polaroid tla-04011c
  • mochamedics
    • Mar 2012
    • 11
    • usa
    polaroid tla-04011c
    hello all trying to fic my lcd tv to start with i got it you had to turn it on blue light came on flashed for a second then nothing i left it on 10 minutes turned it off then back on worked great . so i used it just warmed it up ,then about a year ago just the red light , bought a main board not power supply board off ebay and it worked again as long as you warmed it up lasted a year now it turns blue light on flashes for a sec then blank no matter how long you warm it up,took back off looking for bad caps no buldge or burn .today it will turn blue light on flash and wont turn off just blue light on .i have a volt meter and am pretty good at fixing stuff any advice would be great thxs
    Re: polaroid tla-04011c
    Please post the good clear pictures of the whole chassis, and then closed up pictures of each boards and connectors, then later on when you take the suspected board out, then we will need the top side and back side of the board. But lets see what the whole TV and the connectors, caps look like first. I think the problem will more likely to be in the power supply.
    • mochamedics
      • Mar 2012
      • 11
      • usa
      here are 3 pics ill remove power supply
      • mochamedics
        • Mar 2012
        • 11
        • usa
        here is power supply front back finer quality
          Are there any voltage labeling on those white connectors on the power supply board, right now your standby power supply is working.
          Do you also still have the old control board, did you try that to see if you have the same symptom?
          • mochamedics
            • Mar 2012
            • 11
            • usa
            v1 gnd v2 remote on top left bottom left is gnd ,v3 no values old board was trashed over a year ago , ps thanks for the help if i know the caps that go bad i can replace them ,
            • mochamedics
              • Mar 2012
              • 11
              • usa
              bump
              • selldoor
                Slow Learner
                • 7870
                BUMP !!! where/who do you think you are??
                You will be lucky to get any help at all doing that.
                You have to be patient with people here: we nearly all have jobs, college and families in the real world and we just help out when we can. I'd guess most of us are not qualified technicians, and just pass on what we have learnt.
                In any case your pictures are very poor - we will not waste our time trying to look at them. - That is why over 80 people have looked at the post and given up!
                As regard the caps make a list of all the Electrolytic ones - make voltage - uf we dont know what is on the board or if they are any good - are any leaking or bulging.
                Are they on the list of Bad/ not very good caps.
                Have you looked for a schematic / service manual for the set/power board.
                • mochamedics
                  • Mar 2012
                  • 11
                  • usa
                  wow little rude arnt we didnt know i upset you like that if you cant help then dont bother being rude .
                    1) The pictures qualities are very poor, I have a hard time tracing out the bottom side of the board.
                    2) Please see the attached PDF, and tell us the voltage reading on the large cap is so we can tell if the PS_ON and PFC is working or not.
                    • mochamedics
                      • Mar 2012
                      • 11
                      • usa
                      sorry about pics from before these are much better and on main cap 409 is reading when on
                        Wells, thanks for the pictures, but they are still way out of focus, I cannot read the designators (white printing to show Rxxx, Cxxx).
                        Since you are getting about 400Vdc on that large cap, more likely the PS_ON is working and it is turning on the PFC Voltage boosting circuits, but not the 24Vdc switching power supply section.
                        Please see the PDF, I need REALLY GOOD CLEAR pictures and we need to find the P/N as printed on the two IC's as shown.
                        • mochamedics
                          • Mar 2012
                          • 11
                          • usa
                          part number are big chip l6598d(top) sti emblem then 91c3638 (bottom) small chip 1653a pnin
                            OK, I will look up the spec sheet tomorrow, it getting late here. Please also post clear pictures in the red area for me.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              An example of what budm is talking about
                              https://www.badcaps.net/forum/attach...1&d=1290283049
                              --- begin sig file ---
                              --- end sig file ---
                              • mochamedics
                                • Mar 2012
                                • 11
                                • usa
                                here is a good pic
                                • mochamedics
                                  • Mar 2012
                                  • 11
                                  • usa
                                  i can get a used power supply for 40 bucks
                                    That is cheap! But I like to verify things just to be sure, but we can only do so much from long distant.
                                    • mochamedics
                                      • Mar 2012
                                      • 11
                                      • usa
                                      yep if you look on the net by part number there is lots of them for around 40 some are 80 just bypass them lol
                                      • Tomylee
                                        Nintendo 2DS XL – Orange light, no blue light, signs of overheating
                                        by Tomylee
                                        Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
                                        Here's what I've observed:
                                        All ribbon cables are properly connected
                                        Battery is present and in good condition
                                        No reaction even with screens disconnected
                                        There's a visible burn mark / overheating sign on the metal shield, right above the CPU
                                        I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
                                        06-26-2025, 02:33 PM
                                      • blind2reply
                                        proscan 40ld45q - no pic -no sound - no backlight - blue light turns off
                                        by blind2reply
                                        proscan 40ld45q
                                        Have tried published resets with no help. (unplug for 10, push on-off for 30, push menu and vol +, etc.)
                                        After being plugged in, red light comes on. Push power button and blue light comes on for ~five seconds then goes out. Power button does not turn the unit on a second time - have to unplug/re-plug before power button will try to start with blue light.
                                        No sound, no picture (used flashlight test).
                                        No bulging cap, no burn spots, no burn smells, nothing visual (cold joints/breaks/bugs).
                                        Digital voltmeter;...
                                        06-06-2021, 01:16 PM
                                      • TurboTundra
                                        PS5 EDM-033 Blue Light 2 Sec then Powers Off
                                        by TurboTundra
                                        Hi, I am waiting for my uart tool so I can grab an error code and narrow down where my issue is, but I decided to measure capacitors and fuses to insure everything was okay.
                                        The PS5 turns on with a blue light and a beep for 1-2 seconds then turns off. I noticed a grey capacitor measures no voltage on standby or input power. Does this indicate a problem with the capacitor or something down on the line? I’m getting 3.3v on input with the red cap next to the grey one, and 5.2v on input with the red cap further away from the grey cap.
                                        Thank you for any input...
                                        06-10-2025, 08:51 PM
                                      • icareservicezone
                                        Synology DS918+ blue light blink
                                        by icareservicezone
                                        Synology DS918+
                                        Model name : GDI41L2
                                        p/N: 08-06GDI4116
                                        Version: V1.6
                                        Problem : blue light blink...
                                        05-24-2025, 11:53 PM
                                      • cajoeg
                                        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                        by cajoeg
                                        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                        02-10-2025, 04:01 PM
