Philips 32PFL6606T 32" LED no back light
  • shepp
    • Mar 2012
    • 377
    • England
    #61
    Re: Philips 32PFL6606T 32" LED no back light
    ill try and get a better picture of the board tonight, my cameras not that great, because the picture of the diodes i tested isnt that clear to see the tracks and how its connected
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      #62
      Originally posted by shepp
      full strip down, but if there is 4 sets of LEDs and only 2 sets are getting the correct 150V surely this means the fault lays on A3 and A4 supply somewhere because there not getting the full 150v there only getting 72v?
      im inclined to think that a1 a2 a3 a4 are paired and 2 sets ie a1 & a2 are running off one transformer and a3 & a4 are running off another transformer,have you tested the voltage with the plugs removed from the board,and tested at the pcb itself? if the voltage comes up at around 150v on the plug footprints then it could be the led network has shorted,but then again an led diode normally dosent go short circuit they go open,its worth a shot before stripping down to the panel to get to the leds,im facing the same problem with a sharp lc-46le700e where i have voltage at the led plugs but backlights arnt turning on with 2 flashing leds on the main board ??,oh hum the saga continues
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • shepp
        • Mar 2012
        • 377
        • England
        #63
        I'll try that when I get home, the transformer that feeds them both has one primary and 2 secondary
          If you've got voltage to the LEDs you probably have an open LED. You need to test each individually which can be done with a meter which puts out more than 3.5V on diode test. Some do - mine does - but not all do. Check with a white LED first. As an alternative you can use a CR2032 coin cell and tape some wires to it; it will make the LEDs light up individually if you power them. The LED which doesn't light up needs replacing but it could just be shorted with minimal affect on the picture, if the LED array is large enough and the diffuser is good. You must test both ways as LEDs conduct only one way and it may not be obvious which way is positive.
          If you have a higher voltage, current limited supply, you can light up a group of LEDs all at once to speed up testing.
          Thinking about it a 16:9 TV will have more voltage on the bottom edge LEDs than the side LEDs as there are less on the side. In fact 150V vs. 72V is about 16:9 ratio (should be 84V on other LEDs, but might be limited by the open circuit in one chain, or the brightness might be different on the sides of the panel.)
          This is just like finding a bad bulb in a set of Xmas lights.
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            #65
            the secondarys are more likely to fail than the primarys,a ring tester would be good to test them if you have one,if you dont it would be a case of testing both the secondarys and see if they are the same within reasonable tolerance
            • shepp
              • Mar 2012
              • 377
              • England
              #66
              Think I checked them and they were the same, but that was in circuit so could be false reading, ill check voltages again with the plug out, and do what tom said if I'm getting the voltage, if not ill take transformer out and test it
                That might not work for SMPS transformers, different # of turns per winding. You have a voltage - that should be enough to make the LEDs glow - but they don't from what I understand.
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  #68
                  i mean the transformers that supply the voltage to the leds,not the smps transformer,thats a point im wondering if the tv has edge lit backlight or compete array of leds all over the screen?
                  • shepp
                    • Mar 2012
                    • 377
                    • England
                    #69
                    I'm not sure on that 1, but ill let you know if I have 2 strip it down
                      Those are just regular SMPS transformers. Measuring the resistance only works for Royer oscillator inverters, which balance current through the CCFLs using the resistance.
                      • shepp
                        • Mar 2012
                        • 377
                        • England
                        #71
                        just checked voltage.... 150v going out to both A1 and A4 , so its souning like a LEDs gone, so gonna strip it down in abit, ill post some pics when ive got it to pieces, problem is the service manual only shows so much so i figure im on my own, just have to be gentle with the screen when i take it off
                        • multimeter
                          • Jan 2011
                          • 739
                          • united kingdom
                          #72
                          before you do ,is there a lead coming from the power supply going to the t con board?and i mean separate from the lvds ribbon cable,check to see if you have the correct voltage,if not then this supply may come from the main board,and could be throwing you a little,most led tvs get there switch on supply from the main board
                          • shepp
                            • Mar 2012
                            • 377
                            • England
                            #73
                            no there is one going to main board then ribbon cables from the main board going to t con (X 2) and other one on power board going to the LED panel
                            • multimeter
                              • Jan 2011
                              • 739
                              • united kingdom
                              #74
                              and are you getting any voltage going to the t con?
                              • multimeter
                                • Jan 2011
                                • 739
                                • united kingdom
                                #75
                                sorry tom yeah your right,just looked at the pic again
                                • shepp
                                  • Mar 2012
                                  • 377
                                  • England
                                  #76
                                  the picture is fine, i can see the menu's and setup screens coming on, its just the back light
                                  all voltages are correct, you went through that with me before
                                  • multimeter
                                    • Jan 2011
                                    • 739
                                    • united kingdom
                                    #77
                                    right you are ,time to test the leds then,make sure when you take out the diffuser sheets you dont get any dust or hairs inbetween on re-assembly ,if you fix the dud led or led rail,it will show through when the pic comes up,i usually use a can of air duster
                                    • shepp
                                      • Mar 2012
                                      • 377
                                      • England
                                      #78
                                      would it be a wise move to wear some powder free latex glove? so i dont get finger prints on anything?
                                        As long as you don't touch the inside of the LCD, you should be fine - but it doesn't hurt to take precautions.
                                        • shepp
                                          • Mar 2012
                                          • 377
                                          • England
                                          #80
                                          oooo my god what have i done...
                                          ill post some pics after ive eaten, but the LEDs are round the edges top and bottom, i havent managed to take the suspected strip off yet....my diners nearly ready
                                          this is scary stuff....i really dont wanna damage the screen, but its out and safe with all the glare etc sheets, god knows how im gonna solder the new LED in...thats if i can get one(if i can find the one thats gone)
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                          • PNI E.
                                            tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                            by PNI E.
                                            hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                            02-20-2025, 08:36 AM
                                          • biogon
                                            PHILIPS 42PFL7404 no back-light
                                            by biogon
                                            I have a problem with the back-light on a 12-years-old PHILIPS 42PFL7404 TV with DELTA DPS-298 power supply. Screen time is 11000h. A month ago the image started to flicker slightly and after a minute it turned off, but keeping the audio. It was necessary to disconnect from the line to turn it on again, with the same symptoms (Error code:17). The PSU seems to have all the components and welds fine. For a while I ran it without the back cover and it held up well without shutting down. With a heat fan I looked for the susceptible area and found it in the return circuit and supervision of the power...
                                            09-14-2021, 04:44 AM
                                          • koby058
                                            vostro comes up with back light but no picture
                                            by koby058
                                            Hi people!!
                                            The owner said it showed bad picture once in a while (attached)
                                            I see that there is back light but no picture.
                                            I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                            Also attached schematic and BDV
                                            LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                            07-13-2025, 01:03 PM
                                          • djordje
                                            Philips 55 oled 804/12 red light blink
                                            by djordje
                                            Hello all,
                                            I have Philips Oled 55 (804/12) with black screen and red light blink.
                                            I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                            Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                            When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                            My questions is what should i do next...
                                            01-03-2025, 04:00 PM
