VZ42L No Amber light, no stand by 5v
  • Bigredram87
    • Sep 2013
    • 88
    Re: VZ42L No Amber light, no stand by 5v
    That's all I have done so far
      That should be enough to run the IC, orientation is correct for sure. Look at the output pin7? which drive the Gate of the PFC MOSFET to see if it has any voltage there.
      • Bigredram87
        • Sep 2013
        • 88
        Ok pin 7 to ground? With pson correct
        • Bigredram87
          • Sep 2013
          • 88
          ok I have 10.90 Volts output but the strange thing is I have a 10.90 voltage drop across the first resistor off of pin 7? I have 10.90V at the lead edge of the SM resistor and 0 volts on the other side.... THe thing I also just realized is there are multiple other resistors that have no continuity across them!!
            It would be helpful to see the position of these resistors you refer to.
            • Bigredram87
              • Sep 2013
              • 88
              Ok this one is measuring 8.5M ohm
              I realize now that the other ones just dont wrk on coninuity setting and if you use ohm setting the do register a value I apologize
              • Bigredram87
                • Sep 2013
                • 88
                I believe it is has 100 printed on it
                • Bigredram87
                  • Sep 2013
                  • 88
                  OK I replaced the resistor with one I had and the cap did shoot up to 400V and the Tv was making a whining type noise. It ended up blowing my main fuse when the voltage reached 400 but I was only using a 5amp fuse (temp until rest of my order comes in)
                    OK, I looked the board lay out, pin 7 (Gate drive) is connected to R820, this resistor is connected in series with R806, this R806 is then connected in series with R822 (basically these 3 resistors are connected in series), R822 is connected in parallel with Gate discharge Diode D807 and then feed the Gate of the MOSFET Q801. Since the resistor is damaged, it means that the MOSFET was damaged (Drain to Gate shorted out that it is blown open by now) and dumped about 380VDC into the output pin 7 of the PFC IC. I cannot read the value of those resistors, the Diode D807 mat be damaged also.
                    • Bigredram87
                      • Sep 2013
                      • 88
                      Wow ok I can take it to work and look under scope to get the values... SO basically I should replace R820,R806 R822 D807 Q801
                      • Bigredram87
                        • Sep 2013
                        • 88
                        Is there a way I can test Mosfet just for future reference and to verify
                        • Bigredram87
                          • Sep 2013
                          • 88
                          Also is there anything I can check after the FET to make sure nothing else was damaged
                            I would check the PFC diode - near the FET - just in case that caused the original fault.
                              R824 needs to be check also. Since D807 is in parallel with R822, it will not readout correctly, you will have to remove it off the board.
                              You can check for shorts on all 3 legs combination. Real function test will be an active test by using power supply, LED for indicator, resistor.
                              • Bigredram87
                                • Sep 2013
                                • 88
                                I feel like its bad i believe it is showing it's flowing both ways in diode check mode 1 direction measures .686v the other which i thought should be overload measures -.868 or something close to that
                                  I am sure it is bad since 13V power supply cannot damage the Gate drive circuit like that, it had to be High voltage from the Drain to Gate that caused the damage to the resistor. I should have told you to check those resistor but from the pictures I did not see any blown up resistors in the Gate drive path.
                                  • Bigredram87
                                    • Sep 2013
                                    • 88
                                    Yea its strange the one that is blown for sure the 10 ohm looks completely fine until you pull it out and measure it Thanks so much I plan on ordering these parts soon
                                      I usually tell people to change the IC and the MOSFET at the same time and check the Gate drive resistors/Diode network, I am sorry I did not tell you that. Might as well take a close look at C816 which is in parallel with the Source Drain to see if it has any burnt sign.
                                      • Bigredram87
                                        • Sep 2013
                                        • 88
                                        Oh no problem I'm very excited to be learning this stuff. I will let you know when my parts arrive again thank you
                                        • Bigredram87
                                          • Sep 2013
                                          • 88
                                          Ok I replaced the diode and the blown resistors now I am just waiting for MOSFET to ship. In the meantime can you explain the good method of checking mosfets ? I have a breadboard and resistors and LEDs. I would like to know process
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • maxim2511
                                            LG 55EC930V OLED - swich on swich of no screen
                                            by maxim2511
                                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                            Then I get an idea to take it apart and clean boards from dust.
                                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                            05-14-2021, 02:21 AM
