logic lcxw37hd1
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    logic lcxw37hd1
    had this one come in,blown psu standby circuit,psu all fixed,
    smd bridge blown,power ic (green mode power switch),3.15a anti surge fuse.
    psu kicking out all the right voltages now.
    tv tunes in ok,picture all good,when powering off on remote standby,and also tv side power switch,and power back on, you have to retune the dvb as it wont store the channels.
    anyone know a service mode for this tv?,need to check if its in some kind of shop mode,before ordering a new dvb board,checked this board ,caps ok,2 voltage regulators on there are inputting and outputting what they should do,nothing else apart from huge smd chips to check on this board.
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    Re: logic lcxw37hd1
    Try doing a factory reinstall. (Usually available in the normal menus.)
    Based on what chassis? Vestel? If so, 4725 MENU on remote gets into service menu.
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      Re: logic lcxw37hd1
      dont think this is a vestal ,main board number is as follows:
      450100005501
      450000006301
      2006/02/17
      dvb board is as follows:
      4501-0001-5803
      psu board number is as follows:
      4501 0001 0400
      4500 0002 7800
      amoi ver 1.0
      quite a nice psu in fact.
      tried your code tom,didnt work ,tried 1st installation menu also,that didnt work,still dosent seem to want to store the channels it finds,fine while tv is on,switch off, no channels.
        Re: logic lcxw37hd1
        Pics of chassis? I or someone else may recognise it.
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          Re: logic lcxw37hd1
          il try and get a pic up tomorow,not sure how it will turn out though
          • thuss
            • Jul 2012
            • 317
            • uk
            Re: logic lcxw37hd1
            Hi
            I have a logik LCXW37HD1 doing the same thing - not saving dtv channels, fine whilst on.
            I was wondering did you ever find a solution?
            Thanks in advance.
            • brianbelfast
              • Jun 2010
              • 29
              • Northern Ireland
              Re: logic lcxw37hd1
              Any updates on the disappearing freeview ? I just did the standby psu rebuild only to find that the freeview tuner only puts in an appearance about once in every 10 startups. I've not recapped the main part of the psu yet. Ripples upsetting the digital tuner maybe ?
                • 30956
                Re: logic lcxw37hd1
                storage is probably to an 8pin eeprom.
                anything in there starting with 25L ?
                as for freeview, a lot of people are losing freeview.
                the scum-government has sold an 800Mhz license to the fone company's for 4g service.
                some tv's can pick it up and the AGC in the tuner causes it to lose the weaker DVB signals.
                  • 30956
                  Re: logic lcxw37hd1
                  https://duckduckgo.com/?q=freeview+4...t-wt&kv=1&kh=1
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    Re: logic lcxw37hd1
                    Go to SKY MEDIA web site for firmware update all there makes and models fail in this way, some have updates and some dont, they will repair it for you for £145, or go to Ohm supplies see if Andy has an eeprom for your set, go by main board and panel numbers,dont worry to much about make and model Flocko
                      • 30956
                      Re: logic lcxw37hd1
                      got a link for sky media?
                      • flocko
                        • Nov 2012
                        • 1121
                        • uk
                        Re: logic lcxw37hd1
                        www.umc-uk.co.uk try this hope it helps Flocko
                        • brianbelfast
                          • Jun 2010
                          • 29
                          • Northern Ireland
                          Re: logic lcxw37hd1
                          Mine isn't a channel storage problem. After restarting the set maybe a dozen times the freeview section springs to life and all the previously stored channels are still there and all works perfectly. Next restart it's back to "No signal remind" and auto off in 5 minutes. It's almost as if the digital tuner is failing POST and the main board thinks there is no digital tuner installed.
                          Does anyone know how to get into the installer / service menu on this chassis ? Thanks.
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            Re: logic lcxw37hd1
                            Pictures - details of your main board?
                            • brianbelfast
                              • Jun 2010
                              • 29
                              • Northern Ireland
                              Re: logic lcxw37hd1
                              Thanks for the reply.
                              I just powered up the set and freeview tuner is working fine. All channels still there since I last retuned it. I did notice however that the picture is doing a little hiccup just every once in a while similar to the glitching you get associated with weak signal. (My signal here is off the scale so it's not that)
                              Next time I power up it will most likely say no input. Not no signal. It's like the set is sitting on an av input with nothing connected. Like the digital tuner is not outputting anything. It's a weird one.
                              Photos attached. First one is the set working. The rest are of the main board. It's mostly covered up by the tuner board so I took it out to give you a better view.
                              Hope you can help. Fingers crossed.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                Re: logic lcxw37hd1
                                I know very little about tvs - are you in Belfast?
                                If the signal is VERY strong perhaps it needs what I think they call an attenuator
                                on the aerial wire I assume you have checked the aerial and cable - wires soldered not just pushfit?.
                                • brianbelfast
                                  • Jun 2010
                                  • 29
                                  • Northern Ireland
                                  Re: logic lcxw37hd1
                                  Yes I'm in Belfast.
                                  No it's not a signal issue. If I could just get into the service menu and reset everything I reckon that would sort it out. The set had a pretty major power supply blow-up which could well have corrupted some of the info in memory. I'll keep searching. Thanks for your help. And please give me a shout if you find that elusive service menu code.
                                  • brianbelfast
                                    • Jun 2010
                                    • 29
                                    • Northern Ireland
                                    Re: logic lcxw37hd1
                                    OK it turns out that this is actually an AMOI LC37T1E in disguise. To enter service menu you hold down the menu button on the remote and switch the set on. Problem is, for me anyway, that factory reset initialises the main board in the set but not the freeview board which is separate. So I am no further on. I give up. Freeview board is 12 quid on ebay.
                                    • ohren
                                      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                      by ohren
                                      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                      The models launched in 2018 and 2019 respectively....
                                      09-08-2023, 05:24 PM
                                    • korben_dallas
                                      Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                      by korben_dallas
                                      Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                      I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                      I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                      MY QUESTION:
                                      I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                      02-14-2024, 12:23 AM
                                    • Yanleb
                                      LG 60PK550 Logic Control Board EBR63450301
                                      by Yanleb
                                      Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                      C57: 3.30V
                                      C61:...
                                      07-20-2023, 12:38 AM
                                    • mferna14
                                      Logic Board 820-00840-A Missing EDP_BKLT_EN
                                      by mferna14
                                      Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
                                      07-10-2024, 05:18 PM
                                    • mferna14
                                      Logic Board 820-01987-A missing PP3V3_S5
                                      by mferna14
                                      Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
                                      06-07-2025, 05:07 PM
