What are yall using to clean LCDs
  • cashkennedy
    • Aug 2011
    • 668
    I fix quite a few tv's so am pretty carefull not to touch the screens, but the majority i get come dirty to begin with. Usually you can clean them up fairly easily, just be carefull not to drag the dirt around or youll get fine scratches on the bezel for the most part.
    But occasionally theres one with really oily finger / smudges on the screen that stand out when the screen is off, and you look at the right angle...
    My default cleaning solution is 20% isopropyl alcohol / 80% water, and some really stiff paper wipes that dont lint up the screen. But that doesnt seem to get the oilyest fingerprints off.
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
  • mariushm
    • May 2011
    • 3799
    Re: What are yall using to clean LCDs
    Microfiber cloth with a few drops of water:
    http://www.amazon.com/Microfiber-Cle...7115685&sr=8-6
    http://www.amazon.com/Microfiber-Cle...7115685&sr=8-8
    Not the towel ones, these finer ones.
    On some monitors, it's a bad idea to use isopropyl alcohol or any kind of alcohol, just water is enough.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      ordinary glass cleaner + a microfiber cloth (preferably not a brand new one that still "lints out")
      • cashkennedy
        • Aug 2011
        • 668
        Yeah i know viewsonic recomends not using isopropyl alcohol. Thats why i dilute it fairly strongly to only 20%. But i believe (from experience), that it just causes a streaky finish on viewsonic monitors.
        And what do you mean by ordinary glass cleaner > the standard here in US is amonia based windex > but most fake windex's are just water + evaporation agent + blue dye.
        It is usually stated in the manual for most sets to not use ammonia based cleaner. But the ones that are just water that evaporates quicker might be safe.
        • mariushm
          • May 2011
          • 3799
          Ordinary glass cleaner is not recommended, they often have more chemicals which can attack the surface of the LCD screen.
          Windex I'm sure is bad.
          There are LCD cleaning substances, they're usually distilled water plus perfume and maybe a bit of isopropyl alcohol, but regular water is often better.
          My Samsung monitors came with microfiber cloth and also said regular water should be used only.
            No cleaner with AMMONIA.
            • mendota
              • Aug 2012
              • 5
              • cascadia
              just whatever we have in stock. any glass cleaner should do the trick, so long as you're actually cleaning glass, you don't spray the screen directly, and you let it evaporate.
              • t.j.
                • Apr 2010
                • 383
                • canada
                most contain ammonia...so again, not recommended to uses glass cleaner!
                light soapy water mix! works real well, then once tv screen is done ya just continue on to the walls!
                • ecking767
                  • Oct 2009
                  • 492
                  Water and two micro fiber cloth, nothing else it needed. wet one cloth and leave the other cloth dry. Wipe with the wet cloth and dry with the other.
                    Damp cloth, then dry it off. Works perfect.
                    • killian6pk
                      • Apr 2010
                      • 502
                      If you have a Big Lots store they have Endust for Electronics LCD and Plasma Wipes. Says they are Alcohol & Ammonia Free and Anti-Static. I think they also go under the name Odd Lots in some areas.
                      Have you ever stopped to think and then forget to start thinking again?
                      As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
                      • multimeter
                        • Jan 2011
                        • 739
                        • united kingdom
                        karcher pressure washer
                        fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                        please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                        • mendota
                          • Aug 2012
                          • 5
                          • cascadia
                          Originally posted by t.j.
                          most contain ammonia...so again, not recommended to uses glass cleaner!...
                          i'm new at the whole electronics repair thing, so i have to ask, why do you guys avoid ammonia?
                          • multimeter
                            • Jan 2011
                            • 739
                            • united kingdom
                            ammonia will cause some screens to go a "milky"color due to a reaction with the plastics in the lcd layers,may be ok on some plasmas though as long as they are true real glass,then again you could use any window cleaner spray for them
                            • mendota
                              • Aug 2012
                              • 5
                              • cascadia
                              yeah, when i said glass cleaner for glass, i was thinking of the protective screen on plasmas. that's good information to know about LCD screen plastics.
                              • rickybennett
                                • 26
                                • usa
                                Philips lcd gel cleaner and 2 soft wash cloths one to wipe and another to dry
                                i figured out that if you don't use 2 cloths like that wither its a window or electronic screen you will get smears every time
                                other then that if there no finger prints on the screen i just use a swifter micro fiber duster thing on it
                                • ClockChip
                                  Isopropyl alcohol as a cleaning agent?
                                  by ClockChip
                                  Hello All,
                                  I wanted to check with the board before I do anything foolish and/or irreversible. Can someone please set me straight on the use of isopropyl alcohol to clean electronics? I understand it is commonly used to clean electrical contacts. However, in this case, I am wondering if I can safely immerse a small electronic item in alcohol provided a) all power has been removed and b) I take care to dry it thoroughly before re-applying power.
                                  The short version is that I am seeking to clean an older used (well-used) electronic item. The basic plan is to immerse it in...
                                  03-16-2024, 12:10 PM
                                • ronaldopdias
                                  14" MacBook LCDs - has Apple re-introduced a new serialisation type?
                                  by ronaldopdias
                                  Since about a month or two ago, we've observed a new type of 'serialisation' on the LCDs and we're just curious whether anyone has seen this
                                  • New LCDs straight from the factory (not programmed)- if the Mac is restarted or switched on from a cold boot, you must close the lid, then open it again (so two cycles of opening and closing the screen) in order to get display.
                                  • Transplant the IC onto another screen:
                                    • If the model and revision match exactly then it will perform as normal
                                    • If the manufacturer matches exactly BUT its a different revision, the colours are mostly in
                                  06-28-2025, 09:56 AM
                                • totof
                                  Samsung UE55JS9000 backlight issue
                                  by totof
                                  Hello.
                                  I'm sharing with those in the know a problem I'm having with my Samsung UE55JS9000T TV, which has a backlight fault with halos of light on the sides (see my photos). This is a model with LED strip backlighting on the sides.
                                  I took the TV apart to remove the panel and noticed that the "yellowish" film on the Plexiglas light diffusion plate was stuck to the LEDs. When I peeled it off, it left marks on the Plexiglas plate, which I cleaned as best I could with rubbing alcohol (see photo).
                                  The result isn't perfect, but it still seems pretty good to me.
                                  10-05-2025, 08:27 AM
                                • wankio
                                  My cat peed on my monitor
                                  by wankio
                                  So when i bought this dell2515h, i think plastic frame is not tight enough to prevent it, i can pull 0.5cm plastic frame on this area.
                                  picture1 :
                                  I thought my screen auto off cuz power-saving but it not at the time i'm noticed cat peed on it. So i tried to turn it on but it won't, then i clean plastic frame and pull 0.5cm to clean with alcohol 70*. At this time screen is on, but brightness drop from 100% to zero slowly, some fracture images,etc... (still no vertical lines on this area yet)
                                  So i used hair dryer on that area, at first time, one vertical lines...
                                  03-20-2023, 10:20 PM
                                • jkruns
                                  M1 A2338 screen and touchbar issues after cleaning up liquid damage
                                  by jkruns
                                  This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                                  My patient is an A2338 Macbook Pro M1 (late 2020).
                                  It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                                  04-22-2024, 06:45 AM
