Vizio E321VL
Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most." -
Re: Vizio E321VL
If you are getting 174 Vdc at the two pins of the Bridge, that means the big cap does have connections all the way to the bridge output, but I am confused since you have indicated that you are not getting any DC voltage on the Big cap. This power supply has PFC circuits, so when you plug the TV into the outlet, the voltage on the big cap should be around AC input voltage x 1.414, and when you turn the TV on, the DC voltage should go up to around 400Vdc on that big cap.Never stop learning
Re: Vizio E321VL
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."Comment
Re: Vizio E321VL
If you are getting 174 Vdc at the two pins of the Bridge, that means the big cap does have connections all the way to the bridge output, but I am confused since you have indicated that you are not getting any DC voltage on the Big cap. This power supply has PFC circuits, so when you plug the TV into the outlet, the voltage on the big cap should be around AC input voltage x 1.414, and when you turn the TV on, the DC voltage should go up to around 400Vdc on that big cap.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
Well I checked the cap again and I got 0.4V DC. Should I pull that cap and check ESR etc? Maybe it was bad even though it was new?Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
RV is a Varistor
RT is a Thermistor
Edit - just beat me to it but at least we agree.
Before you pull the cap just test for continuity from a leg to the next joint.Last edited by selldoor; 06-03-2012, 02:29 PM.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Re: Vizio E321VL
Checked several components on both sides +/- and it shows continuity to the next 3 components located on that trace.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
seems like i had one of these in with a bad surface mt diode it was underneath back side of powerboard. near the startup cap, i overlooked it twice and after i let it set for a couple of days i found it. try checking around the area of the cap and see if you find an open sm diode.Comment
Re: Vizio E321VL
1-2 = 0.801mohm; 1-3= 1.737kohm; 2-3= 0.767mohm.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
OK, you do not have open trace.
How about the D100? That Diode is the one that feed the rectified AC into the large cap.Never stop learning
Re: Vizio E321VL
I don't understand what you mean, what do you want me to do? For information purposes this is one of the Diodes that I took out tested and replaced so it is new. It is a GAMUR460 Ultra Fast Rectifier Diode 4A 600V.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
I am still trying to find out why you are not getting the 170vdc on that large cap, as you can see from testing the connection, the traces are OK the only thing that in the path of the + output of the bridge to the + of the large cap (inductor tested OK) is that Diode D100, you can also see it in the diagram I provided, unless that Diode is open (or installed backward), then there is no other reason for not getting any DC on that large cap.Never stop learning
Re: Vizio E321VL
Ok I will check it and see if it is open or installed backwards. I hope I did not do that. Get back to you in a few minutes.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
Picture of that D100 as mounted will help also.Never stop learning
Re: Vizio E321VL
Well you can officially put me into the dumber than a rock catagory. It was in backwards. Took it out and resoldered it and now I am getting 171.9 volts at the Filter Cap. However I am not able to get the voltage to increase by pushing the on/off button. So I guess now I should check for 5V, 12V and 24V at the cable to the Main Board? Also I gave you wrong info above in post #36 about what that Diode was. I corrected that post in case someone needed that info later.Have you ever stopped to think and then forget to start thinking again?
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
Assuming...7 Photos -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... - Loading...
