Lg 37lc55
  • junger
    TV Enthusiast
    • Sep 2011
    • 13
    • England
    Lg 37lc55
    Hi All
    I have had a couple of the same model giving the same sympton on
    LG 37LC55.
    When switched on you get no picture, If the LCD is left on for say 15minutes and then the mains cable is unplugged and reinserted then it works perfectly well. I have looked at the caps on the power board and they are not bubbled/dry.
    Any ideas, anything I can try?
    Junger
    Re: Lg 37lc55
    Bad cap can look normal but it can have high ESR. What you can do is this, heat up the power supply board with hair dryer, then pug in the TV and see if it will come on. ESR will go down when cap is heated up. It sure sounds like bad caps to me.
      Re: Lg 37lc55
      The LG 37LC46, 37LC55, 42LC46 and 42LC55 are prone to four bad caps on the PSU going bad. More Samwha WBs.
      • junger
        TV Enthusiast
        • Sep 2011
        • 13
        • England
        Re: Lg 37lc55
        hi
        which caps are they, so that I can inspect them closer, Thanks for the hairdryer tip, I will try that
        • psmedley
          • Apr 2012
          • 144
          Re: Lg 37lc55
          http://www.ohmsupplies.co.uk/LG-37LC...301-REPAIR-KIT
          LG 37LC55 REPAIR KIT
          BOARD MARKED EAY34796801, EAX32268301
          FAULT SYMPTOMS:
          STAND BY
          FLASHING LED
          DEAD
          WHATS IN THE KIT:
          C217
          C218
          C226
          C210
          C221
          C206
          C222
          C208
          • junger
            TV Enthusiast
            • Sep 2011
            • 13
            • England
            Re: Lg 37lc55
            hi all
            The fault has developed further,now I can see in the back, when switched on the hv lights up, after about 10 mins the hv lights strobe/flash and then goes back to normal.
            I have replaced the PSU board from my mates LG (same model) and it was the same, so I changed the main board and the fault travelled with the board. so the fault is on the main processing board, any ideas?
            • selldoor
              Slow Learner
              • 7870
              Re: Lg 37lc55
              Pictures top and bottom of your main board might help.
              Did you try the hairdryer trick on the main board.
              Please can you update your profile with country and mains voltage.
              I will attach instructions for pictures.
              Welcome to the forum-
              We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
              Examples of what is needed
              https://www.badcaps.net/forum/attach...1&d=1290283049
              https://www.badcaps.net/forum/attach...7&d=1280167246
              It will be useful if you can say a bit about yourself - skills tools etc.
              • rediii
                thinkpad t460 - only charges when battery reinserted
                by rediii
                hello, the following problem:
                the thinkpad would charge after reinserting the battery after charger is plugged. however, also when the adapter is installed and the battery is removed and reinserted. charging occurs adaptive (no steady 12 v on pl101/pr110).
                i have checked all mosfets (they appear to be fine), all resistors, diodes and fuses on the circuit lines as well as replaced the charger ic twice as well as pq101 and pq102. i have also tried two original batteries (the device came with external battery only) and power supplies (65 and 90 w, which are also correctly...
                12-11-2022, 01:55 PM
              • Gusse
                GE62VR 6RF Apache Pro - reboot until turn ON stuck at 1.6A
                by Gusse
                I am asking for your help because I am having a problem with no image on an MSI GE62VR 6RF Apache Pro.
                Here is a list of things I have checked:
                - Removed/reinserted the RAM
                - Removed the hard drive
                - Removed the SSD
                - Connected via HDMI -> no image
                - Tested caps lock -> working
                - USB key -> “activity” (LED flashes when inserted)
                - Reflashed the BIOS with CH341 using a version found on the MSI website (then checked the dump read with UEFI Tool) -> same result
                - Checked the power rails around the CPU on the...
                Today, 06:17 AM
              • Curious808
                Brother HL-2140 laser printer: printer error (solved)
                by Curious808
                SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
                Windows 10
                Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
                Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
                06-22-2023, 11:11 PM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • SAFC
                imac 21.5 820-3126-A 2011 dont power on
                by SAFC
                The device was brought to me after self-cleaning. After replacing the thermal interfaces, the iMac stopped turning on. While the client was rummaging around in it, he touched the power supply with the processor radiator, after which there was a bang.
                I examined the power supply, replaced the burnt-out Zener diode ZD36 and the PWM controller DAP017. Now there are standby 12 and 4 volts
                When connecting the board to the power supply, autostart occurs, only LED 501 lights up. The cooler starts to rotate, after half a second it stops and so on in a circle. For these half a...
                09-21-2024, 05:20 AM
