sony bravia lcd klv-37s400a restart
  • MADY
    • May 2012
    • 17
    • COTE D'IVOIRE
    when it starts, it stays on moin one minute and turns off. he does it restart only
    Re: sony bravia lcd klv-37s400a restart
    Do you have a camera... can you take pictures of the inside of your TV?
    Notice you live in Cote D'iovre, so how easy will it be to get parts? Do you have many electronics shops/distributors?
    • hoadle
      • Jul 2010
      • 174
      "when it starts, it stays on moin one minute and turns off. he does it restart only" look like the digital mainboard is bad (its control on/off and TV function)
      open the TV & take picture and pot this thread
      • MADY
        • May 2012
        • 17
        • COTE D'IVOIRE
        It is true that I am in Ivory Coast, but we have the possibility to have the parts. as you ask here are photos of the card. thank you
        • selldoor
          Slow Learner
          • 7870
          Hi- Pictures need to be a bit sharper
          Examples of what is needed
          https://www.badcaps.net/forum/attach...1&d=1290283049
          https://www.badcaps.net/forum/attach...7&d=1280167246
          It will be useful if you can say a bit about yourself - skills tools etc
          Do you have a multimeter and can you use it?.
          Can you do a picture of the inverter board - one down left side in pic 1
          Do it in 2 halves - overlap
          When you switch on does the screen light up then go off.
          What do the LEDs do - stay on/ flash/ change colour
          "he does it restart only" what do you mean? Does it try to restart after it goes off.
          Service manual - here:
          http://elektrotanya.com/sony_klv-26s.../download.html
          • MADY
            • May 2012
            • 17
            • COTE D'IVOIRE
            in fact I am a technician and I'm used to depanner.Mais it is now that I work on LCD, PLASMA. Also I have a multimeter that I know and use lots of other equipment. I want to distinguish from other technician here because they do nothing but tinker. Otherwise when you turn on the screen, it stays on for a miniute to moin and he died. and after two minutes, it turns back on then back off. no flashing LED to assert an error code. thank you
            • selldoor
              Slow Learner
              • 7870
              • MADY
                • May 2012
                • 17
                • COTE D'IVOIRE
                I'm not too bright in English so that I have a little trouble following you but thank you for help.
                • tibimakai
                  • Jan 2012
                  • 3680
                  I had a 40W4150 which restarted like three times and then it gave me a 10 blink code. I have reset to factory, did a firmware update and stopped doing that.
                  • MADY
                    • May 2012
                    • 17
                    • COTE D'IVOIRE
                    OK. thank for a suggestion
                    • milha
                      • 48
                      • Czech republic
                      Hi. I have LCD Sony Bravia KDL-40W5710 and the same problem. Can you tell me, please, how shall I do the reset to the fastory and the firmware update? There is no time. The TV turn after 3 seconds off. Thak you wery much! Miloš
                      • selldoor
                        Slow Learner
                        • 7870
                        @Mady - I think I was on holiday and missed following this up. On the inverter board
                        there is at least one fuse that I can see - did you test it?
                        • milha
                          • 48
                          • Czech republic
                          I have no fuse on the inverter, bud the inverter is OK. I need to know, how can I do the reset and the firmware update. Do you know it? Miloš
                            It might be done with the USB port. Maybe Sony has firmware on their website.
                            • milha
                              • 48
                              • Czech republic
                              Bud the TV can't turn on! I need to do reset first! My question is: How to do? Miloš
                              • selldoor
                                Slow Learner
                                • 7870
                                @milha My post was directed at MADY but if you look at MADY's picture 3 there is a small white fuse just above the connector. It is at F4 which might suggest there are other fuses on that board. Do you have a different board?
                                • milha
                                  • 48
                                  • Czech republic
                                  @selldor Yes, I heve a different board and a different fault. I need to reset the TV. Miloš
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    On the model that I have worked I had to hold the arrow up from the remote while I turned the TV on from the TV's power button and then let go the arrow up button.
                                    • milha
                                      • 48
                                      • Czech republic
                                      I am sorry, I didn't succeed to do reset bei the model LCD Sony Bravia KDL-40W5710 by this way. Good luck to you! Miloš
                                      • MADY
                                        • May 2012
                                        • 17
                                        • COTE D'IVOIRE
                                        Seeldoor. thank you. but I gave the TV to the owner because he was too impatient.
                                        • PopsCaps
                                          Sony Bravia KDL-40V2500 that will not power on
                                          by PopsCaps
                                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                          I do not hear any sound and I cannot see any backlight.
                                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                          03-25-2025, 11:23 AM
                                        • justin35
                                          Sony bravia kdl-43w755c - boot loop
                                          by justin35
                                          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                          from what i read online it looks to be an emmc issue…
                                          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                          i took out the board and say an samsung 16gb emmc
                                          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                          i could try to put one instead of the 16gb one, but will it work?
                                          where do i get the software from?
                                          any help will be much appreciated!...
                                          03-06-2024, 12:26 PM
                                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                                          10-16-2024, 05:15 AM
                                        • Spc.
                                          Sony Bravia KD43XF7596BAEP - Android no picture
                                          by Spc.
                                          Greetings everyone.
                                          I also have Sony Bravia, model:
                                          Sony Bravia KD43XF7596BAEP - Android.
                                          What happend is that image dissapeared while we were watching tv.
                                          Diagnostics:
                                          1. TV turns on, no errors
                                          2. Backlight turs on, no errors
                                          3. Power indicator turns on, white color, no errors
                                          4. Menu works on android, you can hear sound while switching channels
                                          5. Volume up and down works via TV remote and via buttons
                                          6. Tunner works, HEVC / MPEG-4 decoder works
                                          7. I get audio from channels
                                          8. No picture is present,...
                                          05-19-2022, 04:28 AM
                                        • davidebeatrici
                                          Sony M851 MBX-217 no POST and restart loop
                                          by davidebeatrici
                                          Before proceeding with a component level repair, the usual troubleshooting process was followed:
                                          1. Disassemble and unplug everything except the power connector.
                                          2. Replace RAM.
                                          3. Replace CPU.
                                          4. Rewrite BIOS.
                                          Unfortunately the board was still stuck with a 0.75A power consumption at 19V.
                                          After reflowing both GPU and north bridge in one shot (it can't hurt) there was an instant improvement with a constant 1.75A power consumption, but I immediately noticed smoke and the typical smell coming from the GPU area.
                                          I thought to myself "Well,...
                                          07-03-2025, 04:19 PM
