Philips flat-panel dead. Replaced PSU caps and still squealing
  • puttsy
    • 5
    Long time lurker, first time poster. Not sure why I didn't already have an account here before today though...hmm.
    Well, I've recapped some gear in my time and when I came to this TV, I did nothing less. Replaced the caps directly around the power source (the common problem, 200v caps)and the problem still presists. When the TV is plugged in, there is a high pitched whine/squeal that decreases in pitch over a short time.
    Nothing seems to have changed after replacing the caps so it leads me to wonder what the next place to deal with is.
    TV model is: 22PFL3504D/F7
    Beyond capacitors, my experience on PCB's is limited so some liberal explanations may not hurt. I've recapped many types of gear and solved the problems in most but, after recapping failed to solve the problem here, I'm looking to learn the next step!
    Although I would prefer to replace all the caps, I couldn't make it happen on this order because, well, I don't want to stick $50 bucks into caps if it's something else. If there are other components that, in your valuable experience, present similar symptoms, would it be advantageous to replace those or will it be a snipe hunt to get to the bottom of it?
  • Mr Bill
    • Nov 2011
    • 648
    Re: Philips flat-panel dead. Replaced PSU caps and still squealing
    Can you get a few pictures of the power board. Is the power supply and main tuner all one board? Is the tv chirping? From my past experience it'll do a long squeel then chirp chirp chirp. This has been posted a few times but not on your model, atleast i don't think but it always turns out to be a bad zener diode. So that would be a good place to start.
    • RON_CET
      • 217
      check for shorted zener d668 20volt 1 watt on psu,if you find shorted on board,desolder and remove and check also off board
      Ron Driver,BSEE,CET,ISCET,NESDA
      • puttsy
        • 5
        Yep, Power and Tuner are on the same board. I looked up the part number for the board but didn't find any good sources and heck, I would rather fix this one up than buy a new (or new, 'used' board) anyway. This way I know that the caps will be good caps (decent brand anyway) and that it won't be damaged in transit.
        I'll post pictures tomorrow. Apparently the camera on my phone is broken (plastic lens cover/protector) is broken so there are blurry spots on the pictures. You all would probably prefer some detail in the pictures and the ones I took just don't provide such! Thanks for the prompt response though @Mr Bill! Wish I could return the request sooner.
        • puttsy
          • 5
          Full board:
          PSU area 1:
          PSU area 2:
          None of the zener dioades appear to be shorted out so it may be bad(?). Would it be easiest to replace all of them or, is there s specific one that is usually the culprit? I didn't see a D668 diode, there are several other diodes (D607, D608, D605, D606, D610) in the vascinity of the PSU. Now, would it likely be centerilized around that PSU section or, should I be looking all over the whole board for the D668 diode, if that's the common culprit?
          Again, thanks for the help guys! Quite interesting.
          • RON_CET
            • 217
            here's partial schematic of where D668 is located at hope this helps
            • selldoor
              Slow Learner
              • 7870
              As a long time lurker you should be aware that some members including myself do not like pictures posted in line, and will not even look at a thread
              which has them. I suggest you edit and remove then upload using manage attachments.
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                @.@ they're small enough not to break the formatting of the formatting and they load instantly so seriously why does it matter?
                  It's not a big deal. It improves the readability.
                  • puttsy
                    • 5
                    Great! Thanks, found it. However, there is an interesting mark on the board in the vicinity of D668. Almost looks like D631 shorted out but nothing aside from the dark brown marks (almost burned or singed, but not DEEP brown/black) in it's vicinity indicates a problem. Obviously that )D668) still could be the issue but, I want your guys' opinion before I up and buy new parts that may be totally unrelated to the problem.
                    As for the inline pics. I know some guys hate them, others don't have a problem. I usually make sure they are within the size restrictions prior to posting but, from here-on-out, I can just attach them to help keep the crew content. Thanks!
                    • selldoor
                      Slow Learner
                      • 7870
                      Have you tried pinning the sound down by using a rolled up paper or thin card tube. Please can you insulate the bare mains feed - its making me queasy.
                        Looks like this Philips uses a self-resonant two-transistor SMPS, which is a bad idea in my opinion for anything more than a couple of watts.. The squealing could be caused by one of the small poly caps on the primary side going leaky. Or it could be a shorted diode.
                        Is that mains lead factory issue? Looks dangerous!
                        • puttsy
                          • 5
                          Absolutely NOT factory. For quick testing I tapped it onto the board. Now that more than one person has mentioned it I suppose I'll take care of it. I was actually planning on putting a jack on the case and a removable power cable but couldn't find any small figure-8 jacks lying around and didn't want the bulk of a 3-pin IEC connector on there. It's only an issue if you were to move it around but, I knew it wasn't *good* at the time, just wanted to get it tested. I nicely soldered the original cable on there after replacing the couple of caps but, after that failed, I once again took it off and just stuck that one on and off because it's a quick tap it on, tap it off to test with.
                          Just cut it off though, just for you guys. Now,
                          Any easy way to fix that or, should I *sigh* call this TV a loss and move on? I really hate to pitch it. The panel is still good on it but, I can't find a replacement board that matches the model. Any ideas on how to use the panel for anything else?
                          • kew1701
                            Philips taw6205 ambilight speaker STM32 mcu dead
                            by kew1701
                            Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                            04-09-2025, 03:59 AM
                          • rstrube
                            ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                            by rstrube
                            Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
                            Hi Everyone,
                            I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                            Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
                            11-23-2025, 01:37 PM
                          • rstrube
                            by rstrube
                            Hi Everyone,
                            Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
                            11-23-2025, 12:19 PM
                          • Rubenlily
                            Philips 50PUS6503 - dead panel? Picture
                            by Rubenlily
                            Hey,
                            I gave up on my last TV and got a new one to try.
                            Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
                            Is this fixable in any way or should I just give up on this one too?...
                            08-21-2023, 01:07 PM
                          • double_DD
                            How can I be sure that my EC chip is dead?
                            by double_DD
                            As the title suggests, how can I be sure that my EC chip is really dead?
                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                            03-12-2025, 07:47 AM
