Sharp Aquos LC-32D40U - no image
  • ahickman
    • Jan 2012
    • 233
    Re: Sharp Aquos LC-32D40U - no image
    I read throught the datasheet and saw the 2.20 VDC +/- 1%, but thought it was dependent upon VCC which in the example was 3.3 VDC. On this board, VCC is 5.3 VDC. Make a difference?
    Checking my DVM against a reference voltage source now.
    Looked over the various voltage regulators on the PS:
    IC506 = 5.01 VDC
    IC508 = 5.33 VDC
    IC505 = 5.19 VDC
    IC510 = 8.90 VDC
    • ahickman
      • Jan 2012
      • 233
      Were it you, would you be confident that the t-con is the defective board?
      • retiredcaps
        • Apr 2010
        • 9271
        #43
        My interpretation is that it is a fixed 2.20V regardless of Vcc. Vcc can be 2.5 to 20V (page 4).
        IC506 = 5.01 VDC
        IC508 = 5.33 VDC
        IC505 = 5.19 VDC
        IC510 = 8.90 VDC
        I'm talking about voltage regulators on the main board (where the AV, HDMI, RCA).
        --- begin sig file ---
        --- end sig file ---
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          Not until I check out the voltage regulators on the main board. See above post.
          • retiredcaps
            • Apr 2010
            • 9271
            #45
            What make and model do you have? Some manufacturer products age better than others.
            • ahickman
              • Jan 2012
              • 233
              Checking main board VR's now. DVM I am using checked out OK. Vref = 3.30V and reads as 3.31 VDC.
              IC3804 (3.3 v REG ON AV BOARD) = 3.36 VDC
              IC3201 (3.3 V REG on scaler board) = 3.30 VDC
              IC3202 (1.5 V REG on scaler board) = 1.60 VDC
              IC3602 (3.3 V REG on scaler board) = 0.0 VDC
              IC3601 (1.8 V REG on scaler board) = 0.0 VDC
              • retiredcaps
                • Apr 2010
                • 9271
                #47
                What is the reading for all pins on the two above?
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #48
                  What are you calling the scalar board? Post a picture of it with the two ICs above circled in red.
                  • ahickman
                    • Jan 2012
                    • 233
                    Pins #2 on both read 5.0 VDC. Remaining pins have 0.0 VDC. Attached are a front/back shot of scaler board.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #50
                      What is part number of both?
                      • ahickman
                        • Jan 2012
                        • 233
                        Ic3602 = ba00bc0wfp
                        ic2601 = bd7820fp
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #52
                          It looks like both belong to a subsection called MICON2. I'm not sure what that stands for, but it is possible that until the TV actually turns on, those output voltages are at 0.0V. It will all depend on what the datasheet says those components are and the expected output voltage.
                          Are those 2 connectors (CP3601 and CP3603) on MICON2 usb ports?
                          • ahickman
                            • Jan 2012
                            • 233
                            They both look to be part of the HDMI interface. Both have pins #1 (Vc) connected to a H_INT line. Might be that they don't turn on until this pin goes high?
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #54
                              Ic3602 = ba00bc0wfp
                              ic2601 = bd7820fp
                              1)
                              page 2 says for a VCC of 5V, Vo = 3.0V, 3.3V
                              2)
                              page 1 says output voltage is 1.0V minimum and 5.0V maximum.
                              3) So if both ICs are supposed to output non zero voltages as per datasheet, then the MICON2 subsection is bad.
                              4) For both ICs, see if the VCC pin is shorted to ground pin. Any reading under 30 ohms suggests short.
                              5) If they aren't turned on until a HDMI cable is connected, then it may be working as intended.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #55
                                If MICON2 works as speculated, then that only leaves the t-con. If you can find a replacement t-con for $20 on ebay, it might be worth shotgunning this one?
                                I would wait for momaka to see what he thinks of the 5% out of tolerance on U300 first.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #56
                                  Q302 - 8 pin chip, numbers as they appear:
                                  4422
                                  8E5519
                                  See if the mosfet is shorted between Vdd and GND.
                                  Measure the DC voltage of Vdd, input, and output with respect to GND.
                                  • ahickman
                                    • Jan 2012
                                    • 233
                                    Neither are shorted to ground.
                                    • ahickman
                                      • Jan 2012
                                      • 233
                                      Pins 1, 2 and 3 are shorted to ground, but pins 4 and 5 are not. According to the datasheet you linked to, 4 and 5 should be GND?
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #59
                                        Do you have correct orientation for the pin? The notch tells you where pin 1 is.
                                        • ahickman
                                          • Jan 2012
                                          • 233
                                          Correct orientation.
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:20 PM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
                                            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-06-2024, 10:56 AM
                                            HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
