Sharp Aquos LC-32AD5E-BK wont come on
  • bbjunkie
    • Dec 2011
    • 301
    Re: Sharp Aquos LC-32AD5E-BK wont come on
    Ok will get the scope out tomorrow night and give it a dusting off
    • truep
      • Aug 2010
      • 373
      I had a sony 46" with similar symptoms, it was the main board on that one.
      • bbjunkie
        • Dec 2011
        • 301
        Ok, it might be better if it was the main board, there are many more of these around on eBay than tcon (but maybe this says something in itself)
        Will get the scope out later and see
        • bbjunkie
          • Dec 2011
          • 301
          Originally posted by tom66
          I would check if there are any waveforms appearing at the LVDS connections.
          Any particular pins? Can I use chassis for gnd ?
          • bbjunkie
            • Dec 2011
            • 301
            Been a while since I did anything with this, my friend couldn't make up his mind if he wanted to fork out for a tcon board.
            Earlier this week he gave me the go ahead, so I got the scope out and found some waveforms at CN1 on the tcon board. Also there is 5v there, so i've gone ahead and ordered the replacement.
            Will update when it arrives and I get it fitted.
              I do run into shorted cap in the T-CON board.
              http://s807.photobucket.com/albums/y...t=DSC00722.jpg
              • bbjunkie
                • Dec 2011
                • 301
                #27
                Ok, will have a check for one of those, ordered a T-Con already but it's not here yet. Nothing much to loose though, so i'll check later.
                • bbjunkie
                  • Dec 2011
                  • 301
                  #28
                  T-Con arrived - fitted and no luck blank black screen with backlight.
                  Looks like someone has been here before me - when I removed the old tcon it became apparent due to some security markings on the back of the board - used by an online seller of second hand parts I would assume.
                  Due to there being waveforms at the input, this would suggest that the panel is bad, right?
                  <edit> I recall seeing this tcon listed for a Vizio model also - I will check later which model and do some further research under that model #
                  • netdent
                    • May 2011
                    • 208
                    #29
                    I have one of these that had faults similar to yours (not seen byme) when I looked at it it was stuck in ext5 (hdmi) but adding input displayed nothing and no buttons worked, bought a main board and it works now, but the freeview is white screen with sometimes vertical garbage line on the right, thinking maybe the set it came from had a diffrent dvb card? looked at service manual but not sure yet if it might be a setting needs changed, if anyone knows would be gratefull
                    thanks Ronnie
                    sigpic
                      I think you need to check all the output voltages of the regulator circuits that are being fed by the SW12V, especially the 5vdc regulator that feeds the T-CON board, the blown fuse is shown in the POWER2 SCH.
                      See the attached PDF that I extract from the service manual.
                      As you can see, the SW12V feeds a lot of circuits.
                        Bad panel will not give you balnk screen (there are MANY active parts that being fed by the T-CON board and not likely that ALL have them had failed to give out blank screen), but dead T-CON will give you black screen if you do have LVDS signals feeding it. Check the 5vdc on the T-CON board. Read how T-CON works and how to troubleshoot it: http://www.mediafire.com/?zzjygannjty
                        I try to upload the PDF but it failed.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          The pdf file size limit is supposed to be 9.54MB, but I think there is a bug with the forum software because a few people have tried to upload 5MB pdf files and have failed.
                          I'm pretty sure it has been reported to the site admin, but so far nothing?
                          --- begin sig file ---
                          --- end sig file ---
                            The T-CON training is only 2MB. Well, he can download it from the link instead.
                            • bbjunkie
                              • Dec 2011
                              • 301
                              #34
                              Ok, thanks for the pointers.
                              The intermittent coloured lines aren't appearing with the new tcon - not sure if it's still intermittent or the new tcon has stopped that part of the fault.
                              I will have a read over the tcon training pdf tonight when I get home from work. I have already checked for 5vdc at tcon and it is present and without ripple.
