I have a 3 year old LG 37LC7D, 37 inch TV that powers up with sound but a bright white screen. After 10 minutes, picture comes in and TV works fine until it is turned off, then process starts again. I have replaced all capacitors on the PSB but this did not solve problem.
LG 37LC7D UK White Screen
Tags: None
Re: LG 37LC7D UK White Screen
All capacitors, or just the bulged ones?I have a 3 year old LG 37LC7D, 37 inch TV that powers up with sound but a bright white screen. After 10 minutes, picture comes in and TV works fine until it is turned off, then process starts again. I have replaced all capacitors on the PSB but this did not solve problem.
Sounds like a T-con issue, especially since you have sound. It could also be a connector from the main board to T-con which is loose. Try disconnecting and reconnecting this.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
It sounds more likely the T-CON board is bad or the switched transistor on the main board that supplies the 12vdc to the T-CON board may be bad, you need to check and see if you have 12vdc on the surface mouted fuse on the T-CON board when you get white glowing screen.
You can download service manual from WWW.ELEKTROTANYA.COM
http://s807.photobucket.com/albums/yy352/budm/LG/Never stop learning
Example of bad LCD panel:
http://s807.photobucket.com/albums/y...m/LCD%20panel/Never stop learning
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by EazyBoneAnother TV topic!!
I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by hcinneHello,
I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... - Loading...
