Sharp LC-32GA6E Stuck in standby
    Re: Sharp LC-32GA6E Stuck in standby
    Can also hear high pitch sound very low, with a ticking sound every 3-5 seconds coming from one of the transformers Think its T701.
    When i unplug the power cable the whinging sound slighty goes higher, then fades out.
      Need a little help does these readings sound correct?
      Meter set to diode
      Q701 reads:-
      Black probe on G, Red probe on D = OL
      Black probe on G, Red probe on S = 1.267
      Black probe on D, Red probe on S = .476
      RED probe on G, BLACK probe on D = OL
      RED probe on G, BLACK probe on S = 1.164
      RED probe on D, BLACK probe on S = OL
      Q702 reads:-
      Black probe on G, Red probe on S = 1.272
      Black probe on D, Red probe on S = .475
      RED probe on G, BLACK probe on S = 1.153
      Are they ok?
      Part No=12N60C
        Meter set to diode
        Q701 reads:-
        Q702 reads:-
        Are they ok?
        Part No=12N60C
        Those readings look good.
        I suspect a bad cap in here, especially with the random on/off issues it is having.
        Muh-soggy-knee
          cheers ben7, yea the green led on the front is staying on? wasnt doing that before.
            Still no joy, the whining sound is coming from this relay, i recapped nearly the whole board yesday apart from the large caps.
            Can anyone piont me what directions i should take next.
              Hmm, either the power supply standby has a lot of ripple, or the circuit meant to turn the relay on is not functioning right.
              Check the standby voltage again.
              Muh-soggy-knee
                Just connected the DMM onto CN706 something aint right?
                pin1= 1.26v
                pin2= 0.00v
                pin3= 1.26v
                pin4= 0.00v
                pin5= 0.00v
                pin6= 0.00v
                pin7= 0.01v
                pin8= 0.15v
                pin9= 1.78v
                pin10= 0.00v
                pin11= 3.48v
                pin12= 3.48v
                pin13= 0.00v
                  hiya thought i come back & retry.
                  Tv led showing solid green, slight high pitch sound coming from i think L703,
                  pin1= 1.26v
                  pin2= 0.00v
                  pin3= 1.26v
                  pin4= 0.00v
                  pin5= 0.00v
                  pin6= 0.00v
                  pin7= 0.00v
                  pin8= 0.14v
                  pin9= 1.78v
                  pin10= 0.00v
                  pin11= 3.48v
                  pin12= 3.48v
                  pin13= 0.00v
                  How to i go about checking D701, for some funny reason can only get readings with the probes connected reverse?
                    Sorry just a quick heads up, are theses readings correct
                    DMM set to 2k diode:>
                    Q710:
                    Red probe on G - Black probe on S = .322
                    Black probe on G - Red probe on S = .322
                    Red probe on G - Black probe on D = .913
                    Black probe on G - Red probe on D = 1.
                    Red probe on D - Black probe on S = 1.
                    Black probe on D - Red probe on S = .524
                    Q711:
                    Red probe on G - Black probe on S = 1.
                    Black probe on G - Red probe on S = 1.094
                    Red probe on G - Black probe on D = 1.
                    Black probe on D - Red probe on S = .523
                      the number written on the front :> 57299 K3520.01
                        Anyone?
                          I don't see anything obviously wrong with your readings.
                          Does the board still whine?
                            yea is does still whine, ive tried to google the part but it just dont make sense?
                              It's probably from that yellow transformer above. Checked shorted diodes on output?
                                check which diode?
                                  All of them.
                                    Ive checked diodes a few times before, if im correct anything between .3XX & .8XX is fine?how do i go about testing that transformer.
                                      The transformer is probably OK, as they have a failure rate nearing zero percent. Do you have any standby voltage at all?
                                        post #28
                                          How's the voltage with the main board disconnected?