                              • bbjunkie
                                • Dec 2011
                                • 301
                                #35
                                It seems this board is quite popular, the Sharp tcon TW10794V-0 and presumably the panel is also used in:
                                Philips 32PFL5522D
                                Sharp LC-32GD8E & LC-32SD1E
                                Toshiba 32HLX95 & 32WLT58
                                Vizio VW32LHDTV20A
                                Among others.
                                I've got plenty of reading material now, no excuses!
                                • poppik
                                  • Apr 2012
                                  • bro
                                  #36
                                  Hi guys,
                                  I have the same TV. I'm glad to find some place, where it is discussed.
                                  My problem is not in hardware (I hope), but maybe you can help me too.
                                  TV is fine, but only analog tuner is running. The DVB-T tuner doesn't work. Do you know, how to reset it? Maybe some service menu should helps.
                                  I tried factory reset in standard menu, but after that tv freezes and nothing happened. All settings remains.
                                  I search over the web and found some button combination for similar models to enter the service menu, but nothing works.
                                  I appreciate any help.
                                  Thanks!
                                  • vign
                                    • Oct 2013
                                    Originally posted by bbjunkie
                                    Was out today at a friends, and he gave me a TV to look at for him
                                    This one is a Sharp Aquos LC-32AD5E-BK - a 32" LCD with dvb-t and analogue tuner.
                                    Brought it home and plugged it in, after 5 seconds or so there's a click from the PSU and the green LED lights on the front panel.
                                    There is no response from the remote, or any buttons on the TV at all.
                                    Will be taking the back off later and will post pics then.
                                    Jim
                                    I have this TV, and have same problems. Green light on but TV wont turn on! Firstly, where did you buy the axial fuse please? From ebay? any part number? Any make? Was it 1.6? or 2.0? have you removed the old fuse or put it on the top of the old fuse?! Is your TV working with replaced T-CON board? or TV is still in the lab for ongoing surgery?! :-)
                                    • pcdoctoruk
                                      • Jan 2017
                                      • uk
                                      #38
                                      Power board I have changed most of the caps on this board, apart from a few tiny 1mfd to 22mfd caps and all the voltages check out .
                                      the problem is that the sound and tv turns on but the screen has vertical lines down the screen.
                                      after 20 minutes the picture is fine and will work unless the tv is turned off for 2 hours or so and it's back to square 1.
                                      any hints or help would be great..
                                      ps i am looking at getting a replacement board later in the week to see if that works as I am pulling my hair out.
                                      pps all the caps check out within tolerences with my capatence meter... atlas lcr40
                                      • scubacamper
                                        Sharp Aquos LC-70C6400U Half Screen Dark
                                        by scubacamper
                                        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                        05-03-2025, 12:19 PM
                                      • sefoster
                                        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                        by sefoster
                                        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                        11-20-2022, 09:29 AM
                                      • jonah1024
                                        Sharp Aquos LC-40UG7252E LCD TV burn in?
                                        by jonah1024
                                        Hello!
                                        I'm a few days old into this TV screens repair universe so please bear with me.
                                        Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                        - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                        - I did a factory reset as well...
                                        07-16-2024, 04:23 AM
                                      • klassic
                                        Sharp Aquos LC-60LE635E three blinks
                                        by klassic
                                        Hi community,
                                        I will describe my problem with a TV in those short following terms to be the most precise :
                                        What i have :
                                        power board DPS-162KP-1
                                        main logic board QPWBXF733WJN2
                                        symptoms :
                                        white led light logo at startup,
                                        after 2 minutes, blinking 3 times a row, repeating
                                        no backlight (and apparently no picture, checked panel with flashlight)
                                        no startup sound
                                        powerboard investigations :
                                        1-2 PNL : 0v
                                        3-4 GND
                                        5-6-7-8 UR : 13.15v
                                        9-10-11-12...
                                        10-24-2023, 01:39 PM
                                      • foxyUK
                                        Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                        by foxyUK
                                        Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                        The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                        There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                        10-22-2024, 10:27 AM
