Vizio VS420LF1A Screen/backlight goes off after awhile
  • Blackwolf
    • Mar 2012
    • 18
    I have a Vizio VS420LF1A that i had previously posted about here in this forum.
    The back light and lcd was not coming on at all, yet the Vizio logo at the bottom was turning white. After testing several components i just gave up and purchased a new (used) PSU off ebay. I connected it and the TV worked great for 2 months or so. Unfortunately now Im having a problem where the tv will come on and work fine, but then the back light and lcd will just turn off (vizio logo still white) sometimes after several hours of use, or sometimes after just a few min. If i turn off the tv and let it sit for a few min after this happens, it will work for awhile, sometimes hours, sometimes just mins. Yesterday, the tv was on for several hours and worked perfectly, then towards the end of the night, it started doing it again. Im a bit puzzled as to why sometimes it works fine, then other times it exhibits this issue. I checked for obvious stuff like blown/bulging caps on the psu, but all looks well. I have pics that i took previously for the other thread available here
    Re: Vizio VS420LF1A Screen/backlight goes off after awhile
    Try unplugging the button panel on the TV.
    • Blackwolf
      • Mar 2012
      • 18
      Ok i will try that, but would that cause the backlight/lcd to turn off but leaving the vizio logo white? (not orange like when its in standby)
        Probably not - although maybe if the button gets stuck the TV does odd things like that?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Does the sound stay on? Have you checked to see if there is still a very dark picture on the screen when it appears to have gone off - try with a flashlight at different angles.
          • Blackwolf
            • Mar 2012
            • 18
            The sound does stay on, and i do see the picture on the LCD when i look closely at it with a flash light, so it must be the back light. I turned it on today and it stayed on for several hours with out going out but then it happened. Is it bad inverter or psu issue perhaps? Why does it sometimes work for hours then other times only a few min? Maybe theres a short or something?
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Please post clear pictures without flash of the inverter board and Tcon.
              • Blackwolf
                • Mar 2012
                • 18
                Some pics i took before are available here
                https://www.badcaps.net/forum/showpo...33&postcount=3
                These are the only 2 boards i see, is there another i may be missing somewhere?
                • killian6pk
                  • Apr 2010
                  • 502
                  There should be one and possibly two inverter boards probably under a metal cover one on each side of the tv. All of the backlight wires will be plugged into them.
                  Have you ever stopped to think and then forget to start thinking again?
                  As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
                  • killian6pk
                    • Apr 2010
                    • 502
                    disregard my previous message looks like your backlights are run off the power board so you want have any inverter boards. Not sure how that is being done though with just two connectors.
                    • spice_disc
                      Vizio TV M50-C1 reboot cycle and static on screen
                      by spice_disc
                      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                      09-08-2024, 02:37 PM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • paqman
                      Vizio M60-C3 black screen
                      by paqman
                      So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
                      So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
                      03-02-2024, 04:37 PM
