSB/Inverter.
      • Gadjet
        • Aug 2012
        • 248
        Here are a few more angles
        • cadillacman
          • Feb 2011
          • 524
          oh krap its one of those all in one supplies...
          did you ever have any luck with this?? Im looking to buy one, perhaps i should avoid it now that i know of one without a caps issue.
          • drpj23
            • May 2012
            • 528
            Sounds like a main board issue.
            • kevinm34232
              • May 2012
              • 1884
              Briefly looked for a service manual with no luck. But check for your voltages at P1 on the main board, there's a pin labeled on/off maybe it's not getting the signal, check for voltage there when pressing power...
                Since this combo board has PFC Voltage booster circuit, you need to check the DC voltage on that large black DC filter cap in the primary (hot side) of the power supply. Check it with the TV plugged in but do not hit the power switch, the DC on that cap should be about 165VDC, then hit the power switch, the DC voltage on that cap should rise up to around 390~400VDC, if it does, that means the main power PS_ON signal is OK. If it does not go up then it may mean that PS_ON is not present or the PFC circuit is bad.
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  The power board also mentions that there are two expected output voltages - 5VDC and 12VDC. Read all of the voltages on the output connector. Some of these will not be there until the unit is turned on. There should be a 5VSB and some others. Use the GND on the output connector when taking the readings.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                    09-06-2024, 05:59 AM
                    HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                    This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-12-2024, 02:15 PM
