LG 42LC46 problem
  • sienoki
    sienoki
    • Jan 2012
    • 314
    Re: LG 42LC46 problem
    Originally posted by sienoki
    this is best pic at mo
    heres another
      I see at least one regulator on the board.
      Get out your multimeter. Set it to 20VDC. Place the black probe on the metal chassis; for example, a part of the metal frame like a spare screw hole. Then, turn the TV on (and make sure the picture is good.) Measure the voltage on each pin (using the red probe) - for the middle pin, measure the tab as they are connected to each other and it's easier to measure, and report the readings. Then, wait for the picture to go bad, and measure again.
      Use a loupe to read the part number and report that back.
      • sienoki
        sienoki
        • Jan 2012
        • 314
        heres another
        the regulator markings are rt9164a..15pg9fr0z
          Datasheet: http://pdf1.alldatasheet.com/datashe...K/RT9164A.html
          "15" indicates 1.5V output, so we should see 1.5V on one pin.
          • sienoki
            sienoki
            • Jan 2012
            • 314
            the middle leg is1.49
            the left 1 is 0.00
            the right 1 is 3.25
              the left 1 is 0.00
              the right 1 is 3.25
              That's fine. Was that during failure or normal operation?
              • sienoki
                sienoki
                • Jan 2012
                • 314
                #27
                the left 1 is 0.00
                the right 1 is 3.25
                no change in them readings after picture gone
                • sienoki
                  sienoki
                  • Jan 2012
                  • 314
                  #28
                  them readings where when picture good..them readings didnt change when picture gone
                    Okay so the regulator is fine.
                    Next step:
                    - turn TV off at wall
                    - disconnect left ribbon connector (for left side of screen)
                    - turn back on you should have picture on right but not on left (left hand might be random noise, or just white or black.)
                    - wait 10 mins does problem occur?
                    - turn back off, plug left in and repeat with right.
                    • sienoki
                      sienoki
                      • Jan 2012
                      • 314
                      #30
                      Next step:
                      with left ribbon off left is white and right no picture just flickering dark grey screen vice versa
                        Strange, never seen that behaviour before, okay that means my test there won't work. (Some t-cons work with half the display, due to marginal components...)
                        Next test is to leave the set on with ribbons connected until problem occurs, then unplug the LVDS cable, leave T-con for 30 seconds, and plug the LVDS back in, seeing if you get a picture.
                        Also, do you get sound during failure?
                        • sienoki
                          sienoki
                          • Jan 2012
                          • 314
                          #32
                          Do you want me to do your 1st test again when the set is cold..cos i only get a good picture for 10mins from cold and when picture goes bad i would have to wait till set cooled down again to get good picture back
                          I did your 1st test as soon as picture went so that is probably why half of screen had no picture..there was sound during failure
                          • sienoki
                            sienoki
                            • Jan 2012
                            • 314
                            #33
                            Just done your second test had to wait to get a good picture to start with..anyways had good picture for about 8mins pulled LVDS cable waited 30secs then plugged back in but no picture m8..sound remains
                            • sienoki
                              sienoki
                              • Jan 2012
                              • 314
                              #34
                              I asked the lad at work today what the faults where..he said he was having screen problems going shaded then flickering..after that then the start up issues(bad caps)he never told me about the screen issue when i bought it.
                              Do you reckon the screen itself is on its way out.
                                The fault in the pics doesn't look like a screen fault, as the noise is random like digital noise - screen faults cause bands of failure (e.g. horizontal/vertical lines, missing parts of picture, slow updating on one half, etc...)
                                Can you repeat the first test after the set cools down?
                                Do you have an oscilloscope, or can you borrow one?
                                • sienoki
                                  sienoki
                                  • Jan 2012
                                  • 314
                                  #36
                                  I dont have an oscilloscope(have you seen state of my multimeter)i dont know of any1 i could borrow off.That bloke at farnells said he was a moderator on this site but i didnt get his num or name
                                  anways i will do 1st test again
                                  • sienoki
                                    sienoki
                                    • Jan 2012
                                    • 314
                                    #37
                                    Done 1st test again with replacement t-con just same results so i tried the original t-con board..left ribbon in place i could see some of the picture but the background was white not greyed out like the replacement?right ribbon in place it was trying for a picture but not white background..weird
                                    I wont beable to get my hands on any advanced testing equipment so it looks like im stuck with a dead set
                                    • sienoki
                                      sienoki
                                      • Jan 2012
                                      • 314
                                      #38
                                      Since i replaced the bulged caps the set has never been on for longer than 40mins..ive now left if for 1hr with the picture like in quote 14..had 10 cups of coffee cos im dont like getting beat..especially with 90quid in it..anyways after 1hr i turned the set off by the remote(standby)and then turned it straight back on with remote and have been watching a crappy army film with patrick swayze for over 1hr..ehh
                                      So my question is did something on the boards?just need a good charging or something???
                                      • bbjunkie
                                        • Dec 2011
                                        • 301
                                        #39
                                        Aren't intermittent faults so much fun?
                                        It's doubtful the fault has been fixed. I hope it has though. However in the last week I have had 2 tv's and a car heater fan all with intermittent problems that have magically started working again.. go figure!
                                        Jim
                                        • sienoki
                                          sienoki
                                          • Jan 2012
                                          • 314
                                          #40
                                          The fault has not been fixed..after 10mins when the picture goes the back of the set is not warm..it only starts to get warm at about 40mins..then if i turn off and on with remote the picture great for as long as the set is on..
                                          What other tests can be done?
                                          Im thinking solder joints but ive got a jewelers eye and had a really good look..cant see anything obvious..when i borrow a descent camera i will post some close ups of all the boards underneath..thx
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                          • THXFX
                                            samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                            by THXFX
                                            Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                            I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                            When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                            What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                            I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                            Measured all power supply...
                                            03-20-2024, 03:21 AM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
