LG 42LG70 blowing fuse
  • tibimakai
    • Jan 2012
    • 3680
    Re: LG 42LG70 blowing fuse
    I couldn't find it on Digikey.
      Right now the fuse keeps blowing is due to shorted out MOSFET's, not due to high inrush current.
      Please leave the two MOSFET's out for now and check the DC voltage on the main DC filter cap, check the voltage when the TV is OFF and when the TV is ON (PFC circuits kicks ON).
        Fuse, just serach for '3.15A 5x20mm fuse'
        http://www.digikey.com/product-detai...543-ND/1009769
        By the way, did you check those two MOSFET's and the two Diode in the PFC circuits mounted on the heat sink?
        • tibimakai
          • Jan 2012
          • 3680
          Thank you for the fuse, I will buy them.
          I have checked(as I know how, but still not sure how) the two transistors and two diodes on the heat sink and they seem OK.
          I have removed the two transistors and the short is gone. Inserted another fuse and started it up and I have 385V and 5.1V STBY(switches are lighting up and they beep).
          When I turn the TV off the 385V the voltage drops to 161V.
          After plugging in the AC cord, the voltage is already at 385V without turning the TV on from the switch or remote.
            OK the PFC is working and not putting too high of the voltage to damage the MOSFET's. Do not install the MOSFET yet, with TV off, but still plug in, check the Gate's pads of both MOSFET's on the board to see what kind of DC voltage you have on the GATE's pad.
            • tibimakai
              • Jan 2012
              • 3680
              Both are oscillating, one a lot more then the other.
              One is 13.5V with a bit of oscillation, but the other it's hard to tell, because it's oscillating between 0-4.3V(the highest that I have seen).
                I do have one question to ask on the sequence of the event: it was blowing the fuse, you found shorted out MOSFET's so you replaced both MOSFET's. The fuse blown right away, so you install the new SMPS IC but did not replace the two new MOSFET's. So now we found out that the new MOSFET's are blown again. Is this correct? If it is, this is what I think what is going on, when the original MOSFET's blew up, it also damaged the SMPS IC. So when you replaced the MOSFET's without replacing the IC at the same time, the damaged IC took out your new MOSFET's, then you replaced the IC but you did not replace the new MOSFET's that were shorted out, so now the shorted MOSFET's took out you new IC.
                  If I have the board in front of me right now, I would replace the two MOSFET's, the IC, and fuse, then plug the TV in the current limiter using lamp and see what will happen.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Yes, that is how it happened and I think that you are right(as always) with the rest also.
                    I will have to order a new IC and fuses. Transistors I have ordered just in case.
                    Thank you for your help, I appreciate it a lot.
                    I won't "bother" you for a week, I will be back on 08/19 from Costa Rica.
                    Hopefully I will get the parts from China also for the Samsung monitor.
                    It will be exciting when I will get back, I'm also waiting on an inverter transformer for a Sony TV, so if everything goes well, I will have three working devices(two, thanks to you).
                    I still have that Asus monitor and a Philips 42PFL7422D/37 w/no power, no relay click.
                      Vacation? By the way, check the resistors, diodes, cap around that IC also, remember the monitor that we still cannot figure out what is going on due to burnt out resistors in the Gate drive circuits?
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Yes, we are going for a week since my daughter is in vacation now.
                        I will check those components also.
                        Yes, that monitor. I have replaced the IC, the resistors, but I have a feeling that the IC doesn't get enough voltage(only 142V). I have updated that post a couple of days ago with the latest voltages. I haven't tried out with the 200K resistor yet, as suggested by another member.
                        And I still have that Vizio VO42L which seems in order, but still won't start.
                          Oh by the way, there are version A and version B for that SMPS IC, make sure to match the version. See page 13
                          • tibimakai
                            • Jan 2012
                            • 3680
                            It's AG, thank you for looking out for me.
                            This is the one I have purchased and I'm considering buying again:
                            http://www.digikey.com/product-detai...SCT-ND/1646500
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I have finally replaced the IC, the two FET transistors and the fuse and now it blew the main fuse.
                              At the main capacitor it shows short. Removed the FET closer to the fuse and the short is gone.
                              I have to confess that I haven't checked all the components as we agreed.
                              It can't be the transformer's winding shorted?
                                All transformer windings will read DC short, what matters is inductance and Q factor.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  FETs should be handled with grounding strap? I'm thinking,what if I handle them wrong and they are already shorted when I install them?
                                  Anybody can teach me please how to test these FET transistors?
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    #37
                                    Switching MOSFETs are pretty resistant to ESD, there is no problem in handling them. There's something else gone downstream. Get a habit of using this whenever you are dealing with a device that had blown mains fuses, it will save you a lot of blown parts.
                                    http://antiqueradio.org/dimbulb.htm
                                    A working TV? How boring!
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Yeah, I have the components for it, I just didn't have the time yet to put it together.
                                      By the way, what kind of bulbs I should use, same as in the description, have different wattage and go from low to a higher one?
                                      Just got back from vacation and I was excited to see it running and rushed it.
                                      I just don't understand why the two FETs are open right(see my other picture with the red line marked) after installing them without power applied.
                                        For 42" TV, at least 100W.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          You are right, they use at least 240W.
                                          • Dannyx
                                            UC3842 Power Adapter Blowing Fuse
                                            by Dannyx
                                            Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                            Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                            12-05-2023, 12:06 PM
                                          • RogerH58
                                            Samsung 46" TV LE46B530 blowing fuse
                                            by RogerH58
                                            I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                            I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                            I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                            06-10-2023, 10:27 AM
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • Ross Kohler
                                            Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                                            by Ross Kohler
                                            I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                                            - There's no sign of any attempt to power on when pushing the power button.
                                            - No PSON signal is reaching the 24-pin ATX connector.
                                            - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                                            - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                                            - If I pull the Super IO S_SLPS#_R pin...
                                            04-16-2024, 09:36 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
