Emerson EWL20S5 double image on screen
  • DakotaKid
    • Nov 2010
    • 165
    This TV was given to me and I plan to fix it and put in my garage to watch while i work out there. It's a 20" LCD, DVD quality picture but not HD and not widescreen. It has a single mainboard with everything except inverter circuitry and then a separate inverter board. The mainboard appears cheaply made but surprisingly well labeled. This board must also be used in a combo TV /DVD unit as it has markings for those components (not installed) as well. No apparent burns or damage on either side of the board.
    Symptom: TV will power on and show blurry ghost double image, one on top half of screen and one on bottom half. After it warms up the image becomes very clear but still displayed once at top half and once on bottom half. For instance, blue background with "VIDEO 2" displayed twice when no input signal is attached. Caps around power supply section are not bulging or leaking but are of a brand I have never heard of and I assume very cheap and prone to failure. The voltages are fairly close to expected values EXCEPT the panel 10.8V supply is actually 12.7V. The 5V is 4.86V.
    I am attaching a picture of the board, a closeup of the power supply section. I downloaded a schematic at elektrotanya, excerpt attached relevant to mainboard.
    I did find a discrepancy that I cannot reconcile and would appreciate any help. The voltages at Q503 on the schematic vs actuals are B=11V (actual 13.25V), C=13.6V (actual 19.25V), E=10.8V (actual 12.7V). Q503 is a KTD2059 transistor. Capacitor C503 (220uf/16v) and diode D504 are in the same circuit leg.
    Hope this all makes sense to someone out there that can help.
    Thanks in advance.
    DK
  • DakotaKid
    • Nov 2010
    • 165
    Re: Emerson EWL20S5 double image on screen
    Anyone help with this one? Thanks.
    • retiredcaps
      • Apr 2010
      • 9271
      I assume this TV has a t-con board? If yes, have you tried cleaning and reseating all the connections originating from the board?
      --- begin sig file ---
      --- end sig file ---
      • selldoor
        Slow Learner
        • 7870
        Didnt want to be the one to say it, but your pictures are poor, It is really all we have to work on. They should look like these:
        Examples of what is needed
        https://www.badcaps.net/forum/attach...1&d=1290283049
        https://www.badcaps.net/forum/attach...7&d=1280167246
        • DakotaKid
          • Nov 2010
          • 165
          No offense taken but it's all I had at the time and they were (a little) better than nothing. Since there is no evidence of bulging caps or burnt components I thought the schematic I attached and the actual voltage readings that I gave would be more helpful.
          I will clean the contacts leading to the LCD panel and will report back but I am still confused about the voltage readings around Q503 and the 12.7V instead of 10.8V at that test point.
          Thanks all.
          DK
            "The voltages at Q503 on the schematic vs actuals are B=11V (actual 13.25V), C=13.6V (actual 19.25V), E=10.8V (actual 12.7V). Q503 is a KTD2059 transistor. Capacitor C503 (220uf/16v) and diode D504 are in the same circuit leg. "
            Q503 is setup as high current pass transistor Emitter follower with the regulated (TL421 Ref Diode) Base voltage to ground that should be 11.4V to get 10.8V (11.4v – 0.6v (Base-Emitter junction Vbe) out at the Emitter.
            Right now the Base Voltage to ground is 13.25V, so minus 0.6v, you will get 12.65V as you have measured.
            So the problem can be the 2.5v Ref Diode D505 is bad or the voltage divider resistor network R514, R516 (I left out R515 because it is a jumper) are out off value.
            From my calculation to what you should get at the Emitter of Q503, it should be 108v as designed.
            Vo = Vref(1+ R514/R516)
            Since Vref is 2.5V, then Vo = 2.5(1+10k/3k) = 10.833V.
            One thing that bothers me as far as the accuracy of the voltage labeling is not right.
            If you look at D636, the output that goes to the output pin is labeled with +40v, but this same voltage also goes to Collector of Q504, and it is labeled as 36.7V, so I am not sure what to trust. You may have to verify a bunch of voltages as labeled and as measured.
