Samsung pn59d530a3f no picture after power supply replacement
  • Goldenmonkey
    • Jul 2017
    • 13
    My samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
    after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
    Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
    any help would be appreciated.
  • nomoresonys
    • 12335
    • U.S.
    Re: Samsung pn59d530a3f no picture after power supply replacement
    Go ahead and test the components on that y sus, the transistors on the heatsinks short out quite a bit, you can test them in circuit, best to check all the components that you can, youtube is your friend for how to videos, one of many many there: https://www.youtube.com/watch?v=p8Jf79Qv4PM
    • nomoresonys
      • 12335
      • U.S.
      Can you post a good picture of the area of the original powerboard with the damage.
      • nomoresonys
        • 12335
        • U.S.
        You will need to test the buffer boards and the other sus board too, to be thorough, again youtube for tutes.
        • Goldenmonkey
          • Jul 2017
          • 13
          The original power supply with damage to resistor and capacitor
          • Goldenmonkey
            • Jul 2017
            • 13
            That youtube link, and several of his other videos were very helpful in learning how to diagnose these parts, thank you.
            I am currently trying to remove the y main board. It feels like it is glued to the back of the TV. I didnt want to just pry it off in fear of breaking it. Is this normal? Should I just use some force to pry it off?
            • Biruslapio
              • Nov 2013
              • 552
              • Brasil
              not glue, thermal pads, very thick and wide ones, so remove all connections before you pry it off or it may rip some cable.
              just be patient, you will hear the peeling off as you pull on it, and it should come without flying off the tv.
              • Goldenmonkey
                • Jul 2017
                • 13
                I was able to get it off. Several adhesive strips below it.
                  09-07-2024, 05:50 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • cheeky2
                  Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                  by cheeky2
                  This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                  I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                  Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                  06-15-2025, 05:12 AM
