Re: sharp lc32sb24u bulb / inverter problem
When you have two lamps in series, if one is not lit, its impedance will be so high just like an open circuits which is not going to let the current to flow and lights up another lamp in series with it. CCFL has negative resistance, resistance goes down as when the lamp conducts and emits the lights.
The sensing can be done on the hot side also. Most uses the cold side since they will be all tie together then it can sense the total current draw of the lamps.
That will be new to me to have lamps in series and one is lit but not the other one. Will chalk one up in my library for this strange behaving that does not go with the electronics theories. That is why we are here to learn.
I wonder if that 1700v is the strike voltage or running voltage.
