Need help with a Emerson 32" TV LC320EM2F
  • eqtitan
    • 10
    Ok, so I traded a laptop (only paid $50 for, worth $300) for an Emerson 32" LCD TV the guy powered it on via an inverter in his car which I thought was a bad idea. None the less it powered up after the power light blinked RED. Took it home all excited plugged it in to a cable line (COAX) and plugged in the power turned on the TV and heard buzzing coming from the back left it on for a minute when it started to smoke. Took the back cover off and found the issue, it was a capacitor with a bulging top got so hot it melted the shrink material that was wrapped around it.
    Model: LC320EM2F
    The capacitor is labeled as (HEC) 390uf 200wv neg20 85° C but i am unable to find this exact capacitor online or Ebay. I'd like a good quality capacitor replacement.
    It's about as around as a 50cent piece and about 1in in height. I can get pictures later tonight when I get home if needed.
    "Whatever you are, be a good one" - Abraham Lincoln
    Re: Need help with a Emerson 32" TV LC320EM2F
    Just checking you definitely used 115V AC (did he?) Very rare for a primary capacitor like that to go bad unless something else is bad on the power board.
    • eqtitan
      • 10
      Everything else checked out good on the board visually. Not sure what type or output he used when he used the inverter it was plugged into a power out in has escalade.
      • selldoor
        Slow Learner
        • 7870
        Did you see an actual picture on the set in his car or just the screen lit up white.
        • eqtitan
          • 10
          The start up screen that was searching for a signal (Search for Digital Signal) was displayed in lower right corner.
          • selldoor
            Slow Learner
            • 7870
            You will need to post pictures as follows.
            Welcome to the forum-
            We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
            Examples of what is needed
            https://www.badcaps.net/forum/attach...1&d=1290283049
            https://www.badcaps.net/forum/attach...7&d=1280167246
            It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
            • eqtitan
              • 10
              Pictures added to OP
              • eqtitan
                • 10
                • selldoor
                  Slow Learner
                  • 7870
                  Pictures are not clear enough for troubleshooting. need them to be square on
                  and in focus and one of the bottom of the board.
                  It there any evidence that the leads to the cap could have touched something under the board.
                  One of these should do you id get a 105 deg one.
                  http://www.digikey.sg/scripts/dksear...f+200v&stock=1
                  We have had similar boards recently where it has been thought that a diode may have blown if you can check them for shorts.
                  What is the part number of the board- looks like they may be available at a reasonable price.
                  Can we assume there is no way the guy could have switched sets on you?
                  as Tom says Big Cap blowing is not something we often see aprt from one
                  pc monitor that keeps cropping up.
                  • eqtitan
                    • 10
                    No leads did not touch anything under board the frame it attached to was plastic and non conductive. I looked up the part number for the board and checked Ebay the cheapest replacement board was $81 shipped.
                    None of these look the correct size of the one they are replacing....is digi-key located in the USA?
                    • selldoor
                      Slow Learner
                      • 7870
                      Hi - its international - dont know how I got the singapore page just type in digikey.com into your browser and search for 390uf 200v then narrow it down by size. Can you tell US the board number and redo the pics.
                      • Mario R Morales
                        • 3
                        • usa
                        Need parts list 4 d610 (1zb36) orignal part# 4 lc320em2f emerson and d1208 (1m200z) orignal part# 4 emerson lc401em24
                        • Terryfictv
                          • Mar 2011
                          • 124
                          Hi !
                          I am working on the same model...this is my list =
                          Blown fuse
                          Shorted Q600 = TK10A50D
                          Shorted D610 = 1ZB36 ( 36V 1 watt zener )
                          Shorted D640 = SK2B ( SMD on bottom of board )
                          Open R608 = .19 ohm
                          Update ASAP
                          T.
                          • mu2
                            • Oct 2009
                            • 217
                            I also need some information. Working on the same model and my power supply board is BA17F1F0102 3 and the number on the sticker is A17FDMPW.
                            I've already replaced about 5 parts - mosfet, zeners, resistor, etc.
                            I now have two burned resistors and can't identify the values.
                            The reference numbers are R635 and R636. They are located on the bottom right side of the board, above the fuse and to the right of the optocoupler.
                            Would really appreciate the values. I can't make out the color codes from the pictures that have been posted.
                            Does anyone have a link to the schematic of the power supply?
                            Thanks in advance
                            • carjo3000
                              • Apr 2013
                              Thanks in advance
                              Hello, I just started to work on the same board. I've tried replacing the fuse but it keeps blowing out so now I'm checking all the components that have been listed on this thread.
                              The values for R635 and R636 are 120ohm 5%.
                              You mentioned replacing 5 parts so far, can you please list the reference numbers? Has replacing them solved the problem?
                              thanks
                              • mu2
                                • Oct 2009
                                • 217
                                The tv isn't working yet, haven't had much time lately.
                                The parts that I have replaced are:
                                R608, D604, D645, D648, Q600 and D640 on the bottom of the board.
                                Also replaced the two 120 ohm resistors I mentioned before - but that fault wasn't related to the original problem.
                                Right now the transformer is squealing when the set is connected to power. I haven't left it on long enough for fear of more damage.
                                Check out this thread. I think this set uses the same power board.
                                https://www.badcaps.net/forum/showth...light=lc320ss2
                                The writer lists some digikey part numbers.
                                Mike
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  change the opto and the 2 zeners after the rectifiers on the secondary side.the opto dies with the chopper and caused an overshoot.
                                  • microvibe
                                    • Mar 2013
                                    • 275
                                    • canada
                                    i have this same tv and problem with power supply , replaced parts and tested others i still dont have power , there is no clicks or nothing when pluged in. i have power at the zenner d604 not sure where it stop after that trying to follow the circuits still
                                    • buymytvpleez
                                      • May 2013
                                      • usa
                                      D611 is the part that needs replacement. Problem is, I can;t find ANYWHERE to purchase it.
                                      go to youtube and type in the Emerson LC320EM2F repair. There is a repair video (in spanish) that shows you the part that you need. Can anyone help me find the D611 part for purchase?
                                      Johnny
                                      • Dmaltz
                                        • Aug 2013
                                        The schematic I have only has a part number for D611 which is 12B220-YBB. I'm guessing it's a 220 volt zener based on the numbers it has.
                                        • MORETTIGIAN
                                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                                          Procedure performed:
                                          - Removed backplate
                                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          Observed behavior after reassembly:
                                          - GPU powers on and operates normally under...
                                          09-18-2025, 12:14 PM
                                        • Prolog
                                          RTX 3080 FE Identifying capacitor
                                          by Prolog
                                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                          I hope these photos make it clear which component I am referring to:
                                          (yes, the soldering is a bit botched from removing the blown one, I know)
                                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                          12-01-2024, 08:27 PM
                                        • chth96
                                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                          by chth96
                                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                          I know that these capacitor will not last as long as nichicon capacitor...
                                          12-22-2023, 04:34 AM
                                        • chth96
                                          How can I test non-polarized capacitor?
                                          by chth96
                                          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                                          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                                          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                                          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                                          06-02-2024, 07:31 PM
                                        • chth96
                                          Is it no harm to replace with capacitor without ripple current rating?
                                          by chth96
                                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                          Rubycon YK DataSheet (b...
                                          04-19-2024, 05:19 AM
