RCA LED 42A55R120Q no picture
  • aura64
    • Apr 2012
    • 3
    Hello all and thank you for allowing me to join your great group.. I have a RCA LED 42" model: LED42A55R120Q its power up fine and can not change input source or change channels, it shows in the screen a small window at the bottom of the screen like someone is pressing the remote button to lower the volume, so it shows the number "0" for lowest level of volume, and stays there like someone have the lower volume pushed all the time. I have remove the batteries from the remote and still the same, also pushed many time the buttons behind the TV, and unpluged the power still the same. Any insight on this would be greatly appreciated ....
    Re: RCA LED 42A55R120Q no picture
    So the TV functions fine, but the volume is constantly stuck at zero?
    You have taken a good step by cleaning the buttons as this is a #1 cause. However, sometimes the buttons get stuck inside.
    When you open up your TV, remove the button board and see if the problem cures itself. Then, to cure the problem permanently (while still having buttons), use a bit of contact cleaner on the buttons. I had a similar problem with a TV that would turn off as soon as you turned it on.
    • aura64
      • Apr 2012
      • 3
      Hi tom, yes the TV functions fine, but the volume is constantly stuck at zero, I have opened up the TV, and removed the button board, but the problem still the same.
        With the volume 0 display showing can you access the setup menus?
        • truep
          • Aug 2010
          • 373
          maybe the mute button on the remote has been pressed?
          • selldoor
            Slow Learner
            • 7870
            If you unplug the button bar can you change the volume using the remote or is the remote sensor in the button bar?.
            You can check if the remote is sending signals by aiming it at a digital camera
            and viewing it on the camera screen.
            • aura64
              • Apr 2012
              • 3
              This is what I have tried, removed the batteries of remote control, and unplug the button bar at the same time, and still the same, then I tried with the cable box remote and still the same, then remove batteries of both remotes and still the same.
              Tom, I have no access to the setup menus
                Can you post a picture of the main board, the button boards, and the overall layout of your TV?
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • karthur
                  Vizio D65x-G4 Volume changes on its own
                  by karthur
                  On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                  It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                  06-05-2025, 08:13 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • freethink
                  Kenwood KR-A70 Receiver Balance changes with volume controls?
                  by freethink
                  I have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
                  11-23-2025, 07:53 PM
