Re: A guide to fixing/troubleshooting some common plasma TV problems
Wow, what a quick reply. Thank you.
Well I think it's a plasma. I assume it is because it's quite an early model and I thought LCD/ LED came out later?
Anyway I can get the model number off the back tomorrow but I need my allen keys from work to loosen the tilt bracket and I forgot them the rush today.
I'll post it tomorrow if that's okay but I think you may be correct if I can buy a replacement for what you say.
Many thanks
Fritz
This topic is closed.
It is a plasma?
The model # off the rear of the set would help, or if you have written it down.
A 42" 2003 plasma is likely to be 480p SD, which will mean repairing it will probably exceed the costs of a replacement, used one (around £50 to £100 here.)Leave a comment:
Hi Tom
Seems like a brilliant forum. Concise and (relatively) easy information to follow.
A quick question if I may as I appreciate I might (hopefully) need to start a new thread for this. I have a 42" Bush TV. I don't know the model no. I'm afraid as it's mounted on the wall at the moment and I've yet to dismount it.
This TV is approx. 10 years old and served me very well in that time. When watching the other night it appeared to suddenly go into standby mode. The screen went black and the LED power light flashed red then green 7 times. Then nothing, then the repeating flashing. I tried powering down and waiting 5 mins and then powering on but now when I turn it on it seems about to start normally but after 1-2 seconds with the green led lit, just as I expect the picture to appear, I hear a click and I get the 7 flashing red/ green LEDs. Then nothing for short while, then the 7 flashing LEDs again. No picture throughout this process.
My question is does this sound like a fixable problem? As I said this TV is about 10 years old so I'm not expecting miracles but a new TV just before Christmas isn't really something I'd like to consider.
Many thanks
FritzLeave a comment:
Right side is SS.
4 blinks can be caused by Vsus short, Vda short (I think...), and 15V short. So if you get a 6/7/8 blink code when SN or SS is disconnected, I'd check each of those boards for a short across those points. You could have received a bad board, it's fairly common.Leave a comment:
sry..i dont know correct name for that long board on the right side of tv...i know that the left one is SN board,i replaced her!
There isn't an SC and SN, only one or the other. Please double check.Leave a comment:
hi tom ...me again... the SJ guys sent me another SN board(we presumed that the first one was bad),i mounted it and again the tv aint working..but now i even cant start it,as soon as i power it i get 4 blinks!
when i disconnect SN board i get 4 blinks,when i disconnect SC board i get 7 blinks...when both disconnected i get 6 blinks!?
its really disappointing...but i think i messed it up all the way!
is there any help..or could you give me any tip ?
thx...Leave a comment:
It's best to create your own thread if you need further help.informative post! thanks!
reason i just joined is because my 1.5 yr old LG 60" just started showing pinkish-greenish shades flickering across the screen. face shadows are greenish and whites are washed out with a pink-purple haze.
i'll carefully follow your instructions with hopes of saving this (expensive) tv
Disconnect whatever is necessary to remove the control board. If you remove more than what's necessary, no biggie. Take pics so that you can put things back together correctly.Ok, so I see the small screws with the little stand offs keeping the board elevated. Once I unscrew these and lift the main board what will I need to disconnect. Do I have to remove the main board or just loosen it so I can get under it? Also, anything I should avoid or not touch with tools or hands?Last edited by capkid; 11-03-2013, 11:02 AM.Leave a comment:
Ok, so I see the small screws with the little stand offs keeping the board elevated. Once I unscrew these and lift the main board what will I need to disconnect. Do I have to remove the main board or just loosen it so I can get under it? Also, anything I should avoid or not touch with tools or hands?Leave a comment:
The control board is underneath the main board, which you have taken photos of.Leave a comment:
Ok, so I see the cable and it is coiled up and zip tied. Looks like it exits just north of the main panel and goes into the larger portion of the TV I have not accessed. Am I looking for a control board "under" the main board or "above" the main board located in the section of TV I have not exposed yet? Thanks for helping. I know it is tough to do via web.Leave a comment:
The pic you posted is of the main board. The control board is behind it. See the attached pic.Are you referring to the large board with the silver foil ribbon connectors? This would be on the right hand side of the TV. On my left working from the back. I don't know what I am looking for, but it looks to me that that board is screwed directly to a metal panel and it does not look like there could be anything under it.Attached Filesif you find these attachements useful please consider making a small donation to the site
Are you referring to the large board with the silver foil ribbon connectors? This would be on the right hand side of the TV. On my left working from the back. I don't know what I am looking for, but it looks to me that that board is screwed directly to a metal panel and it does not look like there could be anything under it.Leave a comment:
Will be under that board.Leave a comment:
Another.Attached Filesif you find these attachements useful please consider making a small donation to the site
Here are some more pics.Attached Filesif you find these attachements useful please consider making a small donation to the site
Ok Tom, here are the pics of the back of my TV. To refresh, it is an LG. Model no. RU42PZ61. I have located the place to send the board for repair, but need to know which part I am supposed to remove.
http://www.ebay.com/itm/6871QCH038A-...item2a22d26aa4
So here is a pic of inside. This is with the small access panel removed. Do I have to remove the entire back or just the smaller access panel? How do I know which part I am after?Attached Filesif you find these attachements useful please consider making a small donation to the site
At a minimum, your Y-Sus is bad. Your Z-Sus may also have issues if the Vzb voltage reading you posted is accurate. Typically, the recommendation is to replace the large IC on BOTH boards at the same time.Leave a comment:
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by alltvrepairsHi,
I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
Any one met this problem in the past?...10-08-2025, 07:34 AM - Loading...
