Hey everybody, I was wondering if anyone could help me. I replaced the U33 and U9 chip. During U33 replacement I lost a small resister behind U33 so I simply bridged the resistor. The TV worked fine for about a week and one night while watching a movie the picture became pixelated. It almost looks like a bad youtube video and static. Here are some pictures. The bridged resister the second one to the right of R30. Any ideas or any help would be greatly appreciated. Thanks in advance.
Vizio GV42LHDTV10A Pixelated Picture Problems After U33 Replacement
Tags: None
Re: Vizio GV42LHDTV10A Pixelated Picture Problems After U33 Replacement
You "bridged" a lost resistor, as in you just shorted it out
with a piece of wire?
That's a really BAD idea! Now you have likely ruined another
portion of the circuit.
Can you find out what the original value was? And replace it? -
I simply connected the two points with a small line of solder, bypassing it. I suppose I could read the resistance on the one next to it and try to get one identical to it. Its the size of a flea. (Not easy to solder) I'm a noob at this stuff. A friend gave me the TV for free, so what better way to learn then on something I got for nothing.Comment
I simply connected the two points with a small line of solder, bypassing it. I suppose I could read the resistance on the one next to it and try to get one identical to it. Its the size of a flea. (Not easy to solder) I'm a noob at this stuff. A friend gave me the TV for free, so what better way to learn then on something I got for nothing.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
short, unless you really understand the circuit, and have determined
it's safe to do so.
Yes, you should try to find a schematic and determine what the
original value was. It may be too late for the other parts of the
circuit that may have been damaged, but that would be a first step....Comment
Those 3-pin devices are adjustable voltage regulator, the output voltage is set by the two resistors connected to the left pin of the IC. See LM1117 for example. Why ase they replaced in the first place?
Failed TV's and Monitors: http://s807.photobucket.com/albums/yy352/budm/Never stop learning
What is the value of the remaining resistor? Double check this, but I believe U33 usually outputs 3.3 volts. Searching for U33 Vizio on this site will give you the correct voltage. The calculation is Vout = 1.25 x (1 + R1/R2). R1 is the resistor between pin 1 and pin 2, R2 is the resistor between pin 1 and Gnd.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
by RauniHello, this is my first post on this forum, and my first attempted to repair a TV.
My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
Read also that we should test what happens if we... -
by gavricHello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
When tv powers on vizio V logo shows nice on whole screen. picture 1
When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
When i start youtube picture shows on left side fine, right is all scrambled. pic 2
When i click video to start playing picture goes black(like when you change... -
by MmattThis tv would not power on. I replaced the main board and got it on but the picture is distorted. When the Vizio logo comes on it is split and shows up with half the V on each edge of the screen. Can someone tell me what the problem is?
I've checked the ribbon connections and they look fine. Wiggled them and no change in the picture. Is this a t-con board problem?
by GoldenmonkeyMy samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
by ggil44Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
- Loading...
