Poor Old Vizio (VW26L) Died on Me...
  • CuriousGoose
    • May 2012
    • 5
    Hey everyone. I went to turn on my 5+ year old Vizio, Model VW26L, yesterday and much to my chagrin, I received no picture! Upon closer evaluation I noticed that the orange bottom light would go off as it should when I pressed the power button to turn on the tv, but nothing would happen and after a few seconds the orange "off" light would return.
    Now it just so happens I have a full electronics bench at my disposal at work, but I do not normally work the floor (I'm the sales director, lol) and only have basic skills myself. I do have my brother's help, and he has repaired his XBOX360's and such... so really I guess I just need a direction.
    I assume the best first move is to open 'er up, see what's cookin'?
    If you all have any suggestions for how to diagnose the issue, or general ideas about what to check... it would be greatly appreciated. I think once we are pointed in the right direction it is only a (I hope very short) matter of time before I once again have a working tv.
    Thanks a million!!!
    Le Curious Goose
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Poor Old Vizio (VW26L) Died on Me...
    You might get a retiredcaps bonus point if you include a shot of the bench.
    Post clear focused top down view pictures of all your boards following my sig file below exactly.
    With the LED going on/off, you could have bad caps causing unstable power to the main board or you could have a bad voltage regulator. These two seem to pop up regularly on Vizio branded products.
    --- begin sig file ---
    --- end sig file ---
    • CuriousGoose
      • May 2012
      • 5
      I shall get right on those photos, boards and benches! I also promise to not be a noob... I will use the attachment function instead of ridiculous 73rd party hosted site links. PROMISE!
      • CuriousGoose
        • May 2012
        • 5
        Well, here is a picture of *one* of our benches... and some of the equipment I have at my disposal... now if I could only find my box for my TV so I could bring it in!
        Should have pics of the boards by weeks end!
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          thats a helluva bench!,lucky barsteward
          fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
          please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
          • cashkennedy
            • Aug 2011
            • 668
            I just fixed one of these models too, the 3 10v caps (that are used to filters a 15v rail) go bad. Capxon (aka crapxon) is the worst brand of capacitors known to man. You should see them buldged and leaking when you open the set. Replace the 35v caps as well as theyre also crapxon, but are less likely to fail first before the 10v ones which were way to low rated to begin with for the application. (Replace with 16v or better)
            Your problem might be something else though, but i can pretty much guarantee you those caps will be bulged and leaking.
            https://www.badcaps.net/forum/showthread.php?t=16169 this thread shows the power supply, but covers a different issue.
            Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
            • CuriousGoose
              • May 2012
              • 5
              @cashkennedy - THANK YOU!!! Life has not permitted me the time as of yet to open the beast up but these will be the first I check!!!
              • CuriousGoose
                • May 2012
                • 5
                UPDATE!!!!
                IN FACT the 10v caps were all bulgy and gross... put them on order and should have them tomorrow (YAY MOUSER!) or Friday.
                Hopefully replacing all of those caps will fix it, if nothing else I shall post here after I finish knocking the Crapxon out of my set
                • Zilidian
                  • Sep 2013
                  I have the exact model with a somewhat similar issue - but upon opening up the TV; there are no bulging caps or leaking - everything looks great in there.
                  I turned it off one night and it has never turned back on.
                  1. Orange light is on and does not go off after hitting power button (tried remote too)
                  2. I tried to "reset" by unplugging - waiting 15 secs and plugging back in - when I did this the orange light would not come back on and TV was still dead.
                  3. Left unplugged overnight and when plugged back in the orange light came back but TV is still dead.
                  Any suggestions?
                  Thanks,
                  • truep
                    • Aug 2010
                    • 373
                    What brand and series caps did you use?
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      I would love to have a bench like that. There needs to be a drooling emoticon. DROOL DROOL
                      • Ltank
                        • Jun 2013
                        • 776
                        Nice workbench there Mulimeter! I see Ham radio and Heathkit items too. I used to two way radio .
                        I did not use it anymore. Kept Freq meter.Dispossessed of dummy load, SWR METER, deviation meter
                        • darren19822000
                          • Apr 2014
                          i have this exact same issue..pulled it open to find a few bulging capacitors...now i have no idea how to fix it. is it worth it to repair it and hope it doesnt blow again or just get a newer set. my tv is about 4-5 years old
                          • SS454
                            vizio e650i-a2 backlight flashes then turns off
                            by SS454
                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                            panel: au optronics T650HVN05.4
                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                            08-20-2020, 03:57 PM
                          • mrtek
                            Vizio M65-C1
                            by mrtek
                            Hi.
                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                            07-14-2025, 07:28 PM
                          • howardc64
                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                            by howardc64
                            Failure Symptom
                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                            Where is the short?
                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                            05-27-2025, 02:56 PM
                          • howardc64
                            Vizio SmartCast TV software bug that looks like hardware
                            by howardc64
                            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                            11-16-2024, 05:17 PM
