need t-con for sony klv-40w450a
  • exsonyexpert
    • Feb 2012
    • 20
    any one can help me where can i buy this t-con
    Re: need t-con for sony klv-40w450a
    Part # on the T-con? Pictures? Anything?
    • selldoor
      Slow Learner
      • 7870
      Originally had a link in his post but did not leave a gap
      http://flattvparts.co.uk/index.php?m...oducts_id=1093
      Please update your profile with country and mains voltage
      • exsonyexpert
        • Feb 2012
        • 20
        help plz need it asap
          This model is not sold in USA, so what country are you in.
          Since SONY uses more than one maufacturers to supply the LCD panel, do you know if it is using SONY/SAMSUNG panel, AUOPTO panel, CHI-MEI panel?
          • exsonyexpert
            • Feb 2012
            • 20
            that is philppines model they use s-lcd
              So Asia/Pacific model, what is model of the LCD panel (e.g. LTA40...)
              • selldoor
                Slow Learner
                • 7870
                What is wrong with the one you have got - put some pictures up and we can look at it. Have you tested the fuse?
                • exsonyexpert
                  • Feb 2012
                  • 20
                  yah A/P i already inquire the parts to oriss/ap but it supply end
                  hers the panel model LTY[Z]400HC02001
                  • exsonyexpert
                    • Feb 2012
                    • 20
                    hi sir selldoor the defect is white screen i already test all voltage/resistance/leakage etc.. its possible have defect on gamma control i.c but that i.c is much hard to find.. unlike other gamma i.c like as15 as04 as34 already avail in black market.. so i trying to look for hole control mt board shortly t-con
                      Fuse good? Supply 12V or 5V to T-con good?
                      • exsonyexpert
                        • Feb 2012
                        • 20
                        yis sir all suply is good even the output of dc to dc converter i meashured it using scope
                          Check good boost voltage... typically 15V.
                          Check good CORE voltage for T-con IC... typically 1.2V to 2.5V.
                          I see at least six LDOs on that board; all good?
                          Check the crystal and see if it's oscillating.
                          • exsonyexpert
                            • Feb 2012
                            • 20
                            sir tom66 do u have idea where can i buy that t-con? any website or parts supplier
                              No idea, sorry.
                              • selldoor
                                Slow Learner
                                • 7870
                                Just to check - you did clean and reseat the connectors from the tcon to the panel? - have you checked out the cables- they can become brittle and broken due to age and heat. Perhaps update your profile with your country in case there are any members in your country who can assist with finding one.
                                • Daren87
                                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                  by Daren87
                                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                  08-13-2023, 03:25 PM
                                • iglitare
                                  by iglitare
                                  09-04-2025, 07:13 AM
                                • kca
                                  by kca
                                  Hello all ~
                                  08-31-2025, 06:38 AM
                                • rimwall
                                  Sony KD-65x7500D - double image - Tcon or Panel?
                                  by rimwall
                                  This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                  I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                  Today, 02:09 AM
                                • thelankanguy
                                  Sony KD-55X9000F TCON Issue
                                  by thelankanguy
                                  The TV shows a black screen with no image.
                                  TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                  Later both ribbons were disconnected and TCON voltages were tested.
                                  12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                  There is also a short to ground in this circled inductor.
                                  Is this a TCON issue or something else ?...
                                  12-13-2024, 12:27 AM
