Vizio E321VL
Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."Comment
Re: Vizio E321VL
Decided to check the Vizio light on the front. It is steady Orange where I had no light before. Must be some progress. However, there are no backlights or nothing changes when I push the power button. At this time all the boards are connected to each other.Last edited by killian6pk; 06-04-2012, 01:26 PM.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
Ok Now you have the DC standby voltage of 170Vdc, since when you turn the power switch of the TV and the voltage did not go up to 400Vdc, it can mean two things: It is not getting the PS_ON from the Main board or the PFC IC circuits are not working. I will need you to get the P/N of the PFC IC and the SMPS IC so we check the VCC pins.Last edited by budm; 06-04-2012, 02:15 PM.Never stop learning
Re: Vizio E321VL
@TOM, the cap should be OK, since the Didoe is put in backward, the diode never conducts. You can see the diagram I made.
Killian, you may want to recheck all the parts you have installed, just to be sure.Last edited by budm; 06-04-2012, 02:16 PM.Never stop learning
Re: Vizio E321VL
Part # for SMPS IC is: L6599AD
Data Sheet is: https://cdn.badcaps-static.com/pdfs/...d758189067.pdfHave you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
The Cap is fine, if you look at the diagram, when you put in that Diode backward, the diode was never turn on, it was in reverse bias mode. you are OK, no need to change that cap.Never stop learning
Re: Vizio E321VL
if we are now looking for smaller errors Killian6pk You did say you had resoldered some traces - I have been looking but could only see what I thought was one and it looked ok but of you want us to check you will have to mark where to look.
Anyway whilst looking I did find what appeared to be two broken traces. it may be the picture or shadow but please can you check where marked in attached.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Re: Vizio E321VL
I need closed up pictures of the bottom side of the board acround the pfc ic and the SMPS IC so I can trace out the connections, also need the cloased up pictures of the connector on the power supply board so i can see the lables on them, I need to find ot which pin is PS_ON pin, this will be the next step.Last edited by budm; 06-04-2012, 02:45 PM.Never stop learning
Re: Vizio E321VL
Again, SELLDOOR with his GREAT eyesights and software! Killian needs to really re-check his works really well.Never stop learning
Re: Vizio E321VL
Anyway whilst looking I did find what appeared to be two broken traces. it may be the picture or shadow but please can you check where marked in attached.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
I need closed up pictures of the bottom side of the board acround the pfc ic and the SMPS IC so I can trace out the connections, also need the cloased up pictures of the connector on the power supply board so i can see the lables on them, I need to find ot which pin is PS_ON pin, this will be the next step.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
On the Inverter Connector picture Pin one is at the top.
On the Main Board Connector Pin one is at the bottom.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
OK, I will look at the pictures tonight, I cannot find any info on that PFC IC P/N L100 either, it may be difficuit to figure out the VCC pin of that IC, will see after I look at the pictures.
OK, picture#3 post 54, CN101 Pin 11 is PS_ON PIN, please check the voltage onthat pin, it should be around 3VDC or higher when TV is switched on.Last edited by budm; 06-04-2012, 03:57 PM.Never stop learning
Re: Vizio E321VL
If you keep the board oriented in the direction of the picture and look at C608 in the upper left of the board. Go to Buds redline of the picture and look above the number 4 that he placed on the picture. The second location is on the far middle right of the board next to a large black arrow at D331 also look at the scratch across the black arrow to see if that could be a problem. Copper is showing thru.Please upload pictures using attachment function when ask for help on the repair
Re: Vizio E321VL
OK, picture#3 post 54, CN101 Pin 11 is PS_ON PIN, please check the voltage onthat pin, it should be around 3VDC or higher when TV is switched on.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
OK, you do not have the PS_ON signal from the main baord when you trun on the TV, that is why the PFC and the 12/24 Vdc power supply do not turn on. So we need to find out where the fault is on the main board.Never stop learning
Re: Vizio E321VL
You may want to read this thread also:
https://www.badcaps.net/forum/showth...t=19666&page=3Never stop learning
Re: Vizio E321VL
Maybe re check pson test as in
https://www.badcaps.net/forum/showpo...2&postcount=26Please upload pictures using attachment function when ask for help on the repair
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
Assuming...7 Photos -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... - Loading...
