need to know the value of a smd cap
  • geep6
    • Jun 2009
    • 19
    I have a galaxy gts 250 video card given to me and it has no video. But the cooling fan kicks on so i started looking at it closer and i found a piece of smd cap wedged between to legs of an ic. The ic being this one www.richtek.com/download_ds.jsp?s=327 it was wedged between pin 1 and 2 or 2 and 3 not real sure but any way i was wondering if there was a way to tell the value of this cap here are a few pictures of the damaged area
  • Toasty
    • Jul 2007
    • 4171
    Re: need to know the value of a smd cap
    I think the better question might be... Where are D11 & C465?
    Pics on the web don't show them there. See attached. Pure luck to find a pic of that area so clear and large.
    If they were not there, then C473 is unnecessary. It connects to nothing.
    Looking at the "hanging chad" of a contact, it seems it may have been hit trying to remove/install the board. Perhaps?
    What pin does the right hand pad of C473 connect to on the 9259 IC?
    Toast
    veritas odium parit
    • geep6
      • Jun 2009
      • 19
      Pins D11 & C465 are not populated on my board either. The right hand pad of c473 goes to pin 1 boot of 9259 IC and the left hand pad of c473 goes to pin 13 phase of 9259 IC.
      This is what it says about pin 1 in the pdf. Bootstrap supply for the upper gate driver. Connect the
      bootstrap capacitor between BOOT pin and the PHASE
      pin. The bootstrap capacitor provides the charge to turn on
      the upper MOSFET.
      • Toasty
        • Jul 2007
        • 4171
        Unfortunately, SMD caps are unmarked and unremarkable visually. A 1uF may look identical to a 20uF.
        Either find a trashed board somewhere or experiment with some values. Maybe start at 1uF to 5uF ?
        veritas odium parit
          The bootstrap cap value is not important; 1uF should do. Bigger is better.
          • geep6
            • Jun 2009
            • 19
            Would this cap be directional
            • Toasty
              • Jul 2007
              • 4171
              You mean polarized? No.
              veritas odium parit
              • geep6
                • Jun 2009
                • 19
                Yea polarized that what i was thinking. Any idea what i might pull one off of. I would hate to have to wait a week to see if it will work. I have all kinds of junk electronics laying around
                • Toasty
                  • Jul 2007
                  • 4171
                  Got a cap meter or DMM with a capacitance range?
                  Again, can't just look at these because two identical could be miles apart in value. Perhaps a power supply or similar area in a piece you have.
                  veritas odium parit
                  • geep6
                    • Jun 2009
                    • 19
                    I do have a older digital multi meter. But i dont know if it has a capacitance range or how to set it to test for capacitance here is a pic of it.
                    • Toasty
                      • Jul 2007
                      • 4171
                      Nope. No capacitance scale.
                      veritas odium parit
                      • geep6
                        • Jun 2009
                        • 19
                        Bummer guess i will just have to order a cap. How much is a decent cap meter ?
                        • Toasty
                          • Jul 2007
                          • 4171
                          A true capacitance meter would be ~$40 and up into hundreds. A capacitance and ESR meter would be $120+, the latter being the most useful as it does double duty.
                          The Peak Atlas ESR70 is an example: http://catalog.anatekcorp.com/viewPr...item_id=736034
                          All Electronics has this one, but I don't know (and won't vouch for) its accuracy or reliability:
                          http://www.allelectronics.com/make-a...E-METER/1.html
                          Circuit Specialists has this one (same disclaimer):
                          Item: CSI6013A -
                          http://www.circuitspecialists.com/csi6013a.html
                          They (and others) have DMMs with a capacitance range, but they can be limited in their ranges, such as these:
                          Item: CSI2010 -
                          http://www.circuitspecialists.com/lo...ultimeter.html
                          Item: CSI2205D -
                          http://www.circuitspecialists.com/csi2205d.html
                          Item: CSIMS8264 -
                          http://www.circuitspecialists.com/csims8264.html
                          I have 2 of the last one as they were "freebies" with orders of equipment.
                          Their line of meters: http://www.circuitspecialists.com/di...ltimeters.html
                          Unfortunately, until you step up into bigger bucks, there are few reviews and it's essentially a "pig-in-a-poke" choosing one.
                          Toast
                          veritas odium parit
                          • severach
                            • Aug 2007
                            • 1055
                            The Atlas ESR70 won't measure lower than 1uF. The cap ranges on a standard DMM work good for this.
                            sig files are for morons
                            • Gjackson
                              SMEG induction cooker error EA on both left hand side cooktops
                              by Gjackson
                              I have a SMEG cooktop with a EGO 72.08041.002 power board. The two left hand side cooktops started to slowly fail, sometimes stopping with an EA error (Power board failure according to the manual) after a couple minutes boiling some water and eventually they completely failed and now get an EA error on both of them at all times. Visual inspection of the board went over ok, I checked the IGBT's and rectifiers and they seem fine, what should I look at next as this is the first time I'm fixing an induction cooker, I'm suspecting capacitors in this case, Which ones should I look...
                              07-09-2024, 01:46 PM
                            • kca
                              by kca
                              Hello all ~
                              08-31-2025, 06:38 AM
                            • Axis937
                              Accidental slip of the hand caused a spark on Capacitor. Is my PANEL killed in action?
                              by Axis937
                              Hi folks, newbie here. My intention on a working monitor was to test for voltages on the various pins. Somewhere near the ribbon to the monitor, there we 2 caps. One was reading around 5V and the other was maybe about 12 or 14V . Cant really recall. Then it happened. The multimeter kissed the 5v cap and the other cap. Spark appeared. NOW... the part where the spark happened ( Caps near the Last ribbon cable ) is now totally white. 1/6 part of the screen is white. From my little understanding , i came to learn that there are transistors inside the TFT panel. Could that be a issue then? I have removed...
                              11-10-2024, 06:50 AM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • Cyrs
                              Encountering second-hand power
                              by Cyrs
                              be quiet! E6 750W power supply causes the computer to not boot and displays fault codes 19 and 00
                              When I turned on the power, I found a large triode on the back.(A928),There are obvious signs of burning。
                              After detecting that A928 is short-circuited and replaced, the computer starts up normally....
                              01-11-2024, 05:45 AM
