Akai LCT3201AD black screen in 2-3 sec
  • mcross
    • Sep 2011
    • 201
    Ok i know its junk but trying to help out a buddy, its a Akai LCT3201AD ,
    Power supply is putting out correct volts on all pins, recaped alot of bad 220uf on the main and tuner board, get geen light and screen for a few sec, power light stays green and volts remain good to inverter. inverter bad? have done the 1 back light at a time thing , no good. ? any ideas?
    can post pic's but no sure theres a need with the info i have.
    Mike
  • tibimakai
    • Jan 2012
    • 3680
    Re: Akai LCT3201AD black screen in 2-3 sec
    http://blog.coppelltvrepair.com/2011...not-power.html
    • mcross
      • Sep 2011
      • 201
      Thanks for the link , but been there done that on power supplys. Mine is getting and maintaning correct voltage, but black screen in 2-3 sec after start up. Do you think i missed something?
      mike
      • retiredcaps
        • Apr 2010
        • 9271
        2 seconds to black can be
        a) bad ccfls
        b) bad ccfl wiring
        c) bad inverter transformer (secondary windings)
        d) bad caps
        All explained with posts #19 and #20 at
        https://www.badcaps.net/forum/showthread.php?t=10419
        --- begin sig file ---
        --- end sig file ---
        • Jasgriff
          • Feb 2012
          • 578
          Try what retired caps suggests in his post and let us know you findings. If it was me I would make sure that u can see your desktop with a flashlight. This means you can focus on why the CCFL's aren't working.
          Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
          How to resize your pictures guide click HERE
          Retiredcaps Ideal post example click HERE
          • mcross
            • Sep 2011
            • 201
            will do and let you know
            Mike
            • mcross
              • Sep 2011
              • 201
              Ok did some checking, have sound and fant video, just no back light , have replaced around 20 220uf caps all bad (tested with my blue ESR meter) a few 470uf and a few 22 uf, . all caps on ps, most 220uf where on the main board and tuner, inverter is getting 24 v , all transformers test same. I am stumped.
              Mike
              • retiredcaps
                • Apr 2010
                • 9271
                If you have no backlight versus 2 seconds to black, that is totally different.
                Absolutely no backlight (i.e. no 2 seconds to black) can be
                a) open fuse or fuses
                b) shorted mosfet or transistor on the inverter board
                c) bad inverter pwm chip
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  I dont think he means NO back light as in post3 he says it is on for 2 to 3 secs.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    But now in post #7, he says no backlight so something might have changed?
                      No pictures of any boards either.
                      • mcross
                        • Sep 2011
                        • 201
                        Ok guys to clear this up abit, had 2 sec to black, replaced what ended up to be close to 30 caps, then got no back light, and then found a bad transitor on the inverter, now all is good, works like new, by the way most ever cap replaced was 220uf, and few others
                        Thanks all
                        Mike
                        • mrwebo
                          • Jun 2013
                          • united states
                          which was the transistor you replaced I have the same problem and Replace the capacitors that were bad the volatages correct font need your help please I would greatly appreciate it from ... thanks
                          • mrwebo
                            • Jun 2013
                            • united states
                            hello sorry the supply voltages are correct Replace capacitors 470uf and 220uf but still turns on and shows the logo of akai and off and the LED remains lit in green I think is the problem of inverter.
                            What is the transistor that was damaged in your case please driving me crazy this tv. sorry for the English but I use google translator ...... thank you very much
                            • mrwebo
                              • Jun 2013
                              • united states
                              I think it is an inverter transformer and measured with the multimeter the tips of this and gives me strength 180khoms and others give me a measure of 1.5 khoms think that's it.
                              how I can do to turn the trick to remove the transformer protection system or something please help
                              • HTR-Informatique
                                Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                by HTR-Informatique
                                YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                I also changed the screen because the PC fell and the screen was broken.
                                I changed the battery with a new and original battery.
                                I also had corrosion/oxidation on the...
                                02-09-2025, 06:51 AM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • VcemPzd
                                Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                by VcemPzd
                                Hello everyone !
                                My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                04-28-2025, 10:14 AM
                              • DaniK
                                Acer Aspire E5-574-52RH - black screen
                                by DaniK
                                I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                Symptoms are:
                                - random black screen after displaying Acer logo...
                                02-21-2024, 06:27 AM
                              • turmix
                                AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                by turmix
                                Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                During another reassembly, I made a mistake, and...
                                01-29-2024, 03:48 AM
