Re: A guide to fixing/troubleshooting some common plasma TV problems
tpvsn shows me 0.08V.....and tpvad 0.188V....if i correctly checked it !?!
This topic is closed.
Thanks for your reply, have a Samsung tech booked for next week so l'll see what he come's up with.Leave a comment:
ok,ill mesure..thanks for your help!Leave a comment:
Ah, panasonic 7 blinks of death... Great to have found this forum. I will be sure to start a new thread when I need some advice. I hope this works as the one post I need to make in order to start a thread...Leave a comment:
how can i set that up?Leave a comment:
It may be that the VAD or VSCN voltage is not correctly set.
Vad is typically -100V to -190V. Vscn is typically +90V to +200V.Leave a comment:
Here are the pictures...the menu is affected as soon as i open the settings,first menu where i choose some options like picture,sound,security isnt affected !
btw. Original part has this mark on him TNPA5066AB,but i wasn able to find it,i found one seller that had TNPA5066AC,and that part has been marked as substitute part for my original!Leave a comment:
hi tom..i hope you can help me..i had a 7 blinks on my Panasonic Plasma TX-P42X20E...i searched the net and found out that the problem most likely is in the SN board...i ordered it ,and succesfuly replaced it. The plasma fired up,the picture was on but the colours were all mixed up...like red and green...i hope you could help me somehow! thank you
Does the distortion also affect the menus?
Did you match the board suffix too? (May not be important for SN board.) Board suffix printed near TNPA.....Leave a comment:
hi tom..i hope you can help me..i had a 7 blinks on my Panasonic Plasma TX-P42X20E...i searched the net and found out that the problem most likely is in the SN board...i ordered it ,and succesfuly replaced it. The plasma fired up,the picture was on but the colours were all mixed up...like red and green...i hope you could help me somehow! thank youLeave a comment:
Sounds like it's unable to save settings - could be EEPROM. On TV this new, not your problem to fix it. Get Samsung to fix it.Leave a comment:
Having trouble with Samsung f8500 plasma not able to save picture settings have chosen home use in setup and is showing home mode in menu but after turning the tv off then back on its gone back to default settings been trying to correct it for weeks any ideas anyone would it be something failing inside the set.Leave a comment:
It looks to me like low Vs or Ve voltage. Easily fixed. Start your own thread.Leave a comment:
I bought this tv LG 60pz750 in november 2011, it has an awesome picture but few days ago we notice a type of flickering burn image.
I attach a picture so you can see it. Also, i have video in you tube too
Code:http://youtu.be/ZZKig9N0bZo
Thank youLeave a comment:
Hi Tom
I figure you may say start a new thread but this might only require a quick answer. I have a Panasonic VT50 3D plasma. It's just over 3 years old but has a 5 year extended warranty. Recently it has developed a fault on the upper left corner of the screen. There is a distinct rectangle of short vertical stripes which goes out horizontally approx 3 inches from the frame and extends vertically to halfway down. Is this something you are familiar with?
Cheers.Leave a comment:
Hi Tom,
I have a Samsung PN42A400c2d that was working fine and then one day I turned it on and the blue power indicator light blinks a few times and the stays lit with no picture whatsoever. I have gotten some conflicting advice on whether its a power board issue or a Y-main issue. Help!Leave a comment:
Hi Tom,
As far as panel lifetime go, Panasonic followed by LG followed by a large gap followed by Samsung.
As far as general reliability goes, the order is the same though a higher end Samsung or LG is generally as good as a higher end Panasonic; at the lower end Panasonic beats Samsung and LG.
Well thank you again mate.Leave a comment:
As far as general reliability goes, the order is the same though a higher end Samsung or LG is generally as good as a higher end Panasonic; at the lower end Panasonic beats Samsung and LG.Leave a comment:
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... - Loading...
