Long time lurker, first time poster. Not sure why I didn't already have an account here before today though...hmm.
Well, I've recapped some gear in my time and when I came to this TV, I did nothing less. Replaced the caps directly around the power source (the common problem, 200v caps)and the problem still presists. When the TV is plugged in, there is a high pitched whine/squeal that decreases in pitch over a short time.
Nothing seems to have changed after replacing the caps so it leads me to wonder what the next place to deal with is.
TV model is: 22PFL3504D/F7
Beyond capacitors, my experience on PCB's is limited so some liberal explanations may not hurt. I've recapped many types of gear and solved the problems in most but, after recapping failed to solve the problem here, I'm looking to learn the next step!
Although I would prefer to replace all the caps, I couldn't make it happen on this order because, well, I don't want to stick $50 bucks into caps if it's something else. If there are other components that, in your valuable experience, present similar symptoms, would it be advantageous to replace those or will it be a snipe hunt to get to the bottom of it?