            • DakotaKid
              • Nov 2010
              • 165
              Thanks a lot budm. This helps me understand and begins to explain. The schematic pdf I uploaded in the OP had an addendum page that listed changes to R514 (6.8K) and R516 (1.6K) so if Vref is 2.5V then Vo becomes 2.5 (1+6.8k/1.6k) = 13.125V which is near (13.25V) what I read at that point. Furthermore, version "C" added four 10 Ohm resistors in series between the middle legs of Q503 and Q401 (on the 22V inverter circuit). I found and added the board diagram to the pdf that shows those four resistors near where Q504 is. Since the schematic published didn't have the updated components in it I guess it is possible that the expected voltages all change too...including the 10.8V that is reading closer to 13.7V. I will take the readings that you highlighted and post back here.
              Again...thanks for your assistance.
              DK
                Can you also show the whole back of the TV as how the boards are connected together and the picture of the LCD panel assembly?
                • DakotaKid
                  • Nov 2010
                  • 165
                  Per your diagram:
                  AL +13 reads 12.8V
                  Panel -6V reads -5.98V
                  Panel +25 reads 23.3V
                  Panel +10.8V reads 12.7V
                  Protect-1 reads 3.3V as expected from Q507
                  btw, this "double image" problem is common on this TV per google search but I haven't found anyone who actually solved it. I removed the LCD ribbon cables from the mainboard to the T-con and reseated them and it had no effect. Also, while the TV was operating I slightly flexed the ribbons at the LCD panel and nothing changed so they seem to be attached securely. I will put up a picture showing all of the connections soon.
                    You may want to try cooling using a can of compressed air duster upside down to get cold sray on the board on the LCD panel, and also hairdryer to see if it has affect on the pictures.
                    • selldoor
                      Slow Learner
                      • 7870
                      I have just been looking at the full version of the service manual.
                      It is not encouraging that the first items relate to instructions on removing/
                      replacing the video chip. Leads me to think there is a known problem and
                      either the chip needs replacing or a new board.
                      The second section however tells you how to set up the ordinary remote control to turn it into a service menu control. It may be that by adjusting some of the settings you could stop it splitting.
                      • DakotaKid
                        • Nov 2010
                        • 165
                        I also thought that was a bit alarming to see that section dedicated to replacing the SMD video chip. I saw the part about the service menu but unfortunately I don't have an original remote. The TV is acting odd when playing a movie, as if something isn't responding quickly enough. It is sort of like watching slow motion frame advance where the screen blurs because it seems it can't keep up with displaying the changing input signal, like something isn't switching fast enough. Not sure if that is the video chip, the T-con or the actual display. And heck, it could all go back to voltage problems from bad caps or regulator I suppose. I still wonder about that 12.7V instead of 10.8V output in the power/regulator transistor section.
                        Maybe this thing belongs on CL for the next guy to take a shot at!! LOL.
                        • dicky96
                          HP Elitebook Screen blank - backlights but no image
                          by dicky96
                          Hi guys
                          I'm trying to fix this laptop screen
                          Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                          OK so I have the original screen which works but has lines across the bottom quarter of the screen
                          I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                          04-28-2021, 07:30 AM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • speedtime07
                          i life zed air cx5 no image on screen
                          by speedtime07
                          hi everyone ,
                          There is an image on the external computer screen ,
                          flexi cable test ok - screen test ok -
                          What alternative should I look for?
                          thank you for your support​
                          04-10-2025, 06:24 AM
                        • smic717394
                          by smic717394
                          07-25-2024, 10:16 AM
                        • Khoja
                          Fluke 123 no image on the screen
                          by Khoja
                          Hello experts,
                          I recently purchased a used Fluke 123 Industrial Scopemeter from an online Japanese auction site (jauce.com). It has now been delivered. Unfortunately, I overlooked the fact that the seller neither guarantees its working condition nor accepts returns.
                          When I power it on, the backlight comes on, but there is no image on the screen. After opening the device, I noticed clear signs of previous soldering in several areas (photos attached). It seems someone attempted repairs before.
                          At this point, I'll have to try and fix it myself. Has anyone here...
                          04-10-2025, 09:24 AM
