Vizio SV470XVT1A needs to warm up for 3 hours before normal
  • leonwhite
    • Jan 2012
    • 3
    Hello, I have a Vizio SV470XVT1A that I bought approx. 4 years ago, last month I had no picture but horizontal color bars of varying sizes, I replaced the T-con board and it worked perfectly for 30 days and now it needs to warm up for 3 hours before I get a normal picture. Is there another fix that I can do?
  • Paul678
    • Nov 2011
    • 402
    Re: Vizio SV470XVT1A needs to warm up for 3 hours before normal
    If it takes 3 hours to get normal, that gives you plenty of time
    to move over the boards with a hairdryer, until you find the area
    that makes the picture normal again.
    Then troubleshoot at the component level, or Ebay for another
    board.
    Good Luck.
    • bbjunkie
      • Dec 2011
      • 301
      Probably bad caps in the PSU. Post pics of the boards with the back off. Specifically a close up of the PSU 2000x2000 max resolution and use manage attachments.
      • leonwhite
        • Jan 2012
        • 3
        Now when I turn on the Vizio is starts right up with a great picture, but after maybe approximately 4-6 hours of TV viewing it starts the horizontal bars with various colors.
        If I turn it off for a number of hours and restart the picture is normal again and the cycle repeats it self.
        Thanks,
        Leon
        • survivalbloke
          Dell EC chip warm/hot before power-on - normal?
          by survivalbloke
          This is a shot in the dark, and if you need more info, I'll give it all to you. I've already asked for the schematics and boardview.
          This board won't power up. Has 3.3v on BIOS chip pin 8, 3.3v on power button, confirmed voltage to 0v when pressed power button. The EC chip is quite warm just with the power adapter connected and nothing else. Board is out of the machine and everything disconnected. I'm guess that's abnormal and probably the reason for not powering up. I'm still learning and have been fault tracing with my level of knowledge.
          Just wondering if the EC...
          02-06-2023, 05:20 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • Instafixx
          Macbook A2179 820-01958
          by Instafixx
          Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
          The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
          I checked the Power Sequences below and found this -
          Once a valid external power source (Charger or battery) is connected, the following rails will come online.
          PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
          PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
          05-20-2023, 05:19 AM
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
