Dell EC chip warm/hot before power-on - normal?
  • survivalbloke
    • Aug 2021
    • 307
    This is a shot in the dark, and if you need more info, I'll give it all to you. I've already asked for the schematics and boardview.
    This board won't power up. Has 3.3v on BIOS chip pin 8, 3.3v on power button, confirmed voltage to 0v when pressed power button. The EC chip is quite warm just with the power adapter connected and nothing else. Board is out of the machine and everything disconnected. I'm guess that's abnormal and probably the reason for not powering up. I'm still learning and have been fault tracing with my level of knowledge.
    Just wondering if the EC chip being warm/hot is irregular. If so, I'll stop here.
    Board is a Redwood 14296-1 PWB: 7M6GF
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell EC chip warm/hot before power-on - normal?
    EC should'nt be warm in any conditions. You need to check whether EC's VCC pin is shorted or showing low resistance. Whats the resistance on 3V LDO?? What's the consumption on dc supply??
    • survivalbloke
      • Aug 2021
      • 307
      Thank you. Resistance VCC to gnd is ~25ohms. Consumption is 83ma. I was unable to locate 3V LDO as I don't have a schematic. I do have a boardview which I'm attaching to this post, although oddly, it doesn't match exactly what I'm looking at. It is pretty close though. Just some caps and resistors not in the place they appear in the boardview.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        PU4503,pin3 is your 3V LDO. Exact resistance on this pin?? however, your SIO seems to be defective.
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • capoplays
          Help with BIOS update on Dell G15 5515 after chip replacement
          by capoplays
          Hey everyone,
          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
          When I check the BIOS using the F12 menu Flash...
          10-24-2025, 06:53 AM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • ed1i
          Dell Inspion 7610 bios chip
          by ed1i
          Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
          01-16-2025, 02:14 PM
        • donnietr
          Need help id'ing chip on a Dell g15 5515
          by donnietr
          Hello all,
          I have this dell g15 Ryzen Edition 5515. Board GDL56 LA-K453p. It had liquid damage when i bought it. Cleaned it up really well and then used thermal camera to see what got hot.
          Found the power pdw1 and pdw2 under the graphics card were getting hot. Pdw2 was hottest, i had a similiar chip on another board so i put it on this board.
          The other chip is now hot as well, which it was to begin with.
          Thats the problem as i dont know what to call it, like is it a mosfat? or what?
          I will attach a picture of both the boardlabel and of the area with the chips....
          07-18-2025, 08:03 PM
