Sharp LC-32GA6E Stuck in standby
  • Jahson
    • May 2012
    • 245
    Re: Sharp LC-32GA6E Stuck in standby
    need to check
    • Jahson
      • May 2012
      • 245
      Just started all over again, im getting 0v to the bridge reticfer
      DMM set to 600ac, probes to snake signs in the middle or bridge reticfer = 0v
      did fuse checks f201, f202, f203 all are ok.
      When i probe D763 i get 245v,
      How do i go about testing IC's ic701 & ic703
        0V ac doesn't matter if ICs are bad you need to fix this first, what do you see across two middle pins?
        • Jahson
          • May 2012
          • 245
          • Jahson
            • May 2012
            • 245
            In the picture from post #43 the 2nd pix, the circle is on ic703, one o'clock from the ic703 is D763 im getting 245v when probed.
              No relay click when powered on I guess.
              There are probably two bridges one standby one main.
              • Jahson
                • May 2012
                • 245
                No clicky clicky
                • lepak06
                  TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                  by lepak06
                  Hello
                  I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                  The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                  Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                  All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                  But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                  01-12-2023, 01:43 AM
                • SONY_E-WASTER
                  Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                  by SONY_E-WASTER
                  Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                  The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                  then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                  does...
                  12-26-2021, 05:46 PM
                • Egidio85
                  SHARP LC-40LE814E does not turn on 2 flashes
                  by Egidio85
                  hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                  the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                  reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                  now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                  to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                  07-21-2023, 11:49 AM
                • toty79
                  Hisense LTDN50K220WSEU stuck in standby
                  by toty79
                  Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                  As per Hisense tv title LTDN50K220WSEU stuck in standby
                  PSU rsag.820.5687 HLL 4855WF
                  Main rsag 7.820.5842
                  I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                  05-01-2022, 04:39 PM
                • lego1234567
                  LG 32LB1R - stuck in standby mode
                  by lego1234567
                  Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                  What could be the problem ? Thanks...
                  01-21-2024, 03:39 AM
