LG 42LC46 problem
  • Scoots
    • Jul 2015
    • England
    #81
    Re: LG 42LC46 problem
    I Know this is an old thread but I had the same problem as the OP. The TV would power on when cold but after 2 mins the picture would go off, sound and back light still on. Using the hairdryer trick I thought I had found the problem C954 - 470uF ( top left corner ) I changed that and all was well. So I thought, the TV did not go off. I left it on for about 1.5 hours then turned it off and on again, no picture again. Having scoured the internet I found a site that offered a repair kit for for such problems which showed the capacitor numbers. I changed C975 -100uF ( near T-Con connector ) the TV seems to be working as it should :-).
    The capacitors listed on the site are.
    C553 - 100uF
    C901 - 100uF
    C915 - 100uF
    C954 - 470uF
    C970 - 100uF
    C975 - 100uF
    I hope this helps other people with the same problems
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      #82
      C553 - 100uF
      C901 - 100uF
      C915 - 100uF
      C954 - 470uF
      C970 - 100uF
      C975 - 100uF
      Thank you sooo much this helped me repair one I have
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • THXFX
        samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
        by THXFX
        Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
        I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
        When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
        What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
        I check capacitors and diodes and didn't find any short IN MAINBOARD.
        Measured all power supply...
        03-20-2024, 03:21 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
