Whestinghouse LTV-32w6hd has sound but no picture
  • high-tech
    • Sep 2010
    • 197
    This one is out of my knowledge base. The backlight comes on and stays on and I get the blus screen with all OSD Functions except it wont auto scan for channels. Sound works, All the voltage regulators are clearly marked on the logic board and all voltages are @ spec per regulator. I only found 3 of them unless there is more on the back side of the board. I also measured the voltage going to the t CON board and its @ 5.01 volts. HELP Please!
  • selldoor
    Slow Learner
    • 7870
    Re: Whestinghouse LTV-32w6hd has sound but no picture
    Hi does it work with other inputs PC/ Scart/ HDMI.
    Is there some discoloration on the top of the tuner box or is it just an unlucky coincidence that the flash or light is bouncing on there making it
    look so
    • high-tech
      • Sep 2010
      • 197
      None of the inputs will post any video to the panel. That discoloration on the tuner is the light for the ccd sensor on my camera
      • selldoor
        Slow Learner
        • 7870
        Two things to try
        Did you go into the source settings with the remote to change the source
        on the OSM when you tried the DVD for instance.
        If the main source is set on something you did not try it may not recognise it?
        Can you check that the child lock for all inputs is set to off.
        • jackslater
          • Jan 2012
          • 20
          Check t-con cable it was bad on mine
          sound no video
          white flat cable
          bad on 1 pin on t-con side of card
          scrubbed all pins with brush and alcohol 91%
          re tin the pin with solder
          check end end with ohm meter - 1 ohm
          bad pin was burned and read 6 + plus ohms
          fiixed mine--
          this after check main board to make sure working right- mine had bad regulator-
          fixed - and the had sound and back light - no video
          trick above fixxed video
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • slimmy182
            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
            by slimmy182
            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
            Looking on google I found this:...
            01-14-2023, 11:55 AM
